I am trying to create multiple cameras, each publishing to different ROS topics, with the Python API. Specifically, I am calling:
def create_camera(self, args=None):
print("Executing CreatePrimWithDefaultXform")
status, _ = omni.kit.commands.execute(
"CreatePrimWithDefaultXform",
prim_type="Camera",
prim_path="/sim_camera",
attributes={
"focusDistance": 400,
"focalLength": 24
print("Complete: " + str(status))
self.viewport.set_active_camera("/sim_camera")
# Set Camera Pose
print("Executing TransformPrimCommand")
status, _ = omni.kit.commands.execute("TransformPrimCommand",
path="/sim_camera",
new_transform_matrix=Gf.Matrix4d(
-0.642788,
0.766045,
0.0,
0.0,
-0.133022,
-0.111619,
0.984807,
0.0,
0.754407,
0.633022,
0.173648,
0.0,
175.0,
150.0,
70.0,
1.0,
# adding camera topic
print("Executing ROSBridgeCreateCamera")
status, prim = omni.kit.commands.execute(
"ROSBridgeCreateCamera",
path="/ROS_Camera",
enabled=True,
resolution=Gf.Vec2i(1280, 720),
frame_id="sim_camera",
camera_info_topic="/camera_info",
rgb_enabled=True,
rgb_topic="/rgb",
depth_enabled=True,
depth_topic="/depth",
segmentation_enabled=False,
semantic_topic="/semantic",
instance_topic="/instance",
label_topic="/label",
bbox2d_enabled=False,
bbox2d_topic="/bbox_2d",
bbox3d_enabled=False,
bbox3d_topic="/bbox_3d",
queue_size=10,
camera_prim_rel=["/sim_camera"],
def create_camera2(self, args=None):
prim_type="Camera",
prim_path="/sim_camera_2",
attributes={
"focalLength": 24
self.viewport.set_active_camera("/sim_camera_2")
# Set Camera Pose
-0.642788,
0.766045,
0.0,
0.0,
-0.133022,
-0.111619,
0.984807,
0.0,
0.754407,
0.633022,
0.173648,
0.0,
-175.0,
-150.0,
70.0,
1.0,
path="/ROS_Camera_2",
enabled=True,
frame_id="sim_camera_2",
camera_info_topic="/camera_info_2",
rgb_enabled=True,
rgb_topic="/rgb_2",
depth_enabled=True,
depth_topic="/depth_2",
queue_size=10,
camera_prim_rel=["/sim_camera_2"],
Where create_camera2
is the exact same as create_camera
, I just changed the names of the ROS topics, prim paths, etc, as well as where the camera is located. I copied this code structure from rostopics.py
When I call these functions one after another, it creates both pairs of topics (/rgb, /rgb_2, /depth, /depth_2). Two viewport panels are also opened, one for each camera. However, data is only being published to the second topic.
If I only call one of the functions, then data is successfully published to just that camera’s corresponding topics, meaning I think both sets of code are correctly written.
Is there some way to get multi-camera ROS support working with the Python API?
