I’ve been having this issue for at least 3 years where my display will be blurry while using the proprietary Nvidia driver. Nouveau doesn’t fix anything either.
Any screenshots that I take using the monitor will show up crystal clear, but visually looking at it, everything seems fuzzy, blurry and sometimes even ghosts if I move a window around. I have a second monitor plugged in via a DP->VGA adaptor and, even when my main monitor is blurry, that looks perfectly fine. Sometimes my monitor will work flawlessly, but that’s once in a blue moon.
I’m currently running Void Linux with the latest Linux kernel and KDE Plasma.
I am using an Nvidia RTX 2060, and the monitor is getting the signal via HDMI. I am unsure of the monitor’s control board and anything like that as it’s a seemingly random brand that have no official datasheets (and it doesn’t even seem to be sold anymore). What I do know is it’s a 32" 1080p@60Hz display, and it won’t go higher than that.
I don’t have this issue on Windows 10, and everything is displayed crisp and clear as day.
Here are some troubleshooting steps that I have taken:
- Tried GNOME, KDE Plasma and even XFCE - all produce the same output
- Swapped the HDMI cable and even bought a whole new one
- Tried changing the HDMI port that I use on the monitor
- The issue has persisted across two GPUs now (I used to use a GTX1050)
- Reinstalling the Nvidia Linux drivers (and reconfiguring them). They show up in
lsmod
and X11 is set to use them - nouveau is blacklisted and I confirmed this withlsmod
- The issue has persisted over many distros, such as Ubuntu, Pop, Arch, Gentoo and Void.
- I have looked in the monitor settings and found nothing relevant, and changing everything I can see does nothing to fix the clarity either
- I’ve looked high and low in Plasma’s and Nvidia’s settings, and tried things such as forced anti-aliasing, text rendering, and even vsync changes. They make no difference even after a save + reboot.
- I’ve installed every (even seemingly) relevant package across every Linux distribution that I’ve used, and none of them made a difference.
- I re-tried POP_OS and ensured that I was using the Nvidia ISO and installs to root out any misconfiguration, to no avail.
- Ensured that FXAA was disabled in the Nvidia settings
- I can view a full 1080p image in Firefox while using F11, with no vertical/horizontal scroll bars
- I have checked through the nvidia log file (the one you’re able to generate manually) and found nothing that seems to relate to my issue. nvidia-bug-report.log.gz (215.8 KB)
It’s probably important to note that, in a live Linux ISO, if I change my output to a lower resolution and then back to native a good 5-8 times, the monitor will clear up. This is not a permanent fix but I think it has something to do with the connection being re-initialised, although I’m not too sure about the reason.
I have looked around for others that have experienced something similar to me and all of the issues turned out to be misconfiguration or things that had nothing to do with what I’m experiencing (mostly anti-aliasing issues).
I find it hard to think of things that could be at fault as it works perfectly fine in Windows, which is baffling to me. In addition to this, when I ran Windows under Linux via KVM+QEMU (with Single GPU Passthrough), all the issues went away as the drivers were handled by Windows.
“bls-bls3393” is the closest match to my monitor I can find online, except mine is 32" and not 19". I can’t post anymore links in here due to being a new user.
Here is an output of xrandr
Screen 0: minimum 8 x 8, current 3360 x 1179, maximum 32767 x 32767
HDMI-0 connected primary 1920x1080+1440+0 (normal left inverted right x axis y axis) 376mm x 301mm
1920x1080 60.00*+ 59.94 50.00 23.98
1680x1050 59.95
1440x900 59.89
1280x720 60.00 59.94 50.00
1152x864 60.00
1024x768 60.00
800x600 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94 59.93
DP-0 connected 1440x900+0+279 (normal left inverted right x axis y axis) 408mm x 255mm
1440x900 59.89*+
1280x1024 75.02 60.02
1280x960 60.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 disconnected (normal left inverted right x axis y axis)
Here are two previews of google, this is windows and this is Linux. I know the differences aren’t too perceivable on camera, but they are to the naked eye. Looking at it more, it seems that the output is also heavily under-saturated while in Linux.
I have also asked this on StackExchange and I was referred here by a commenter.
