ModuleNotFoundError: No module named 'isaacsim.replicator'
Isaac Sim Version
4.2.0
Operating System
Ubuntu 22.04
when ı run this code in bash. Path: → (env_isaacsim) ibra@ibra1903:~$ python capture_image.py
ModuleNotFoundError: No module named ‘isaacsim.replicator’
How can ı fix it?
import os
import sys
import cv2
# Isaac Sim modül yolunu ekle
sys.path.append('/home/ibra/.local/share/ov/pkg/isaac-sim-4.2.0/kit/python/lib/python3.10/site-packages')
# EXP_PATH değişkenini kontrol et
if 'EXP_PATH' not in os.environ:
    os.environ['EXP_PATH'] = '/tmp'
# sys.path kontrolü
print(sys.path)
# Isaac Sim modüllerini içe aktar
from isaacsim import SimulationApp
from isaacsim.replicator.synthetic_record import SyntheticDataRecorder
# SimulationApp'i başlat
simulation_app = SimulationApp({"headless": False})
# SyntheticDataRecorder'ı başlat
sd_recorder = SyntheticDataRecorder()
# Kameranın sahnedeki yolu
camera_path = "/World/Camera"
# Görüntü alımı işlemleri
rgb_image = sd_recorder.get_rgb(camera_path)
depth_image = sd_recorder.get_depth(camera_path)
# Görüntüleri kaydedin
cv2.imwrite("rgb_image.png", rgb_image)
cv2.imwrite("depth_image.png", depth_image)
# Simulation App'i kapatın
simulation_app.close()
(env_isaacsim) ibra@ibra1903:~$ pip list
when ı write this command :Isaac sim-replicator appears
