Hi Nv member:
I’m seeing a DKMS build failure when installing mlnx-ofed-kernel-dkms (OFED 25.07) on an aarch64 system with NVIDIA kernels.
On the same machine, the DKMS build works fine on kernel 6.14.0-1013-nvidia, but fails on 6.14.0-1015-nvidia. Because both kernels are installed, the package installation fails overall.
The failure happens during the DKMS build step:
./ofed_scripts/pre_build.sh 6.14.0-1015-nvidia …
and DKMS reports a bad exit status for 6.14.0-1015-nvidia.
Kernel headers for 6.14.0-1015-nvidia are installed, and no changes were made between the two kernels other than the patch level. This makes it look like a kernel compatibility issue specific to 1015.
Or I need the install the driver by the following link?
Could you please advise whether kernel 6.14.0-1015-nvidia is expected to be supported by OFED 25.07, or if there is a recommended workaround or fix?
- Fail_log reference:
20251226_mlnx-ofed-kernel-dkms_fail_log.txt (8.7 KB)
Found pre-existing /lib/modules/6.14.0-1013-nvidia/kernel/drivers/net/ethernet/mellanox/mlx5/core/mlx5_dpll.ko.zst, archiving for uninstallation
Installing /lib/modules/6.14.0-1013-nvidia/updates/dkms/mlx5_dpll.ko.zst
Installing /lib/modules/6.14.0-1013-nvidia/updates/dkms/fwctl.ko.zst
Installing /lib/modules/6.14.0-1013-nvidia/updates/dkms/mlx5_fwctl.ko.zst
Running the post_install script:
----- mlnx-ofed-kernel post-install ------
Package ‘srp-dkms’ is not installed, skipping module ‘srp’.
Package ‘iser-dkms’ is not installed, skipping module ‘iser’.
Package ‘isert-dkms’ is not installed, skipping module ‘isert’.
Package ‘mlnx-nfsrdma-dkms’ is not installed, skipping module ‘mlnx-nfsrdma’.
Package ‘mlnx-nvme-dkms’ is not installed, skipping module ‘mlnx-nvme’.
Running depmod… done.
Building initial module mlnx-ofed-kernel/25.07.OFED.25.07.0.9.7.1 for 6.14.0-1015-nvidia
Deprecated feature: CLEAN (/var/lib/dkms/mlnx-ofed-kernel/25.07.OFED.25.07.0.9.7.1/source/dkms.conf)
Sign command: /usr/bin/kmodsign
Signing key: /var/lib/shim-signed/mok/MOK.priv
Public certificate (MOK): /var/lib/shim-signed/mok/MOK.derBuilding module(s)…(bad exit status: 1)
Failed command:
./ofed_scripts/pre_build.sh 6.14.0-1015-nvidia /lib/modules/6.14.0-1015-nvidia/build mlnx-ofed-kernel 25.07.OFED.25.07.0.9.7.1
ERROR: Cannot create report: [Errno 17] File exists: ‘/var/crash/mlnx-ofed-kernel-dkms.0.crash’Error! Bad return status for module build on kernel: 6.14.0-1015-nvidia (aarch64)
Consult /var/lib/dkms/mlnx-ofed-kernel/25.07.OFED.25.07.0.9.7.1/build/make.log for more information.
dpkg: error processing package mlnx-ofed-kernel-dkms (–configure):
installed mlnx-ofed-kernel-dkms package post-installation script subprocess returned error exit status 10
Processing triggers for initramfs-tools (0.142ubuntu25.5) …
update-initramfs: Generating /boot/initrd.img-6.14.0-1015-nvidia
Errors were encountered while processing:
needrestart is being skipped since dpkg has failed
E: Sub-process /usr/bin/dpkg returned an error code (1)
