Mosaic with 5 displays (1:5), Quadro RTX 5000
Hello Guys,
I’m trying to run a setting with 5 displays. The displays are plugged in the GPU via 4DIsplayport und 1USB-C.
The displays are lined up (rows=1 and cols=5) and rotated at 90°.
But the problem is, the system only shows 4 of them. The last one is deactivated and when I try to turn it on in the windows settings, it turns on but another one deactivates.
Does the Quadro RTX 5000 support 5 displays?
And if, can you pls give me a little help for the configuration?
Kind regards
The RTX 5000 supports a max of display outputs on a single GPU. For 5 outputs you will need to use 2 RTX 5000 GPUs.
