Hi @Simplychenable and @rthaker. Thank you for the information. I will paste a full isaac log at the bottom of this reply.
@rthaker: I can rule out 3. In one run we are simulating roughly 4000 environments in parallel which takes ~5Gb of GPU memory, whereas the GPUs have at least 40Gb available. I verified this with nvidia-smi. Some more information on the issue:
- We isolate training runs by having each in their own docker container. I am not sure how you would synchronize between different training runs when they are their own applications running in separate docker containers
- I am suspecting that the issue is 2, there might be some code in the cuda physx articulation backend of isaac-sim which works with fixed memory locations?
Is there some way of checking what memory locations are accessed by the code in question, to verify that both instances try to access the same location?
Full isaac log:
stdout
[Warning] [omni.isaac.kit.simulation_app] Modules: ['omni.isaac.kit.app_framework'] were loaded before SimulationApp was started and might not be loaded correctly.
[Warning] [omni.isaac.kit.simulation_app] Please check to make sure no extra omniverse or pxr modules are imported before the call to SimulationApp(...)
[Warning] [omni.kit.app.plugin] No crash reporter present, dumps uploading isn't available.
[Info] [carb] Logging to file: /isaac-sim/kit/logs/Kit/Isaac-Sim/2022.2/kit_20231010_114008.log
2023-10-10 11:40:08 [31ms] [Warning] [omni.ext.plugin] [ext: omni.sensors.nv.lidar] Extensions config 'extension.toml' doesn't exist '/isaac-sim/exts/omni.sensors.nv.lidar' or '/isaac-sim/exts/omni.sensors.nv.lidar/config'
2023-10-10 11:40:08 [31ms] [Warning] [omni.ext.plugin] [ext: omni.sensors.nv.radar] Extensions config 'extension.toml' doesn't exist '/isaac-sim/exts/omni.sensors.nv.radar' or '/isaac-sim/exts/omni.sensors.nv.radar/config'
[0.249s] [ext: omni.stats-0.0.0] startup
[0.261s] [ext: omni.rtx.shadercache-1.0.0] startup
[0.266s] [ext: omni.assets.plugins-0.0.0] startup
[0.268s] [ext: omni.gpu_foundation-0.0.0] startup
[0.279s] [ext: carb.windowing.plugins-1.0.0] startup
2023-10-10 11:40:08 [268ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2023-10-10 11:40:08 [268ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.3]) (impl: carb.windowing-glfw.plugin)
[0.283s] [ext: omni.kit.renderer.init-0.0.0] startup
2023-10-10 11:40:08 [384ms] [Warning] [carb.graphics-vulkan.plugin] No command queue family supports flags: 0x100, queue type: 3. No queues of this type will be created
| Driver Version: 515.86.01 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| 0 | Quadro RTX 8000 | Yes: 0 | | 49398 MB | 10de | 0 |
| | | | | | 1e30 | 81ee6025.. |
| OS: Linux apollo1, Version: 5.4.0-135-generic
| Processor: Intel(R) Xeon(R) Gold 6252 CPU @ 2.10GHz | Cores: Unknown | Logical: 8
| Total Memory (MB): 1547825 | Free Memory: 1437562
| Total Page/Swap (MB): 0 | Free Page/Swap: 0
[1.546s] [ext: omni.kit.pipapi-0.0.0] startup
[1.551s] [ext: omni.kit.pip_archive-0.0.0] startup
[1.554s] [ext: omni.kit.loop-isaac-1.0.0] startup
[1.555s] [ext: omni.kit.async_engine-0.0.0] startup
[1.557s] [ext: omni.kit.test-0.0.0] startup
[1.584s] [ext: omni.usd.config-1.0.0] startup
[1.589s] [ext: omni.usd.libs-1.0.0] startup
[1.849s] [ext: omni.isaac.core_archive-2.0.1] startup
[1.860s] [ext: omni.pip.torch-1_13_1-0.1.4] startup
[1.862s] [ext: omni.isaac.ml_archive-1.1.0] startup
[1.862s] [ext: omni.client-0.1.1] startup
[1.876s] [ext: omni.appwindow-1.0.1] startup
2023-10-10 11:40:10 [1,865ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2023-10-10 11:40:10 [1,865ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.3]) (impl: carb.windowing-glfw.plugin)
[1.879s] [ext: omni.kit.renderer.core-0.0.0] startup
2023-10-10 11:40:10 [1,900ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2023-10-10 11:40:10 [1,900ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.3]) (impl: carb.windowing-glfw.plugin)
2023-10-10 11:40:10 [1,902ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2023-10-10 11:40:10 [1,902ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.3]) (impl: carb.windowing-glfw.plugin)
[1.919s] [ext: omni.kit.renderer.capture-0.0.0] startup
[1.921s] [ext: omni.kit.renderer.imgui-0.0.0] startup
2023-10-10 11:40:10 [1,912ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2023-10-10 11:40:10 [1,912ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.3]) (impl: carb.windowing-glfw.plugin)
2023-10-10 11:40:10 [1,913ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2023-10-10 11:40:10 [1,913ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.3]) (impl: carb.windowing-glfw.plugin)
[2.062s] [ext: carb.audio-0.1.0] startup
[2.071s] [ext: omni.ui-2.14.4] startup
[2.092s] [ext: omni.uiaudio-1.0.0] startup
[2.094s] [ext: omni.kit.mainwindow-1.0.0] startup
[2.096s] [ext: omni.kit.uiapp-0.0.0] startup
[2.096s] [ext: omni.usd.schema.physics-1.0.0] startup
[2.158s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[2.169s] [ext: omni.usd.schema.audio-0.0.0] startup
[2.178s] [ext: omni.usd.schema.anim-0.0.0] startup
[2.376s] [ext: omni.usd.schema.semantics-0.0.0] startup
[2.382s] [ext: omni.usd.schema.physx-0.0.0] startup
[2.427s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[2.439s] [ext: omni.usd.schema.omniscripting-1.0.0] startup
[2.450s] [ext: omni.kit.window.popup_dialog-2.0.16] startup
[2.458s] [ext: omni.kit.actions.core-1.0.0] startup
[2.461s] [ext: omni.kit.widget.nucleus_connector-1.0.3] startup
[2.465s] [ext: omni.kit.commands-1.4.5] startup
[2.470s] [ext: omni.gpucompute.plugins-0.0.0] startup
[2.471s] [ext: omni.usd.core-1.0.4] startup
[2.476s] [ext: omni.timeline-1.0.5] startup
[2.479s] [ext: omni.hydra.scene_delegate-0.3.0] startup
[2.488s] [ext: omni.kit.audiodeviceenum-1.0.0] startup
[2.490s] [ext: omni.hydra.usdrt_delegate-4.3.2] startup
[2.518s] [ext: omni.graph.tools-1.17.2] startup
[2.538s] [ext: omni.usd-1.6.30] startup
[2.608s] [ext: omni.kit.collaboration.channel_manager-1.0.9] startup
[2.610s] [ext: omni.kvdb-0.0.0] startup
[2.612s] [ext: omni.kit.usd.layers-2.0.11] startup
[2.625s] [ext: omni.kit.menu.utils-1.4.7] startup
[2.638s] [ext: omni.localcache-0.0.0] startup
[2.640s] [ext: omni.kit.primitive.mesh-1.0.8] startup
[2.645s] [ext: omni.convexdecomposition-104.2.4-5.1] startup
[2.648s] [ext: omni.kit.stage_templates-1.1.13] startup
[2.651s] [ext: omni.kit.usd_undo-0.1.2] startup
[2.652s] [ext: omni.graph.core-2.65.4] startup
[2.657s] [ext: omni.usdphysics-104.2.4-5.1] startup
[2.661s] [ext: omni.graph-1.50.2] startup
[2.738s] [ext: omni.physx-104.2.4-5.1] startup
2023-10-10 11:40:11 [2,751ms] [Warning] [omni.kvdb.plugin] wasn't able to load the meta database, trying to repair it ...
2023-10-10 11:40:11 [2,753ms] [Warning] [omni.kvdb.plugin] repair failed
[2.766s] [ext: omni.kit.numpy.common-0.1.0] startup
[2.769s] [ext: omni.graph.nodes-1.48.3] startup
[2.791s] [ext: omni.isaac.dynamic_control-1.2.3] startup
[2.807s] [ext: omni.isaac.kit-1.4.1] startup
[2.808s] [ext: omni.kit.widget.path_field-2.0.4] startup
[2.809s] [ext: omni.kit.search_core-1.0.2] startup
[2.810s] [ext: omni.kit.widget.browser_bar-2.0.5] startup
[2.812s] [ext: omni.kit.widget.filebrowser-2.3.10] startup
[2.827s] [ext: omni.kit.widget.versioning-1.3.8] startup
[2.830s] [ext: omni.kit.notification_manager-1.0.5] startup
[2.832s] [ext: omni.iray.libs-0.0.0] startup
[2.838s] [ext: omni.kit.window.filepicker-2.7.15] startup
[2.899s] [ext: omni.ui_query-1.1.1] startup
[2.901s] [ext: omni.mdl.neuraylib-0.1.0] startup
[2.904s] [ext: omni.kit.wiStarting kit application with the following args: ['/isaac-sim/exts/omni.isaac.kit/omni/isaac/kit/simulation_app.py', '/isaac-sim/apps/omni.isaac.sim.python.gym.headless.kit', '--/app/tokens/exe-path=/isaac-sim/kit', '--/persistent/app/viewport/displayOptions=3094', '--/rtx/materialDb/syncLoads=True', '--/rtx/hydra/materialSyncLoads=True--/omni.kit.plugin/syncUsdLoads=True', '--/app/renderer/resolution/width=1280', '--/app/renderer/resolution/height=720', '--/app/window/width=1440', '--/app/window/height=900', '--/renderer/multiGpu/enabled=True', '--/app/fastShutdown=True', '--ext-folder', '/isaac-sim/exts', '--ext-folder', '/isaac-sim/apps', '--/physics/cudaDevice=0', '--portable', '--no-window', '--allow-root']
Passing the following args to the base kit application: ['task=FrankaGoto', 'headless=True', 'seed=-1']
Warp 0.6.3 initialized:
CUDA Toolkit: 11.5, Driver: 11.7
Devices:
"cpu" | x86_64
"cuda:0" | Quadro RTX 8000 (sm_75)
Kernel cache: /root/.cache/warp/0.6.3
task:
physics_engine: physx
debug: False
env:
numEnvs: 4096
envSpacing: 3.0
episodeLength: 500
enableDebugVis: False
clipObservations: 5.0
clipActions: 1.0
controlFrequencyInv: 2
startPositionNoise: 0.0
startRotationNoise: 0.0
numProps: 4
aggregateMode: 3
successThreshold: 0.1
velocityRateThreshold: 1.0
accelerationRateThreshold: 1.0
jerkRateThreshold: 1.0
dofVelocityScale: 0.1
distRewardScale: 10.0
zeroTargetVelocityRewardScale: 0.0
zeroTargetAccelerationRewardScale: 0.0
collisionPenaltyScale: 0.0
actionPenaltyScale: 0.1
velocityPenaltyScale: 0.0
accelerationPenaltyScale: 0.0
jerkPenaltyScale: 0.0
actionSmoothnessPenaltyScale: 0.1
actionThresholdPenaltyScale: 0.0
frankaRandomizationScale: 0.25
neutralJointsPenaltyScale: 0.001
jointLimitRewardScale: 0.1
disturbCube: False
objectObservation: True
randomizeObject: False
eval:
goal_poses: [[-0.2, -0.45, 0.2], [-0.2, -0.45, 0.45], [-0.2, -0.45, 0.7], [-0.2, 0.45, 0.2], [-0.2, 0.45, 0.45], [-0.2, 0.45, 0.7], [0.2, -0.45, 0.2], [0.2, -0.45, 0.45], [0.2, -0.45, 0.7], [0.2, 0.0, 0.2], [0.2, 0.0, 0.45], [0.2, 0.0, 0.7], [0.2, 0.45, 0.2], [0.2, 0.45, 0.45], [0.2, 0.45, 0.7], [0.6, -0.45, 0.2], [0.6, -0.45, 0.45], [0.6, -0.45, 0.7], [0.6, 0.0, 0.2], [0.6, 0.0, 0.45], [0.6, 0.0, 0.7], [0.6, 0.45, 0.2], [0.6, 0.45, 0.45], [0.6, 0.45, 0.7]]
controlSpace:
rateLimiting: False
velocityRateLimit: [2.175, 2.175, 2.175, 2.175, 2.61, 2.61, 2.61]
accelerationRateLimit: [15.0, 7.5, 10.0, 12.5, 15.0, 20.0, 20.0]
jerkRateLimit: [7500.0, 3750.0, 5000.0, 6250.0, 7500.0, 10000.0, 10000.0]
velocityRateLimitScale: 1.0
accelerationRateLimitScale: 1.0
jerkRateLimitScale: 1.0
effectiveDofs: 7
targetFeedback: True
type: JointVel
jointPosActionScale: 40.0
jointVelActionScale: 60
cartPosActionScale: 45.0
cartVelActionScale: 150.0
mirroring: True
impedanceStiffness: [40.0, 40.0, 40.0, 40.0, 30.0, 20.0, 20.0]
controlOrientation: True
oneStepIntegration: False
orientationRepresentation: 6D
nullSpace: True
Kp: [1.5, 2.0, 2.5, 0.4, 0.4, 0.4]
J_reg: 0.001
J_w: [50.0, 50.0, 50.0, 10.0, 1.0, 1.0, 1.0]
restPose: [0, 0, 0, -1.55, 0, 1.9, 0]
nullGain: [1.2, 1.2, 1.2, 1.2, 0.5, 0.3, 0.1]
sim:
dt: 0.0083
use_gpu_pipeline: True
gravity: [0.0, 0.0, -9.81]
add_ground_plane: True
use_flatcache: True
enable_scene_query_support: False
enable_cameras: False
default_physics_material:
static_friction: 0.01
dynamic_friction: 0.01
restitution: 0.0
physx:
worker_thread_count: 4
solver_type: 1
use_gpu: True
solver_position_iteration_count: 12
solver_velocity_iteration_count: 1
contact_offset: 0.005
rest_offset: 0.0
bounce_threshold_velocity: 0.2
friction_offset_threshold: 0.04
friction_correlation_distance: 0.025
enable_sleeping: True
enable_stabilization: True
max_depenetration_velocity: 1000.0
gpu_max_rigid_contact_count: 524288
gpu_max_rigid_patch_count: 33554432
gpu_found_lost_pairs_capacity: 524288
gpu_found_lost_aggregate_pairs_capacity: 262144
gpu_total_aggregate_pairs_capacity: 1048576
gpu_max_soft_body_contacts: 1048576
gpu_max_particle_contacts: 1048576
gpu_heap_capacity: 33554432
gpu_temp_buffer_capacity: 16777216
gpu_max_num_partitions: 8
franka:
override_usd_defaults: False
fixed_base: False
enable_self_collisions: False
enable_gyroscopic_forces: True
sleep_threshold: 0.005
stabilization_threshold: 0.001
density: -1
rest_offset: 0.0
woodbox:
fixed_base: False
density: -1
rest_offset: 0.0
prop:
fixed_base: False
density: 100
rest_offset: 0.0
train:
params:
seed: 95
algo:
model:
network:
separate: False
space:
continuous:
mu_activation: None
sigma_activation: None
mu_init:
sigma_init:
val: -1
fixed_sigma: True
mlp:
units: [512, 256, 128, 64]
activation: elu
d2rl: False
initializer:
regularizer:
load_checkpoint: False
load_path:
config:
full_experiment_name: FrankaGoto-JointVel-95
env_name: rlgpu
device: cuda
device_name: cuda
ppo: True
mixed_precision: False
normalize_input: True
normalize_value: True
num_actors: 4096
reward_shaper:
scale_value: 1.0
normalize_advantage: True
gamma: 0.99
tau: 0.95
learning_rate: 0.0005
lr_schedule: adaptive
kl_threshold: 0.008
score_to_win: 100000000
max_epochs: 750
save_best_after: 100
save_frequency: 100
print_stats: True
grad_normndow.file_importer-1.0.10] startup
[2.906s] [ext: omni.kit.ui_test-1.2.9] startup
[2.911s] [ext: omni.mdl-0.1.0] startup
[2.949s] [ext: omni.kit.widget.zoombar-1.0.4] startup
[2.950s] [ext: omni.kit.widget.searchfield-1.0.10] startup
[2.952s] [ext: omni.kit.material.library-1.3.21] startup
[2.960s] [ext: omni.kit.browser.core-2.2.2] startup
[2.966s] [ext: omni.kit.window.file_exporter-1.0.10] startup
[2.968s] [ext: omni.physics.tensors-0.1.0] startup
[2.978s] [ext: omni.kit.browser.folder.core-1.7.3] startup
[2.984s] [ext: omni.kit.window.file-1.3.32] startup
[2.988s] [ext: omni.physx.tensors-0.1.0] startup
[3.003s] [ext: omni.isaac.version-1.0.0] startup
[3.004s] [ext: omni.kit.browser.sample-1.2.5] startup
[3.009s] [ext: omni.isaac.cloner-0.4.1] startup
[3.010s] [ext: omni.isaac.core-1.46.3] startup
[3.313s] [ext: omni.warp-0.6.3] startup
[3.670s] [ext: omni.kit.window.title-1.1.2] startup
2023-10-10 11:40:12 [3,660ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2023-10-10 11:40:12 [3,660ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.3]) (impl: carb.windowing-glfw.plugin)
2023-10-10 11:40:12 [3,662ms] [Warning] [carb] [Plugin: libomni.structuredlog.plugin.so] Module /isaac-sim/kit/libomni.structuredlog.plugin.so remained loaded after unload request
2023-10-10 11:40:12 [3,663ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2023-10-10 11:40:12 [3,663ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.3]) (impl: carb.windowing-glfw.plugin)
[3.676s] [ext: omni.isaac.gym-0.3.3] startup
[3.677s] [ext: omni.isaac.sim.python.gym.headless-2022.2.1] startup
[3.678s] Simulation App Starting
2023-10-10 11:40:12 [4,238ms] [Warning] [carb.audio.device] audio device is misconfigured or broken {deviceIndex = 0, name = 'default'} (The device is likely misconfigured, check your $HOME/.asoundrc)
2023-10-10 11:40:12 [4,238ms] [Warning] [carb.audio.output] failed to retrieve the capabilities for device 0 {result = eDeviceLost (2)}
2023-10-10 11:40:12 [4,238ms] [Warning] [carb.audio.context] failed to set the requested output during context creation. Using a null streamer instead {result = eDeviceLost (2)}
[4.286s] app ready
2023-10-10 11:40:12 [4,288ms] [Warning] [omni.kit.browser.folder.core.models.folder_browser_model] Do not load cache for Warp because url changed:
2023-10-10 11:40:12 [4,288ms] [Warning] [omni.kit.browser.folder.core.models.folder_browser_model] - from /isaac-sim/extscache/omni.warp-0.6.1+cp37/data/scenes
2023-10-10 11:40:12 [4,289ms] [Warning] [omni.kit.browser.folder.core.models.folder_browser_model] - to /isaac-sim/extscache/omni.warp-0.6.3+cp37/data/scenes
[4.311s] Simulation App Startup Complete
[4.352s] [ext: omni.inspect-1.0.1] startup
[4.364s] [ext: omni.kit.clipboard-1.0.0] startup
[4.370s] [ext: omni.kit.menu.create-1.0.8] startup
[4.383s] [ext: omni.volume-0.1.0] startup
[4.387s] [ext: omni.kit.context_menu-1.5.12] startup
[4.393s] [ext: omni.activity.core-1.0.1] startup
[4.397s] [ext: omni.hydra.rtx-0.1.0] startup
[4.406s] [ext: omni.debugdraw-0.1.1] startup
[4.414s] [ext: omni.kit.widget.stage-2.7.24] startup
[4.421s] [ext: omni.kit.window.property-1.8.2] startup
[4.424s] [ext: omni.kit.viewport.utility-1.0.14] startup
[4.426s] [ext: omni.kit.property.usd-3.18.17] startup
[4.438s] [ext: omni.kit.widget.text_editor-1.0.2] startup
[4.441s] [ext: omni.kit.widget.settings-1.0.1] startup
[4.443s] [ext: omni.kit.widget.graph-1.5.6-104_2] startup
[4.599s] [ext: omni.ui.scene-1.5.18] startup
[4.612s] [ext: omni.kit.window.preferences-1.3.8] startup
[4.686s] [ext: omni.kit.window.extensions-1.1.1] startup
[4.694s] [ext: omni.kit.widget.prompt-1.0.5] startup
[4.695s] [ext: omni.graph.ui-1.24.2] startup
[4.749s] [ext: omni.graph.scriptnode-0.10.0] startup
[4.753s] [ext: omni.graph.action-1.31.1] startup
[4.764s] [ext: omni.graph.bundle.action-1.3.0] startup
[4.765s] [ext: omni.syntheticdata-0.2.4] startup
2023-10-10 11:40:13 [4,769ms] [Warning] [omni.syntheticdata.scripts.extension] SyntheticData extension needs at least a stageFrameHistoryCount of 3
[4.788s] [ext: omni.command.usd-1.0.2] startup
[4.790s] [ext: omni.replicator.core-1.7.8] startup
2023-10-10 11:40:13 [4,806ms] [Warning] [omni.replicator.core.scripts.annotators] Annotator PostProcessDispatch is already registered, overwriting annotator template
[4.897s] [ext: omni.replicator.isaac-1.7.4] startup
2023-10-10 11:40:15 [7,042ms] [Warning] [omni.isaac.core.utils.viewports] could not get active viewport, cannot set camera view
2023-10-10 11:40:17 [8,858ms] [Warning] [omni.client.plugin] Tick: authentication: Discovery(ws://localhost:3333): Error creating Api/Connection search: Not connected
2023-10-10 11:40:17 [8,861ms] [Warning] [omni.isaac.core.utils.nucleus] /persistent/app/omniverse/mountedDrives setting not found
2023-10-10 11:40:17 [8,861ms] [Warning] [omni.client.plugin] HTTP Client: provider_http: CC-493: Request through cache failed. Retrying without cache for http://omniverse-content-production.s3-us-west-2.amazonaws.com/.cloudfront.toml
2023-10-10 11:40:17 [8,861ms] [Warning] [omni.client.plugin] HTTP Client: omniclient: CC-873: Bypassing cache until the application is restarted
2023-10-10 11:40:17 [9,271ms] [Warning] [omni.client.plugin] HTTP Client: provider_http: CC-493: Request through cache failed. Retrying without cache for http://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/Isaac/2022.2.1/
: 1.0
entropy_coef: 0.01
truncate_grads: True
e_clip: 0.2
horizon_length: 64
minibatch_size: 16384
mini_epochs: 4
critic_coef: 4
clip_value: True
seq_len: 4
bounds_loss_coef: 0.0001
task_name: FrankaGoto
experiment:
num_envs:
eval_group:
offline_data_file:
eval_experiment:
seed: 95
torch_deterministic: False
max_iterations:
pipeline: gpu
sim_device: gpu
device_id: 0
rl_device: cuda
debug: False
num_threads: 4
solver_type: 1
test: False
checkpoint:
headless: True
enable_livestream: False
mt_timeout: 30
wandb_activate: False
wandb_group:
wandb_name: FrankaGoto-JointVel-95
wandb_entity:
wandb_project: asimov-gym
Setting seed: 95
Sim params does not have attribute: physx
Sim params does not have attribute: franka
Sim params does not have attribute: woodbox
Sim params does not have attribute: prop
Pipeline: GPU
Pipeline Device: cuda:0
Sim Device: GPU
Task Device: cuda:0
RL device: cuda
Setting up scene
Actor params does not have attribute: fixed_base
Scene set up
Setting up init_data
init_data set up
Resetting envs tensor([ 0, 1, 2, ..., 4093, 4094, 4095], device='cuda:0')
bangbang_rate nan
smoothness_index nan
Success rate 0.00 based on 4096 episodes
best success rate 0.00
self.seed = 95
Started to train
Exact experiment name requested from command line: FrankaGoto-JointVel-95
Box(-1.0, 1.0, (7,), float32) Box(-inf, inf, (20,), float32)
current training device: cuda
build mlp: 20
RunningMeanStd: (1,)
RunningMeanStd: (20,)
[2023-10-10 11:41:15] Running RL reset
bangbang_rate nan
Success rate 0.00 based on 8192 episodes
saving next success rate: 0.0
=> saving checkpoint 'runs/FrankaGoto-JointVel-95/nn/FrankaGoto-JointVel-95-success.pth'
There was an error running python
stderr
/isaac-sim/kit/python/lib/python3.7/site-packages/hydra/_internal/defaults_list.py:251: UserWarning: In 'config': Defaults list is missing `_self_`. See https://hydra.cc/docs/upgrades/1.0_to_1.1/default_composition_order for more information
warnings.warn(msg, UserWarning)
/isaac-sim/kit/python/lib/python3.7/site-packages/hydra/_internal/defaults_list.py:412: UserWarning: In config: Invalid overriding of hydra/job_logging:
Default list overrides requires 'override' keyword.
See https://hydra.cc/docs/next/upgrades/1.0_to_1.1/defaults_list_override for more information.
deprecation_warning(msg)
2023-10-10 11:41:15 [67,306ms] [Error] [omni.physx.tensors.plugin] CUDA error: an illegal memory access was encountered: ../../../source/extensions/omni.physx.tensors/plugins/gpu/GpuArticulationView.cpp: 947
/isaac-sim/kit/exts/omni.graph/omni/graph/core/_impl/autonode/type_definitions.py:12: DeprecationWarning: `np.float` is a deprecated alias for the builtin `float`. To silence this warning, use `float` by itself. Doing this will not modify any behavior and is safe. If you specifically wanted the numpy scalar type, use `np.float64` here.
Deprecated in NumPy 1.20; for more details and guidance: https://numpy.org/devdocs/release/1.20.0-notes.html#deprecations
Float = NewType("Float", np.float)
/isaac-sim/kit/kernel/py/omni/kit/app/_impl/__init__.py:104: DeprecationWarning: Using or importing the ABCs from 'collections' instead of from 'collections.abc' is deprecated since Python 3.3,and in 3.9 it will stop working
if not isinstance(setting_py, str) and isinstance(setting_py, collections.Sequence):
/isaac-sim/kit/python/lib/python3.7/site-packages/gym/spaces/box.py:84: UserWarning: e[33mWARN: Box bound precision lowered by casting to float32e[0m
logger.warn(f"Box bound precision lowered by casting to {self.dtype}")
/src/asimov_gym/tasks/asimov_task.py:152: RuntimeWarning: invalid value encountered in double_scalars
self._num_actions * len(self.bangbang_history) * self._num_envs
/isaac-sim/kit/extscore/omni.kit.pip_archive/pip_prebundle/numpy/core/fromnumeric.py:3441: RuntimeWarning: Mean of empty slice.
out=out, **kwargs)
/isaac-sim/kit/extscore/omni.kit.pip_archive/pip_prebundle/numpy/core/_methods.py:189: RuntimeWarning: invalid value encountered in double_scalars
ret = ret.dtype.type(ret / rcount)
Error executing job with overrides: ['task=FrankaGoto', 'headless=True', 'seed=-1']
File "./scripts/rlgames_train.py", line 149, in parse_hydra_configs
rlg_trainer.run()
File "./scripts/rlgames_train.py", line 64, in run
"sigma": None,
File "/isaac-sim/kit/python/lib/python3.7/site-packages/rl_games/torch_runner.py", line 120, in run
self.run_train(args)
File "/isaac-sim/kit/python/lib/python3.7/site-packages/rl_games/torch_runner.py", line 101, in run_train
agent.train()
File "/isaac-sim/kit/python/lib/python3.7/site-packages/rl_games/common/a2c_common.py", line 1162, in train
self.obs = self.env_reset()
File "/isaac-sim/kit/python/lib/python3.7/site-packages/rl_games/common/a2c_common.py", line 470, in env_reset
obs = self.vec_env.reset()
File "/omni-isaac-gym-envs/omniisaacgymenvs/utils/rlgames/rlgames_utils.py", line 102, in reset
return self.env.reset()
File "/src/asimov_gym/envs/vec_env_rlgames.py", line 50, in reset
obs_dict, _, _, _ = self._reset_step()
File "/src/asimov_gym/envs/vec_env_rlgames.py", line 27, in _reset_step
) = self._task.post_physics_step()
File "/omni-isaac-gym-envs/omniisaacgymenvs/tasks/base/rl_task.py", line 254, in post_physics_step
self.get_observations()
File "/src/asimov_gym/tasks/franka_tasks/franka_goto.py", line 134, in get_observations
self.franka_jac = self._frankas.get_jacobians()
File "/isaac-sim/exts/omni.isaac.core/omni/isaac/core/articulations/articulation_view.py", line 2088, in get_jacobians
result = self._backend_utils.clone_tensor(result, device=self._device)
File "/isaac-sim/exts/omni.isaac.core/omni/isaac/core/utils/torch/tensor.py", line 36, in clone_tensor
return torch.clone(data)
RuntimeError: CUDA error: an illegal memory access was encountered
CUDA kernel errors might be asynchronously reported at some other API call,so the stacktrace below might be incorrect.
For debugging consider passing CUDA_LAUNCH_BLOCKING=1.
Set the environment variable HYDRA_FULL_ERROR=1 for a complete stack trace.
/isaac-sim/python.sh: line 41: 639124 Segmentation fault (core dumped) $python_exe "$@" $args
When launched with CUDA_LAUNCH_BLOCKING=1 the stderr becomes:
2023-10-10 11:52:10 [71,928ms] [Error] [omni.physx.tensors.plugin] CUDA error: an illegal memory access was encountered: ../../../source/extensions/omni.physx.tensors/plugins/gpu/GpuArticulationView.cpp: 936
2023-10-10 11:52:10 [71,928ms] [Error] [omni.physx.tensors.plugin] CUDA error: an illegal memory access was encountered: ../../../source/extensions/omni.physx.tensors/plugins/gpu/GpuArticulationView.cpp: 942
out=out, **kwargs)
rlg_trainer.run()
"sigma": None,
agent.train()
File "/isaac-sim/exts/omni.isaac.core/omni/isaac/core/articulations/articulation_view.py", line 2084, in get_jacobians
current_values = self._physics_view.get_jacobians()
File "/isaac-sim/kit/extsPhysics/omni.physics.tensors-104.2.4-5.1/omni/physics/tensors/impl/api.py", line 534, in get_jacobians
raise Exception("Failed to get Jacobians from backend")
Exception: Failed to get Jacobians from backend
/isaac-sim/python.sh: line 41: 651441 Segmentation fault (core dumped) $python_exe "$@" $args
