OS: Debian 13 “Trixie” (fresh upgrade from Debian 12)
Driver Version: 550.163.01
Display Server: X11
Kernel: 6.12.48+deb13-amd64
Problem Description:
After upgrading from Debian 12 to Debian 13, monitors do not wake up after suspend. The system appears to resume (fans spin up, lights come on) but displays remain black and unresponsive.
Reproducible Steps:
Fresh Debian 13 installation with NVIDIA 550.163.01 drivers
Run sudo systemctl suspend
Wake system (keyboard/mouse/power button)
Result: Black screens, system appears hung
Key Finding:
Uninstalling NVIDIA drivers completely resolves the issue - suspend/resume works perfectly with nouveau drivers.
Expected Behavior:
Monitors should wake up properly after suspend, as they do with nouveau drivers.
Additional Notes:
This appears to be a regression - suspend/resume worked fine on Debian 12 with earlier NVIDIA drivers. Issue persists with X11 (not Wayland-specific).
I will attach nvidia-bug-report.sh output if this helps with diagnosis.
First, as the power management is closely linked to BIOS quality, ensure that you have an up to date BIOS. For example, Ryzen need AGESA 1.9.0.0 to operate in mode S0ix. So, check for BIOS updates, and apply them if required.
Edit /etc/modprobe.d/nvidia-options.conf
#options nvidia-current NVreg_DeviceFileUID=0 NVreg_DeviceFileGID=44 NVreg_DeviceFileMode=0660
# To grant performance counter access to unprivileged users, uncomment the following line:
#options nvidia-current NVreg_RestrictProfilingToAdminUsers=0
# Uncomment to enable this power management feature:
#options nvidia-current NVreg_PreserveVideoMemoryAllocations=1
#options nvidia-current NVreg_EnableS0ixPowerManagement=1
and uncomment the two last options (NVreg_PreserveVideoMemoryAllocations=1 and NVreg_EnableS0ixPowerManagement=1) as above.
I also uncommented NVreg_RestrictProfilingToAdminUsers=0, but it’s not needed by suspend, hibernate…
Hi @mika9 , thanks for reporting this issue.
Could you please help to attach a bug report once you see this issue? If the system stays unresponsive, please take a bug report after a reboot. If you are able to ssh into the repro system from another system, please take a bug report when it is in the hung state with the safe mode option.
