ModuleNotFoundError: No module named 'gi' while running Python 3.10 code on Jetson Nano 16GB emmc (SD card customized)
Hello everyone,
I am encountering an issue while running a Python script on my Jetson Nano (Ubuntu 18.04). The script imports the gi module, but when I attempt to run it, I get the following error:
Steps I have followed to try and resolve the issue:
  1. Installed the necessary dependencies:
    I ran the following command to ensure that the required libraries were installed:
    sudo apt-get install -y libgirepository1.0-dev libcairo2-dev
  2. Installed PyGObject via pip for Python 3.10:
    I upgraded pip and installed PyGObject for Python 3.10:
    python3.10 -m pip install PyGObject
  3. Checked the installation:
    I tested the installation in a Python 3.10 environment:
    import gi
    This ran without issue.
  4. Confirmed Python 3.10 is the default:
    I made sure that Python 3.10 is being used as the default version:
    python --version
    # Output: Python 3.10.x
Despite these steps, I still encounter the error when running my script:
python3.10 deepversion.py
System Information:
  • Jetson Nano Model: Jetson Nano 16GB EMMC
  • Ubuntu version: 18.04
  • Python version: 3.10.x
Has anyone encountered a similar issue, or can provide further guidance on resolving this?
Thank you in advance!
deepversion.py.zip (1.5 KB)
I tried with different PyGObject version and it worked.
python3.10 -m pip install PyGObject==3.38.0
