Multiple UVC USB Camera with Gstreamer
I try to use 4 USB3 camera with Jetson NX. But I cannot get it work with the 4th camera.
The camera are connected with a USB3 hub, and here is the output of lsusb -t
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=tegra-xusb/4p, 10000M
    |__ Port 3: Dev 2, If 0, Class=Hub, Driver=hub/4p, 5000M
        |__ Port 1: Dev 3, If 0, Class=Hub, Driver=hub/4p, 5000M
            |__ Port 1: Dev 5, If 2, Class=Human Interface Device, Driver=usbhid, 5000M
            |__ Port 1: Dev 5, If 0, Class=Video, Driver=uvcvideo, 5000M
            |__ Port 1: Dev 5, If 1, Class=Video, Driver=uvcvideo, 5000M
            |__ Port 2: Dev 6, If 1, Class=Video, Driver=uvcvideo, 5000M
            |__ Port 2: Dev 6, If 2, Class=Human Interface Device, Driver=usbhid, 5000M
            |__ Port 2: Dev 6, If 0, Class=Video, Driver=uvcvideo, 5000M
            |__ Port 3: Dev 7, If 0, Class=Video, Driver=uvcvideo, 5000M
            |__ Port 3: Dev 7, If 1, Class=Video, Driver=uvcvideo, 5000M
            |__ Port 3: Dev 7, If 2, Class=Human Interface Device, Driver=usbhid, 5000M
            |__ Port 4: Dev 8, If 2, Class=Human Interface Device, Driver=usbhid, 5000M
            |__ Port 4: Dev 8, If 0, Class=Video, Driver=uvcvideo, 5000M
            |__ Port 4: Dev 8, If 1, Class=Video, Driver=uvcvideo, 5000M
4 camera are same model, here is the output of v4l2-ctl --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
	Type: Video Capture
	[0]: 'YUYV' (YUYV 4:2:2)
		Size: Discrete 1920x1080
			Interval: Discrete 0.017s (60.000 fps)
		Size: Discrete 1280x1024
		Size: Discrete 1600x1200
			Interval: Discrete 0.040s (25.000 fps)
		Size: Discrete 2048x1536
		Size: Discrete 2560x1440
		Size: Discrete 2592x1944
	[1]: 'MJPG' (Motion-JPEG, compressed)
			Interval: Discrete 0.033s (30.000 fps)
And here is the command and output of gstreamer:
gst-launch-1.0 v4l2src device=/dev/video0 \
    ! "video/x-raw,width=(int)640,height=(int)480,framerate=(fraction)60/1,format=(string)YUY2" \
    ! nvvidconv \
    ! nvv4l2h265enc insert-sps-pps=true bitrate=800000 \
    ! rtph265pay pt=96 mtu=1280 config-interval=1 \
    ! udpsink host=192.168.1.100 port=5000 sync=false
Opening in BLOCKING MODE
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Redistribute latency...
NvMMLiteOpen : Block : BlockType = 8
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 8
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Failed to allocate required memory.
Additional debug info:
gstv4l2src.c(658): gst_v4l2src_decide_allocation (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
Buffer pool activation failed
Execution ended after 0:00:00.261292017
Setting pipeline to PAUSED ...
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
Would you have any advice to solve this problem?
Thank you.
Ambrose
Looks like the 4 cameras are enumerated as superspeed. In this case, the 4 cameras share 5Gbps. So you can launch 3 cameras in 640x480p successfully and cannot launch the 4th camera?
Thank you.
Yes, I can launch 3 cameras in 640x480 with 60fps. But the 4th failed to launch.
Ambrose
It looks like each camera requests for > 1.25Gbps bandwidth so that the fourth camera doesn’t get enough bandwidth. You may check UVC driver and add debug prints to show the requested bandwidth of the cameras.
I try to found out more from the UVC camera as below:
Enable all uvcvideo module traces:
echo 0xffff > /sys/module/uvcvideo/parameters/trace
And here is the output of dmesg when the camera connect to Jetson.
[  232.974202] usb 2-3.2: new SuperSpeed USB device number 11 using tegra-xusb
[  233.140227] usb 2-3.2: New USB device found, idVendor=0bda, idProduct=3038
[  233.140238] usb 2-3.2: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[  233.140244] usb 2-3.2: Product: LRCP USB3.0
                                              U
[  233.140250] usb 2-3.2: Manufacturer: Generic
[  233.140256] usb 2-3.2: SerialNumber: 200901010001
[  233.173125] uvcvideo: Probing generic UVC device 3.2
[  233.173144] uvcvideo: Found format YUV 4:2:2 (YUYV).
[  233.173150] uvcvideo: - 1920x1080 (60.0 fps)
[  233.173155] uvcvideo: - 640x480 (60.0 fps)
[  233.173160] uvcvideo: - 800x600 (60.0 fps)
[  233.173164] uvcvideo: - 1024x768 (60.0 fps)
[  233.173169] uvcvideo: - 1280x720 (60.0 fps)
[  233.173173] uvcvideo: - 1280x1024 (60.0 fps)
[  233.173178] uvcvideo: - 1600x1200 (25.0 fps)
[  233.173182] uvcvideo: - 2048x1536 (25.0 fps)
[  233.173186] uvcvideo: - 2560x1440 (25.0 fps)
[  233.173191] uvcvideo: - 2592x1944 (25.0 fps)
[  233.173195] uvcvideo: Found format MJPEG.
[  233.173200] uvcvideo: - 1920x1080 (60.0 fps)
[  233.173204] uvcvideo: - 640x480 (30.0 fps)
[  233.173209] uvcvideo: - 800x600 (60.0 fps)
[  233.173242] uvcvideo: - 1024x768 (60.0 fps)
[  233.173248] uvcvideo: - 1280x720 (60.0 fps)
[  233.173253] uvcvideo: - 1280x1024 (30.0 fps)
[  233.173258] uvcvideo: - 1600x1200 (25.0 fps)
[  233.173262] uvcvideo: - 2048x1536 (25.0 fps)
[  233.173267] uvcvideo: - 2560x1440 (25.0 fps)
[  233.173272] uvcvideo: - 2592x1944 (25.0 fps)
[  233.173289] uvcvideo: Found a Status endpoint (addr 83).
[  233.173294] uvcvideo: Found UVC 1.00 device LRCP USB3.0
                                                          U (0bda:3038)
[  233.173311] uvcvideo: Added control 00000000-0000-0000-0000-000000000001/2 to device 3.2 entity 1
[  233.173320] uvcvideo: Adding mapping 'Exposure, Auto' to control 00000000-0000-0000-0000-000000000001/2.
[  233.173327] uvcvideo: Added control 00000000-0000-0000-0000-000000000001/3 to device 3.2 entity 1
[  233.173336] uvcvideo: Adding mapping 'Exposure, Auto Priority' to control 00000000-0000-0000-0000-000000000001/3.
[  233.173370] uvcvideo: Added control 00000000-0000-0000-0000-000000000001/4 to device 3.2 entity 1
[  233.173376] uvcvideo: Adding mapping 'Exposure (Absolute)' to control 00000000-0000-0000-0000-000000000001/4.
[  233.173384] uvcvideo: Added control 00000000-0000-0000-0000-000000000001/6 to device 3.2 entity 1
[  233.173391] uvcvideo: Adding mapping 'Focus (absolute)' to control 00000000-0000-0000-0000-000000000001/6.
[  233.173399] uvcvideo: Added control 00000000-0000-0000-0000-000000000001/15 to device 3.2 entity 1
[  233.173406] uvcvideo: Added control 00000000-0000-0000-0000-000000000001/8 to device 3.2 entity 1
[  233.173413] uvcvideo: Adding mapping 'Focus, Auto' to control 00000000-0000-0000-0000-000000000001/8.
[  233.173421] uvcvideo: Added control 00000000-0000-0000-0000-000000000101/2 to device 3.2 entity 2
[  233.173568] uvcvideo: Adding mapping 'Brightness' to control 00000000-0000-0000-0000-000000000101/2.
[  233.173578] uvcvideo: Added control 00000000-0000-0000-0000-000000000101/3 to device 3.2 entity 2
[  233.173584] uvcvideo: Adding mapping 'Contrast' to control 00000000-0000-0000-0000-000000000101/3.
[  233.173592] uvcvideo: Added control 00000000-0000-0000-0000-000000000101/6 to device 3.2 entity 2
[  233.173598] uvcvideo: Adding mapping 'Hue' to control 00000000-0000-0000-0000-000000000101/6.
[  233.173634] uvcvideo: Added control 00000000-0000-0000-0000-000000000101/7 to device 3.2 entity 2
[  233.173644] uvcvideo: Adding mapping 'Saturation' to control 00000000-0000-0000-0000-000000000101/7.
[  233.173651] uvcvideo: Added control 00000000-0000-0000-0000-000000000101/8 to device 3.2 entity 2
[  233.173664] uvcvideo: Adding mapping 'Sharpness' to control 00000000-0000-0000-0000-000000000101/8.
[  233.173672] uvcvideo: Added control 00000000-0000-0000-0000-000000000101/9 to device 3.2 entity 2
[  233.173678] uvcvideo: Adding mapping 'Gamma' to control 00000000-0000-0000-0000-000000000101/9.
[  233.173686] uvcvideo: Added control 00000000-0000-0000-0000-000000000101/10 to device 3.2 entity 2
[  233.173693] uvcvideo: Adding mapping 'White Balance Temperature' to control 00000000-0000-0000-0000-000000000101/10.
[  233.173699] uvcvideo: Added control 00000000-0000-0000-0000-000000000101/1 to device 3.2 entity 2
[  233.173706] uvcvideo: Adding mapping 'Backlight Compensation' to control 00000000-0000-0000-0000-000000000101/1.
[  233.173739] uvcvideo: Added control 00000000-0000-0000-0000-000000000101/4 to device 3.2 entity 2
[  233.173745] uvcvideo: Adding mapping 'Gain' to control 00000000-0000-0000-0000-000000000101/4.
[  233.173752] uvcvideo: Added control 00000000-0000-0000-0000-000000000101/5 to device 3.2 entity 2
[  233.173759] uvcvideo: Adding mapping 'Power Line Frequency' to control 00000000-0000-0000-0000-000000000101/5.
[  233.173766] uvcvideo: Added control 00000000-0000-0000-0000-000000000101/11 to device 3.2 entity 2
[  233.173773] uvcvideo: Adding mapping 'White Balance Temperature, Auto' to control 00000000-0000-0000-0000-000000000101/11.
[  233.173782] uvcvideo: Scanning UVC chain:
[  233.173788]  OT 3
[  233.173793]  <- XU 4
[  233.173797]  <- PU 2
[  233.173801]  <- IT 1
[  233.173807] uvcvideo: Found a valid video chain (1 -> 3).
[  233.400677] uvcvideo 2-3.2:1.0: Entity type for entity Extension 4 was not initialized!
[  233.400859] uvcvideo 2-3.2:1.0: Entity type for entity Processing 2 was not initialized!
[  233.401022] uvcvideo 2-3.2:1.0: Entity type for entity Camera 1 was not initialized!
[  233.401613] input: LRCP USB3.0
                                 U as /devices/3610000.xhci/usb2/2-3/2-3.2/2-3.2:1.0/input/input11
[  233.402475] uvcvideo: UVC device initialized.
[  233.406628] tegra-asoc: sound: ASoC: CODEC DAI nau8822-hifi not registered
[  233.406825] tegra-asoc: sound: snd_soc_register_card failed (-517)
[  233.410411] hid-generic 0003:0BDA:3038.0007: hidraw0: USB HID v1.11 Device [Generic LRCP USB3.0
        U] on usb-3610000.xhci-3.2/input2
[  233.413672] tegra-asoc: sound: ASoC: CODEC DAI nau8822-hifi not registered
[  233.413925] tegra-asoc: sound: snd_soc_register_card failed (-517)
[  233.462337] uvcvideo: uvc_v4l2_open
[  233.462555] uvcvideo: uvc_v4l2_release
[  236.209464] uvcvideo: Suspending interface 1
[  236.209477] uvcvideo: Suspending interface 0
[  236.229489] usb 2-3.2: usb_suspend_both: status 0
And here is the output of dmesg while the GStreamer running:
[  707.725689] uvcvideo: uvc_v4l2_open
[  707.875535] uvcvideo: Resuming interface 0
[  707.875545] uvcvideo: Resuming interface 1
[  707.876077] uvcvideo: uvc_v4l2_release
[  707.876606] uvcvideo: uvc_v4l2_open
[  707.947834] uvcvideo: Resuming interface 0
[  707.947840] uvcvideo: Resuming interface 1
[  707.948234] uvcvideo: uvc_v4l2_release
[  707.948831] uvcvideo: uvc_v4l2_open
[  708.023266] uvcvideo: Resuming interface 0
[  708.023274] uvcvideo: Resuming interface 1
[  708.023688] uvcvideo: uvc_v4l2_release
[  708.024222] uvcvideo: uvc_v4l2_open
[  708.094749] uvcvideo: Resuming interface 0
[  708.094757] uvcvideo: Resuming interface 1
[  708.094857] uvcvideo: uvc_v4l2_release
[  708.221798] uvcvideo: uvc_v4l2_open
[  708.224452] uvcvideo: Trying format 0x56595559 (YUYV): 640x480.
[  708.224461] uvcvideo: Using default frame interval 16666.6 us (60.0 fps).
[  708.239301] uvcvideo: Setting frame interval to 1/60 (166666).
[  708.253996] uvcvideo: Control 0x00980927 not found.
[  708.259285] uvcvideo: Control 0x00980927 not found.
[  708.262288] uvcvideo: Device requested 32768 B/frame bandwidth.
[  708.262298] uvcvideo: Selecting alternate setting 11 (32768 B/frame bandwidth).
[  708.269011] uvcvideo: Allocated 5 URB buffers of 19x32768 bytes each.
[  708.269143] uvcvideo: uvc_v4l2_poll
[  708.271481] uvcvideo: Marking buffer as bad (error bit set).
[  708.271486] uvcvideo: Marking buffer as bad (error bit set).
[  708.271488] uvcvideo: Marking buffer as bad (error bit set).
[  708.271489] uvcvideo: Marking buffer as bad (error bit set).
[  708.271491] uvcvideo: Marking buffer as bad (error bit set).
[  708.271492] uvcvideo: Marking buffer as bad (error bit set).
[  708.271496] uvcvideo: Marking buffer as bad (error bit set).
[  708.271497] uvcvideo: Marking buffer as bad (error bit set).
[  708.271499] uvcvideo: Marking buffer as bad (error bit set).
[  708.271500] uvcvideo: Marking buffer as bad (error bit set).
[  708.271501] uvcvideo: Marking buffer as bad (error bit set).
[  708.271502] uvcvideo: Marking buffer as bad (error bit set).
[  708.271504] uvcvideo: Marking buffer as bad (error bit set).
[  708.271505] uvcvideo: Marking buffer as bad (error bit set).
[  708.271509] uvcvideo: Marking buffer as bad (error bit set).
[  708.271510] uvcvideo: Marking buffer as bad (error bit set).
[  708.271511] uvcvideo: Marking buffer as bad (error bit set).
[  708.271513] uvcvideo: Marking buffer as bad (error bit set).
[  708.271514] uvcvideo: Marking buffer as bad (error bit set).
[  708.273853] uvcvideo: Marking buffer as bad (error bit set).
[  708.273856] uvcvideo: Marking buffer as bad (error bit set).
[  708.273858] uvcvideo: Marking buffer as bad (error bit set).
[  708.273862] uvcvideo: Marking buffer as bad (error bit set).
[  708.273863] uvcvideo: Marking buffer as bad (error bit set).
[  708.273864] uvcvideo: Marking buffer as bad (error bit set).
[  708.273866] uvcvideo: Marking buffer as bad (error bit set).
[  708.273867] uvcvideo: Marking buffer as bad (error bit set).
[  708.273868] uvcvideo: Marking buffer as bad (error bit set).
[  708.273869] uvcvideo: Marking buffer as bad (error bit set).
[  708.273870] uvcvideo: Marking buffer as bad (error bit set).
[  708.273873] uvcvideo: Marking buffer as bad (error bit set).
[  708.273875] uvcvideo: Marking buffer as bad (error bit set).
[  708.273876] uvcvideo: Marking buffer as bad (error bit set).
[  708.273877] uvcvideo: Marking buffer as bad (error bit set).
[  708.273878] uvcvideo: Marking buffer as bad (error bit set).
[  708.273880] uvcvideo: Marking buffer as bad (error bit set).
[  708.273881] uvcvideo: Marking buffer as bad (error bit set).
[  708.273882] uvcvideo: Marking buffer as bad (error bit set).
[  708.276229] uvcvideo: Marking buffer as bad (error bit set).
[  708.276233] uvcvideo: Marking buffer as bad (error bit set).
[  708.276235] uvcvideo: Marking buffer as bad (error bit set).
[  708.276236] uvcvideo: Marking buffer as bad (error bit set).
[  708.276237] uvcvideo: Marking buffer as bad (error bit set).
[  708.276238] uvcvideo: Marking buffer as bad (error bit set).
[  708.276240] uvcvideo: Marking buffer as bad (error bit set).
[  708.276241] uvcvideo: Marking buffer as bad (error bit set).
[  708.276244] uvcvideo: Marking buffer as bad (error bit set).
[  708.276245] uvcvideo: Marking buffer as bad (error bit set).
[  708.276247] uvcvideo: Marking buffer as bad (error bit set).
[  708.276248] uvcvideo: Marking buffer as bad (error bit set).
[  708.276249] uvcvideo: Marking buffer as bad (error bit set).
[  708.276250] uvcvideo: Marking buffer as bad (error bit set).
[  708.276252] uvcvideo: Marking buffer as bad (error bit set).
[  708.276253] uvcvideo: Marking buffer as bad (error bit set).
[  708.276256] uvcvideo: Marking buffer as bad (error bit set).
[  708.276257] uvcvideo: Marking buffer as bad (error bit set).
[  708.276258] uvcvideo: Marking buffer as bad (error bit set).
[  708.278600] uvcvideo: Marking buffer as bad (error bit set).
[  708.278608] uvcvideo: Marking buffer as bad (error bit set).
[  708.278610] uvcvideo: Marking buffer as bad (error bit set).
[  708.278611] uvcvideo: Marking buffer as bad (error bit set).
[  708.278613] uvcvideo: Marking buffer as bad (error bit set).
[  708.278617] uvcvideo: Marking buffer as bad (error bit set).
[  708.278619] uvcvideo: Marking buffer as bad (error bit set).
[  708.278621] uvcvideo: Marking buffer as bad (error bit set).
[  708.278622] uvcvideo: Marking buffer as bad (error bit set).
[  708.278624] uvcvideo: Marking buffer as bad (error bit set).
[  708.278625] uvcvideo: Marking buffer as bad (error bit set).
[  708.278626] uvcvideo: Marking buffer as bad (error bit set).
[  708.278628] uvcvideo: Marking buffer as bad (error bit set).
[  708.278631] uvcvideo: Marking buffer as bad (error bit set).
[  708.278632] uvcvideo: Marking buffer as bad (error bit set).
[  708.278634] uvcvideo: Marking buffer as bad (error bit set).
[  708.278635] uvcvideo: Marking buffer as bad (error bit set).
[  708.278636] uvcvideo: Marking buffer as bad (error bit set).
[  708.278638] uvcvideo: Marking buffer as bad (error bit set).
[  708.280997] uvcvideo: Marking buffer as bad (error bit set).
[  708.281002] uvcvideo: Marking buffer as bad (error bit set).
[  708.281006] uvcvideo: Marking buffer as bad (error bit set).
[  708.281007] uvcvideo: Marking buffer as bad (error bit set).
[  708.281009] uvcvideo: Marking buffer as bad (error bit set).
[  708.281010] uvcvideo: Marking buffer as bad (error bit set).
[  708.281012] uvcvideo: Marking buffer as bad (error bit set).
[  708.281014] uvcvideo: Marking buffer as bad (error bit set).
[  708.281015] uvcvideo: Marking buffer as bad (error bit set).
[  708.281017] uvcvideo: Marking buffer as bad (error bit set).
[  708.281019] uvcvideo: Marking buffer as bad (error bit set).
[  708.281021] uvcvideo: Marking buffer as bad (error bit set).
[  708.281022] uvcvideo: Marking buffer as bad (error bit set).
[  708.281024] uvcvideo: Marking buffer as bad (error bit set).
[  708.281025] uvcvideo: Marking buffer as bad (error bit set).
[  708.281027] uvcvideo: Marking buffer as bad (error bit set).
[  708.281028] uvcvideo: Marking buffer as bad (error bit set).
[  708.281029] uvcvideo: Marking buffer as bad (error bit set).
[  708.281032] uvcvideo: Marking buffer as bad (error bit set).
[  708.283348] uvcvideo: Marking buffer as bad (error bit set).
[  708.283355] uvcvideo: Marking buffer as bad (error bit set).
[  708.283358] uvcvideo: Marking buffer as bad (error bit set).
[  708.283359] uvcvideo: Marking buffer as bad (error bit set).
[  708.283360] uvcvideo: Marking buffer as bad (error bit set).
[  708.283362] uvcvideo: Marking buffer as bad (error bit set).
[  708.283363] uvcvideo: Marking buffer as bad (error bit set).
[  708.283366] uvcvideo: Marking buffer as bad (error bit set).
[  708.283367] uvcvideo: Marking buffer as bad (error bit set).
[  708.283369] uvcvideo: Marking buffer as bad (error bit set).
[  708.283370] uvcvideo: Marking buffer as bad (error bit set).
[  708.283372] uvcvideo: Marking buffer as bad (error bit set).
[  708.283373] uvcvideo: Marking buffer as bad (error bit set).
[  708.283374] uvcvideo: Marking buffer as bad (error bit set).
[  708.283376] uvcvideo: Marking buffer as bad (error bit set).
[  708.283378] uvcvideo: Marking buffer as bad (error bit set).
[  708.283379] uvcvideo: Marking buffer as bad (error bit set).
[  708.283380] uvcvideo: Marking buffer as bad (error bit set).
[  708.283382] uvcvideo: Marking buffer as bad (error bit set).
[  708.285728] uvcvideo: Marking buffer as bad (error bit set).
[  708.285732] uvcvideo: Marking buffer as bad (error bit set).
[  708.285733] uvcvideo: Marking buffer as bad (error bit set).
[  708.285734] uvcvideo: Marking buffer as bad (error bit set).
[  708.285737] uvcvideo: Marking buffer as bad (error bit set).
[  708.285738] uvcvideo: Marking buffer as bad (error bit set).
[  708.285740] uvcvideo: Marking buffer as bad (error bit set).
[  708.285741] uvcvideo: Marking buffer as bad (error bit set).
[  708.285743] uvcvideo: Marking buffer as bad (error bit set).
[  708.285744] uvcvideo: Marking buffer as bad (error bit set).
[  708.285745] uvcvideo: Marking buffer as bad (error bit set).
[  708.285747] uvcvideo: Marking buffer as bad (error bit set).
[  708.285749] uvcvideo: Marking buffer as bad (error bit set).
[  708.285750] uvcvideo: Marking buffer as bad (error bit set).
[  708.285752] uvcvideo: Marking buffer as bad (error bit set).
[  708.285753] uvcvideo: Marking buffer as bad (error bit set).
[  708.285754] uvcvideo: Marking buffer as bad (error bit set).
[  708.285755] uvcvideo: Marking buffer as bad (error bit set).
[  708.285757] uvcvideo: Marking buffer as bad (error bit set).
[  708.288099] uvcvideo: Marking buffer as bad (error bit set).
[  708.288105] uvcvideo: Marking buffer as bad (error bit set).
[  708.288107] uvcvideo: Marking buffer as bad (error bit set).
[  708.288108] uvcvideo: Marking buffer as bad (error bit set).
[  708.288110] uvcvideo: Marking buffer as bad (error bit set).
[  708.288111] uvcvideo: Marking buffer as bad (error bit set).
[  708.288113] uvcvideo: Marking buffer as bad (error bit set).
[  708.288114] uvcvideo: Marking buffer as bad (error bit set).
[  708.288115] uvcvideo: Marking buffer as bad (error bit set).
[  708.288118] uvcvideo: Marking buffer as bad (error bit set).
[  708.288119] uvcvideo: Marking buffer as bad (error bit set).
[  708.288120] uvcvideo: Marking buffer as bad (error bit set).
[  708.288122] uvcvideo: Marking buffer as bad (error bit set).
[  708.288123] uvcvideo: Marking buffer as bad (error bit set).
[  708.288124] uvcvideo: Marking buffer as bad (error bit set).
[  708.288125] uvcvideo: Marking buffer as bad (error bit set).
[  708.288127] uvcvideo: Marking buffer as bad (error bit set).
[  708.288129] uvcvideo: Marking buffer as bad (error bit set).
[  708.288130] uvcvideo: Marking buffer as bad (error bit set).
[  708.290475] uvcvideo: Marking buffer as bad (error bit set).
[  708.290480] uvcvideo: Marking buffer as bad (error bit set).
[  708.290481] uvcvideo: Marking buffer as bad (error bit set).
[  708.290483] uvcvideo: Marking buffer as bad (error bit set).
[  708.290485] uvcvideo: Marking buffer as bad (error bit set).
[  708.290486] uvcvideo: Marking buffer as bad (error bit set).
[  708.290489] uvcvideo: Marking buffer as bad (error bit set).
[  708.290490] uvcvideo: Marking buffer as bad (error bit set).
[  708.290491] uvcvideo: Marking buffer as bad (error bit set).
[  708.290493] uvcvideo: Marking buffer as bad (error bit set).
[  708.290494] uvcvideo: Marking buffer as bad (error bit set).
[  708.290495] uvcvideo: Marking buffer as bad (error bit set).
[  708.290496] uvcvideo: Marking buffer as bad (error bit set).
[  708.290498] uvcvideo: Marking buffer as bad (error bit set).
[  708.290500] uvcvideo: Marking buffer as bad (error bit set).
[  708.290501] uvcvideo: Marking buffer as bad (error bit set).
[  708.290502] uvcvideo: Marking buffer as bad (error bit set).
[  708.290504] uvcvideo: Marking buffer as bad (error bit set).
[  708.290505] uvcvideo: Marking buffer as bad (error bit set).
[  708.292849] uvcvideo: Marking buffer as bad (error bit set).
[  708.292853] uvcvideo: Marking buffer as bad (error bit set).
[  708.292855] uvcvideo: Marking buffer as bad (error bit set).
[  708.292857] uvcvideo: Marking buffer as bad (error bit set).
[  708.292859] uvcvideo: Marking buffer as bad (error bit set).
[  708.292860] uvcvideo: Marking buffer as bad (error bit set).
[  708.292862] uvcvideo: Marking buffer as bad (error bit set).
[  708.292863] uvcvideo: Marking buffer as bad (error bit set).
[  708.292864] uvcvideo: Marking buffer as bad (error bit set).
[  708.292865] uvcvideo: Marking buffer as bad (error bit set).
[  708.292867] uvcvideo: Marking buffer as bad (error bit set).
[  708.292869] uvcvideo: Marking buffer as bad (error bit set).
[  708.292870] uvcvideo: Marking buffer as bad (error bit set).
[  708.292872] uvcvideo: Marking buffer as bad (error bit set).
[  708.292873] uvcvideo: Marking buffer as bad (error bit set).
[  708.292874] uvcvideo: Marking buffer as bad (error bit set).
[  708.292876] uvcvideo: Marking buffer as bad (error bit set).
[  708.292877] uvcvideo: Marking buffer as bad (error bit set).
[  708.292878] uvcvideo: Marking buffer as bad (error bit set).
[  708.295229] uvcvideo: Marking buffer as bad (error bit set).
[  708.295234] uvcvideo: Marking buffer as bad (error bit set).
[  708.295235] uvcvideo: Marking buffer as bad (error bit set).
[  708.295238] uvcvideo: Marking buffer as bad (error bit set).
[  708.295240] uvcvideo: Marking buffer as bad (error bit set).
[  708.295241] uvcvideo: Marking buffer as bad (error bit set).
[  708.295242] uvcvideo: Marking buffer as bad (error bit set).
[  708.295244] uvcvideo: Marking buffer as bad (error bit set).
[  708.295247] uvcvideo: Marking buffer as bad (error bit set).
[  708.295248] uvcvideo: Marking buffer as bad (error bit set).
[  708.295250] uvcvideo: Marking buffer as bad (error bit set).
[  708.295251] uvcvideo: Marking buffer as bad (error bit set).
[  708.295252] uvcvideo: Marking buffer as bad (error bit set).
[  708.295254] uvcvideo: Marking buffer as bad (error bit set).
[  708.295255] uvcvideo: Marking buffer as bad (error bit set).
[  708.295257] uvcvideo: Marking buffer as bad (error bit set).
[  708.295259] uvcvideo: Marking buffer as bad (error bit set).
[  708.295260] uvcvideo: Marking buffer as bad (error bit set).
[  708.295262] uvcvideo: Marking buffer as bad (error bit set).
[  708.297602] uvcvideo: Marking buffer as bad (error bit set).
[  708.297608] uvcvideo: Marking buffer as bad (error bit set).
[  708.297610] uvcvideo: Marking buffer as bad (error bit set).
[  708.297611] uvcvideo: Marking buffer as bad (error bit set).
[  708.297613] uvcvideo: Marking buffer as bad (error bit set).
[  708.297616] uvcvideo: Marking buffer as bad (error bit set).
[  708.297617] uvcvideo: Marking buffer as bad (error bit set).
[  708.297619] uvcvideo: Marking buffer as bad (error bit set).
[  708.297620] uvcvideo: Marking buffer as bad (error bit set).
[  708.297622] uvcvideo: Marking buffer as bad (error bit set).
[  708.297623] uvcvideo: Marking buffer as bad (error bit set).
[  708.297625] uvcvideo: Marking buffer as bad (error bit set).
[  708.297626] uvcvideo: Marking buffer as bad (error bit set).
[  708.297629] uvcvideo: Marking buffer as bad (error bit set).
[  708.297630] uvcvideo: Marking buffer as bad (error bit set).
[  708.297631] uvcvideo: Marking buffer as bad (error bit set).
[  708.297633] uvcvideo: Marking buffer as bad (error bit set).
[  708.297634] uvcvideo: Marking buffer as bad (error bit set).
[  708.297636] uvcvideo: Marking buffer as bad (error bit set).
[  708.299977] uvcvideo: Marking buffer as bad (error bit set).
[  708.299982] uvcvideo: Marking buffer as bad (error bit set).
[  708.299986] uvcvideo: Marking buffer as bad (error bit set).
[  708.299987] uvcvideo: Marking buffer as bad (error bit set).
[  708.299988] uvcvideo: Marking buffer as bad (error bit set).
[  708.299990] uvcvideo: Marking buffer as bad (error bit set).
[  708.299991] uvcvideo: Marking buffer as bad (error bit set).
[  708.299993] uvcvideo: Marking buffer as bad (error bit set).
[  708.299994] uvcvideo: Marking buffer as bad (error bit set).
[  708.299995] uvcvideo: Marking buffer as bad (error bit set).
[  708.299998] uvcvideo: Marking buffer as bad (error bit set).
[  708.299999] uvcvideo: Marking buffer as bad (error bit set).
[  708.300000] uvcvideo: Marking buffer as bad (error bit set).
[  708.300002] uvcvideo: Marking buffer as bad (error bit set).
[  708.300003] uvcvideo: Marking buffer as bad (error bit set).
[  708.300004] uvcvideo: Marking buffer as bad (error bit set).
[  708.300006] uvcvideo: Marking buffer as bad (error bit set).
[  708.300007] uvcvideo: Marking buffer as bad (error bit set).
[  708.300009] uvcvideo: Marking buffer as bad (error bit set).
[  708.302350] uvcvideo: Marking buffer as bad (error bit set).
[  708.302355] uvcvideo: Marking buffer as bad (error bit set).
[  708.302357] uvcvideo: Marking buffer as bad (error bit set).
[  708.302358] uvcvideo: Marking buffer as bad (error bit set).
[  708.302360] uvcvideo: Marking buffer as bad (error bit set).
[  708.302361] uvcvideo: Marking buffer as bad (error bit set).
[  708.302363] uvcvideo: Marking buffer as bad (error bit set).
[  708.302366] uvcvideo: Marking buffer as bad (error bit set).
[  708.302367] uvcvideo: Marking buffer as bad (error bit set).
[  708.302369] uvcvideo: Marking buffer as bad (error bit set).
[  708.302370] uvcvideo: Marking buffer as bad (error bit set).
[  708.302371] uvcvideo: Marking buffer as bad (error bit set).
[  708.302373] uvcvideo: Marking buffer as bad (error bit set).
[  708.302374] uvcvideo: Marking buffer as bad (error bit set).
[  708.302375] uvcvideo: Marking buffer as bad (error bit set).
[  708.302378] uvcvideo: Marking buffer as bad (error bit set).
[  708.302379] uvcvideo: Marking buffer as bad (error bit set).
[  708.302380] uvcvideo: Marking buffer as bad (error bit set).
[  708.302381] uvcvideo: Marking buffer as bad (error bit set).
[  708.304724] uvcvideo: Marking buffer as bad (error bit set).
[  708.304730] uvcvideo: Marking buffer as bad (error bit set).
[  708.304731] uvcvideo: Marking buffer as bad (error bit set).
[  708.304733] uvcvideo: Marking buffer as bad (error bit set).
[  708.304735] uvcvideo: Marking buffer as bad (error bit set).
[  708.304737] uvcvideo: Marking buffer as bad (error bit set).
[  708.304738] uvcvideo: Marking buffer as bad (error bit set).
[  708.304739] uvcvideo: Marking buffer as bad (error bit set).
[  708.304741] uvcvideo: Marking buffer as bad (error bit set).
[  708.304742] uvcvideo: Marking buffer as bad (error bit set).
[  708.304743] uvcvideo: Marking buffer as bad (error bit set).
[  708.304745] uvcvideo: Marking buffer as bad (error bit set).
[  708.304747] uvcvideo: Marking buffer as bad (error bit set).
[  708.304748] uvcvideo: Marking buffer as bad (error bit set).
[  708.304749] uvcvideo: Marking buffer as bad (error bit set).
[  708.304751] uvcvideo: Marking buffer as bad (error bit set).
[  708.304752] uvcvideo: Marking buffer as bad (error bit set).
[  708.304753] uvcvideo: Marking buffer as bad (error bit set).
[  708.304755] uvcvideo: Marking buffer as bad (error bit set).
[  708.307104] uvcvideo: Marking buffer as bad (error bit set).
[  708.307110] uvcvideo: Marking buffer as bad (error bit set).
[  708.307113] uvcvideo: Marking buffer as bad (error bit set).
[  708.307114] uvcvideo: Marking buffer as bad (error bit set).
[  708.307115] uvcvideo: Marking buffer as bad (error bit set).
[  708.307117] uvcvideo: Marking buffer as bad (error bit set).
[  708.307118] uvcvideo: Marking buffer as bad (error bit set).
[  708.307120] uvcvideo: Marking buffer as bad (error bit set).
[  708.307121] uvcvideo: Marking buffer as bad (error bit set).
[  708.307136] uvcvideo: Marking buffer as bad (error bit set).
[  708.307137] uvcvideo: Marking buffer as bad (error bit set).
[  708.307138] uvcvideo: Marking buffer as bad (error bit set).
[  708.307140] uvcvideo: Marking buffer as bad (error bit set).
[  708.307141] uvcvideo: Marking buffer as bad (error bit set).
[  708.307142] uvcvideo: Marking buffer as bad (error bit set).
[  708.307144] uvcvideo: Marking buffer as bad (error bit set).
[  708.307145] uvcvideo: Marking buffer as bad (error bit set).
[  708.307147] uvcvideo: Marking buffer as bad (error bit set).
[  708.307148] uvcvideo: Marking buffer as bad (error bit set).
[  708.309473] uvcvideo: Marking buffer as bad (error bit set).
[  708.309479] uvcvideo: Marking buffer as bad (error bit set).
[  708.309481] uvcvideo: Marking buffer as bad (error bit set).
[  708.309483] uvcvideo: Marking buffer as bad (error bit set).
[  708.309484] uvcvideo: Marking buffer as bad (error bit set).
[  708.309486] uvcvideo: Marking buffer as bad (error bit set).
[  708.309489] uvcvideo: Marking buffer as bad (error bit set).
[  708.309491] uvcvideo: Marking buffer as bad (error bit set).
[  708.309493] uvcvideo: Marking buffer as bad (error bit set).
[  708.309494] uvcvideo: Marking buffer as bad (error bit set).
[  708.309496] uvcvideo: Marking buffer as bad (error bit set).
[  708.309497] uvcvideo: Marking buffer as bad (error bit set).
[  708.309499] uvcvideo: Marking buffer as bad (error bit set).
[  708.309500] uvcvideo: Marking buffer as bad (error bit set).
[  708.309503] uvcvideo: Marking buffer as bad (error bit set).
[  708.309505] uvcvideo: Marking buffer as bad (error bit set).
[  708.309506] uvcvideo: Marking buffer as bad (error bit set).
[  708.309508] uvcvideo: Marking buffer as bad (error bit set).
[  708.309509] uvcvideo: Marking buffer as bad (error bit set).
[  708.311851] uvcvideo: Marking buffer as bad (error bit set).
[  708.311855] uvcvideo: Marking buffer as bad (error bit set).
[  708.311856] uvcvideo: Marking buffer as bad (error bit set).
[  708.311859] uvcvideo: Marking buffer as bad (error bit set).
[  708.311860] uvcvideo: Marking buffer as bad (error bit set).
[  708.311862] uvcvideo: Marking buffer as bad (error bit set).
[  708.311863] uvcvideo: Marking buffer as bad (error bit set).
[  708.311865] uvcvideo: Marking buffer as bad (error bit set).
[  708.311866] uvcvideo: Marking buffer as bad (error bit set).
[  708.311867] uvcvideo: Marking buffer as bad (error bit set).
[  708.311869] uvcvideo: Marking buffer as bad (error bit set).
[  708.311871] uvcvideo: Marking buffer as bad (error bit set).
[  708.311872] uvcvideo: Marking buffer as bad (error bit set).
[  708.311873] uvcvideo: Marking buffer as bad (error bit set).
[  708.311875] uvcvideo: Marking buffer as bad (error bit set).
[  708.311876] uvcvideo: Marking buffer as bad (error bit set).
[  708.311877] uvcvideo: Marking buffer as bad (error bit set).
[  708.311879] uvcvideo: Marking buffer as bad (error bit set).
[  708.311880] uvcvideo: Marking buffer as bad (error bit set).
[  708.314224] uvcvideo: Marking buffer as bad (error bit set).
[  708.314228] uvcvideo: Marking buffer as bad (error bit set).
[  708.314230] uvcvideo: Marking buffer as bad (error bit set).
[  708.314231] uvcvideo: Marking buffer as bad (error bit set).
[  708.314233] uvcvideo: Marking buffer as bad (error bit set).
[  708.314234] uvcvideo: Marking buffer as bad (error bit set).
[  708.314236] uvcvideo: Marking buffer as bad (error bit set).
[  708.314237] uvcvideo: Marking buffer as bad (error bit set).
[  708.314240] uvcvideo: Marking buffer as bad (error bit set).
[  708.314241] uvcvideo: Marking buffer as bad (error bit set).
[  708.314242] uvcvideo: Marking buffer as bad (error bit set).
[  708.314243] uvcvideo: Marking buffer as bad (error bit set).
[  708.314245] uvcvideo: Marking buffer as bad (error bit set).
[  708.314246] uvcvideo: Marking buffer as bad (error bit set).
[  708.314248] uvcvideo: Marking buffer as bad (error bit set).
[  708.314249] uvcvideo: Marking buffer as bad (error bit set).
[  708.314251] uvcvideo: Marking buffer as bad (error bit set).
[  708.314252] uvcvideo: Marking buffer as bad (error bit set).
[  708.314254] uvcvideo: Marking buffer as bad (error bit set).
[  708.316599] uvcvideo: Marking buffer as bad (error bit set).
[  708.316604] uvcvideo: Marking buffer as bad (error bit set).
[  708.316605] uvcvideo: Marking buffer as bad (error bit set).
[  708.316606] uvcvideo: Marking buffer as bad (error bit set).
[  708.316608] uvcvideo: Marking buffer as bad (error bit set).
[  708.316610] uvcvideo: Marking buffer as bad (error bit set).
[  708.316612] uvcvideo: Marking buffer as bad (error bit set).
[  708.316613] uvcvideo: Marking buffer as bad (error bit set).
[  708.316615] uvcvideo: Marking buffer as bad (error bit set).
[  708.316616] uvcvideo: Marking buffer as bad (error bit set).
[  708.316618] uvcvideo: Marking buffer as bad (error bit set).
[  708.316619] uvcvideo: Marking buffer as bad (error bit set).
[  708.316620] uvcvideo: Marking buffer as bad (error bit set).
[  708.316623] uvcvideo: Marking buffer as bad (error bit set).
[  708.316624] uvcvideo: Marking buffer as bad (error bit set).
[  708.316625] uvcvideo: Marking buffer as bad (error bit set).
[  708.316627] uvcvideo: Marking buffer as bad (error bit set).
[  708.316628] uvcvideo: Marking buffer as bad (error bit set).
[  708.316629] uvcvideo: Marking buffer as bad (error bit set).
[  708.318975] uvcvideo: Marking buffer as bad (error bit set).
[  708.318980] uvcvideo: Marking buffer as bad (error bit set).
[  708.318982] uvcvideo: Marking buffer as bad (error bit set).
[  708.318984] uvcvideo: Marking buffer as bad (error bit set).
[  708.318985] uvcvideo: Marking buffer as bad (error bit set).
[  708.318986] uvcvideo: Marking buffer as bad (error bit set).
[  708.318987] uvcvideo: Marking buffer as bad (error bit set).
[  708.318989] uvcvideo: Marking buffer as bad (error bit set).
[  708.318990] uvcvideo: Marking buffer as bad (error bit set).
[  708.318992] uvcvideo: Marking buffer as bad (error bit set).
[  708.318994] uvcvideo: Marking buffer as bad (error bit set).
[  708.318995] uvcvideo: Marking buffer as bad (error bit set).
[  708.318996] uvcvideo: Marking buffer as bad (error bit set).
[  708.318998] uvcvideo: Marking buffer as bad (error bit set).
[  708.318999] uvcvideo: Marking buffer as bad (error bit set).
[  708.319000] uvcvideo: Marking buffer as bad (error bit set).
[  708.319001] uvcvideo: Marking buffer as bad (error bit set).
[  708.319003] uvcvideo: Marking buffer as bad (error bit set).
[  708.319005] uvcvideo: Marking buffer as bad (error bit set).
[  708.321350] uvcvideo: Marking buffer as bad (error bit set).
[  708.321354] uvcvideo: Marking buffer as bad (error bit set).
[  708.321355] uvcvideo: Marking buffer as bad (error bit set).
[  708.321357] uvcvideo: Marking buffer as bad (error bit set).
[  708.321358] uvcvideo: Marking buffer as bad (error bit set).
[  708.321359] uvcvideo: Marking buffer as bad (error bit set).
[  708.321361] uvcvideo: Marking buffer as bad (error bit set).
[  708.321363] uvcvideo: Marking buffer as bad (error bit set).
[  708.321365] uvcvideo: Marking buffer as bad (error bit set).
[  708.321366] uvcvideo: Marking buffer as bad (error bit set).
[  708.321367] uvcvideo: Marking buffer as bad (error bit set).
[  708.321368] uvcvideo: Marking buffer as bad (error bit set).
[  708.321370] uvcvideo: Marking buffer as bad (error bit set).
[  708.321371] uvcvideo: Marking buffer as bad (error bit set).
[  708.321372] uvcvideo: Marking buffer as bad (error bit set).
[  708.321375] uvcvideo: Marking buffer as bad (error bit set).
[  708.321376] uvcvideo: Marking buffer as bad (error bit set).
[  708.321377] uvcvideo: Marking buffer as bad (error bit set).
[  708.321378] uvcvideo: Marking buffer as bad (error bit set).
[  708.323725] uvcvideo: Marking buffer as bad (error bit set).
[  708.323728] uvcvideo: Marking buffer as bad (error bit set).
[  708.323730] uvcvideo: Marking buffer as bad (error bit set).
[  708.323732] uvcvideo: Marking buffer as bad (error bit set).
[  708.323734] uvcvideo: Marking buffer as bad (error bit set).
[  708.323736] uvcvideo: Marking buffer as bad (error bit set).
[  708.323737] uvcvideo: Marking buffer as bad (error bit set).
[  708.323738] uvcvideo: Marking buffer as bad (error bit set).
[  708.323740] uvcvideo: Marking buffer as bad (error bit set).
[  708.323741] uvcvideo: Marking buffer as bad (error bit set).
[  708.323743] uvcvideo: Marking buffer as bad (error bit set).
[  708.323744] uvcvideo: Marking buffer as bad (error bit set).
[  708.323746] uvcvideo: Marking buffer as bad (error bit set).
[  708.323748] uvcvideo: Marking buffer as bad (error bit set).
[  708.323749] uvcvideo: Marking buffer as bad (error bit set).
[  708.323750] uvcvideo: Marking buffer as bad (error bit set).
[  708.323752] uvcvideo: Marking buffer as bad (error bit set).
[  708.323753] uvcvideo: Marking buffer as bad (error bit set).
[  708.323754] uvcvideo: Marking buffer as bad (error bit set).
[  708.326101] uvcvideo: Marking buffer as bad (error bit set).
[  708.326109] uvcvideo: Marking buffer as bad (error bit set).
[  708.326111] uvcvideo: Marking buffer as bad (error bit set).
[  708.326113] uvcvideo: Marking buffer as bad (error bit set).
[  708.326114] uvcvideo: Marking buffer as bad (error bit set).
[  708.326116] uvcvideo: Marking buffer as bad (error bit set).
[  708.326117] uvcvideo: Marking buffer as bad (error bit set).
[  708.326119] uvcvideo: Marking buffer as bad (error bit set).
[  708.326120] uvcvideo: Marking buffer as bad (error bit set).
[  708.326123] uvcvideo: Marking buffer as bad (error bit set).
[  708.326125] uvcvideo: Marking buffer as bad (error bit set).
[  708.326129] uvcvideo: Marking buffer as bad (error bit set).
[  708.326134] uvcvideo: Marking buffer as bad (error bit set).
[  708.326135] uvcvideo: Marking buffer as bad (error bit set).
[  708.326137] uvcvideo: Marking buffer as bad (error bit set).
[  708.326138] uvcvideo: Marking buffer as bad (error bit set).
[  708.326140] uvcvideo: Marking buffer as bad (error bit set).
[  708.326143] uvcvideo: Marking buffer as bad (error bit set).
[  708.326144] uvcvideo: Marking buffer as bad (error bit set).
[  708.328476] uvcvideo: Marking buffer as bad (error bit set).
[  708.328480] uvcvideo: Marking buffer as bad (error bit set).
[  708.328482] uvcvideo: Marking buffer as bad (error bit set).
[  708.328483] uvcvideo: Marking buffer as bad (error bit set).
[  708.328484] uvcvideo: Marking buffer as bad (error bit set).
[  708.328486] uvcvideo: Marking buffer as bad (error bit set).
[  708.328488] uvcvideo: Marking buffer as bad (error bit set).
[  708.328490] uvcvideo: Marking buffer as bad (error bit set).
[  708.328491] uvcvideo: Marking buffer as bad (error bit set).
[  708.328493] uvcvideo: Marking buffer as bad (error bit set).
[  708.328494] uvcvideo: Marking buffer as bad (error bit set).
[  708.328495] uvcvideo: Marking buffer as bad (error bit set).
[  708.328496] uvcvideo: Marking buffer as bad (error bit set).
[  708.328498] uvcvideo: Marking buffer as bad (error bit set).
[  708.328500] uvcvideo: Marking buffer as bad (error bit set).
[  708.328501] uvcvideo: Marking buffer as bad (error bit set).
[  708.328503] uvcvideo: Marking buffer as bad (error bit set).
[  708.328504] uvcvideo: Marking buffer as bad (error bit set).
[  708.328505] uvcvideo: Marking buffer as bad (error bit set).
[  708.330850] uvcvideo: Marking buffer as bad (error bit set).
[  708.330853] uvcvideo: Marking buffer as bad (error bit set).
[  708.330855] uvcvideo: Marking buffer as bad (error bit set).
[  708.330857] uvcvideo: Marking buffer as bad (error bit set).
[  708.330860] uvcvideo: Marking buffer as bad (error bit set).
[  708.330861] uvcvideo: Marking buffer as bad (error bit set).
[  708.330862] uvcvideo: Marking buffer as bad (error bit set).
[  708.330864] uvcvideo: Marking buffer as bad (error bit set).
[  708.330865] uvcvideo: Marking buffer as bad (error bit set).
[  708.330866] uvcvideo: Marking buffer as bad (error bit set).
[  708.330868] uvcvideo: Marking buffer as bad (error bit set).
[  708.330870] uvcvideo: Marking buffer as bad (error bit set).
[  708.330871] uvcvideo: Marking buffer as bad (error bit set).
[  708.330873] uvcvideo: Marking buffer as bad (error bit set).
[  708.330874] uvcvideo: Marking buffer as bad (error bit set).
[  708.330875] uvcvideo: Marking buffer as bad (error bit set).
[  708.330876] uvcvideo: Marking buffer as bad (error bit set).
[  708.330878] uvcvideo: Marking buffer as bad (error bit set).
[  708.330879] uvcvideo: Marking buffer as bad (error bit set).
[  708.333226] uvcvideo: Marking buffer as bad (error bit set).
[  708.333230] uvcvideo: Marking buffer as bad (error bit set).
[  708.333231] uvcvideo: Marking buffer as bad (error bit set).
[  708.333233] uvcvideo: Marking buffer as bad (error bit set).
[  708.333234] uvcvideo: Marking buffer as bad (error bit set).
[  708.333236] uvcvideo: Marking buffer as bad (error bit set).
[  708.333237] uvcvideo: Marking buffer as bad (error bit set).
[  708.333238] uvcvideo: Marking buffer as bad (error bit set).
[  708.333240] uvcvideo: Marking buffer as bad (error bit set).
[  708.333242] uvcvideo: Marking buffer as bad (error bit set).
[  708.333243] uvcvideo: Marking buffer as bad (error bit set).
[  708.333244] uvcvideo: Marking buffer as bad (error bit set).
[  708.333246] uvcvideo: Marking buffer as bad (error bit set).
[  708.333247] uvcvideo: Marking buffer as bad (error bit set).
[  708.333248] uvcvideo: Marking buffer as bad (error bit set).
[  708.333250] uvcvideo: Marking buffer as bad (error bit set).
[  708.333252] uvcvideo: Marking buffer as bad (error bit set).
[  708.333253] uvcvideo: Marking buffer as bad (error bit set).
[  708.333255] uvcvideo: Marking buffer as bad (error bit set).
[  708.335601] uvcvideo: Marking buffer as bad (error bit set).
[  708.335605] uvcvideo: Marking buffer as bad (error bit set).
[  708.335606] uvcvideo: Marking buffer as bad (error bit set).
[  708.335608] uvcvideo: Marking buffer as bad (error bit set).
[  708.335609] uvcvideo: Marking buffer as bad (error bit set).
[  708.335612] uvcvideo: Marking buffer as bad (error bit set).
[  708.335613] uvcvideo: Marking buffer as bad (error bit set).
[  708.335615] uvcvideo: Marking buffer as bad (error bit set).
[  708.335616] uvcvideo: Marking buffer as bad (error bit set).
[  708.335617] uvcvideo: Marking buffer as bad (error bit set).
[  708.335619] uvcvideo: Marking buffer as bad (error bit set).
[  708.335620] uvcvideo: Marking buffer as bad (error bit set).
[  708.335621] uvcvideo: Marking buffer as bad (error bit set).
[  708.335623] uvcvideo: Marking buffer as bad (error bit set).
[  708.335625] uvcvideo: Marking buffer as bad (error bit set).
[  708.335626] uvcvideo: Marking buffer as bad (error bit set).
[  708.335627] uvcvideo: Marking buffer as bad (error bit set).
[  708.335629] uvcvideo: Marking buffer as bad (error bit set).
[  708.335630] uvcvideo: Marking buffer as bad (error bit set).
[  708.337976] uvcvideo: Marking buffer as bad (error bit set).
[  708.337980] uvcvideo: Marking buffer as bad (error bit set).
[  708.337988] uvcvideo: Marking buffer as bad (error bit set).
[  708.337995] uvcvideo: Marking buffer as bad (error bit set).
[  708.337997] uvcvideo: Marking buffer as bad (error bit set).
[  708.337998] uvcvideo: Marking buffer as bad (error bit set).
[  708.338000] uvcvideo: Marking buffer as bad (error bit set).
[  708.338002] uvcvideo: Marking buffer as bad (error bit set).
[  708.338003] uvcvideo: Marking buffer as bad (error bit set).
[  708.338005] uvcvideo: Marking buffer as bad (error bit set).
[  708.338008] uvcvideo: Marking buffer as bad (error bit set).
[  708.338009] uvcvideo: Marking buffer as bad (error bit set).
[  708.338011] uvcvideo: Marking buffer as bad (error bit set).
[  708.338012] uvcvideo: Marking buffer as bad (error bit set).
[  708.338016] uvcvideo: Marking buffer as bad (error bit set).
[  708.338018] uvcvideo: Marking buffer as bad (error bit set).
[  708.338019] uvcvideo: Marking buffer as bad (error bit set).
[  708.338021] uvcvideo: Marking buffer as bad (error bit set).
[  708.338028] uvcvideo: Marking buffer as bad (error bit set).
[  708.340352] uvcvideo: Marking buffer as bad (error bit set).
[  708.340355] uvcvideo: Marking buffer as bad (error bit set).
[  708.340357] uvcvideo: Marking buffer as bad (error bit set).
[  708.340358] uvcvideo: Marking buffer as bad (error bit set).
[  708.340360] uvcvideo: Marking buffer as bad (error bit set).
[  708.340372] uvcvideo: Marking buffer as bad (error bit set).
[  708.340374] uvcvideo: Marking buffer as bad (error bit set).
[  708.340377] uvcvideo: Marking buffer as bad (error bit set).
[  708.340378] uvcvideo: Marking buffer as bad (error bit set).
[  708.340379] uvcvideo: Marking buffer as bad (error bit set).
[  708.340380] uvcvideo: Marking buffer as bad (error bit set).
[  708.340382] uvcvideo: Marking buffer as bad (error bit set).
[  708.340383] uvcvideo: Marking buffer as bad (error bit set).
[  708.340384] uvcvideo: Marking buffer as bad (error bit set).
[  708.340386] uvcvideo: Marking buffer as bad (error bit set).
[  708.340388] uvcvideo: Marking buffer as bad (error bit set).
[  708.340389] uvcvideo: Marking buffer as bad (error bit set).
[  708.340391] uvcvideo: Marking buffer as bad (error bit set).
[  708.340392] uvcvideo: Marking buffer as bad (error bit set).
[  708.342727] uvcvideo: Marking buffer as bad (error bit set).
[  708.342731] uvcvideo: Marking buffer as bad (error bit set).
[  708.342733] uvcvideo: Marking buffer as bad (error bit set).
[  708.342734] uvcvideo: Marking buffer as bad (error bit set).
[  708.342737] uvcvideo: Marking buffer as bad (error bit set).
[  708.342738] uvcvideo: Marking buffer as bad (error bit set).
[  708.342740] uvcvideo: Marking buffer as bad (error bit set).
[  708.342741] uvcvideo: Marking buffer as bad (error bit set).
[  708.342743] uvcvideo: Marking buffer as bad (error bit set).
[  708.342744] uvcvideo: Marking buffer as bad (error bit set).
[  708.342745] uvcvideo: Marking buffer as bad (error bit set).
[  708.342746] uvcvideo: Marking buffer as bad (error bit set).
[  708.342749] uvcvideo: Marking buffer as bad (error bit set).
[  708.342750] uvcvideo: Marking buffer as bad (error bit set).
[  708.342751] uvcvideo: Marking buffer as bad (error bit set).
[  708.342753] uvcvideo: Marking buffer as bad (error bit set).
[  708.342754] uvcvideo: Marking buffer as bad (error bit set).
[  708.342755] uvcvideo: Marking buffer as bad (error bit set).
[  708.342756] uvcvideo: Marking buffer as bad (error bit set).
[  708.345099] uvcvideo: Marking buffer as bad (error bit set).
[  708.345104] uvcvideo: Marking buffer as bad (error bit set).
[  708.345105] uvcvideo: Marking buffer as bad (error bit set).
[  708.345108] uvcvideo: Marking buffer as bad (error bit set).
[  708.345109] uvcvideo: Marking buffer as bad (error bit set).
[  708.345111] uvcvideo: Marking buffer as bad (error bit set).
[  708.345112] uvcvideo: Marking buffer as bad (error bit set).
[  708.345113] uvcvideo: Marking buffer as bad (error bit set).
[  708.345115] uvcvideo: Marking buffer as bad (error bit set).
[  708.345117] uvcvideo: Marking buffer as bad (error bit set).
[  708.345118] uvcvideo: Marking buffer as bad (error bit set).
[  708.345120] uvcvideo: Marking buffer as bad (error bit set).
[  708.345121] uvcvideo: Marking buffer as bad (error bit set).
[  708.345122] uvcvideo: Marking buffer as bad (error bit set).
[  708.345123] uvcvideo: Marking buffer as bad (error bit set).
[  708.345125] uvcvideo: Marking buffer as bad (error bit set).
[  708.345126] uvcvideo: Marking buffer as bad (error bit set).
[  708.345128] uvcvideo: Marking buffer as bad (error bit set).
[  708.345130] uvcvideo: Marking buffer as bad (error bit set).
[  708.347476] uvcvideo: Marking buffer as bad (error bit set).
[  708.347480] uvcvideo: Marking buffer as bad (error bit set).
[  708.347482] uvcvideo: Marking buffer as bad (error bit set).
[  708.347483] uvcvideo: Marking buffer as bad (error bit set).
[  708.347484] uvcvideo: Marking buffer as bad (error bit set).
[  708.347486] uvcvideo: Marking buffer as bad (error bit set).
[  708.347489] uvcvideo: Marking buffer as bad (error bit set).
[  708.347490] uvcvideo: Marking buffer as bad (error bit set).
[  708.347492] uvcvideo: Marking buffer as bad (error bit set).
[  708.347493] uvcvideo: Marking buffer as bad (error bit set).
[  708.347494] uvcvideo: Marking buffer as bad (error bit set).
[  708.347496] uvcvideo: Marking buffer as bad (error bit set).
[  708.347497] uvcvideo: Marking buffer as bad (error bit set).
[  708.347498] uvcvideo: Marking buffer as bad (error bit set).
[  708.347500] uvcvideo: Marking buffer as bad (error bit set).
[  708.347502] uvcvideo: Marking buffer as bad (error bit set).
[  708.347503] uvcvideo: Marking buffer as bad (error bit set).
[  708.347504] uvcvideo: Marking buffer as bad (error bit set).
[  708.347506] uvcvideo: Marking buffer as bad (error bit set).
[  708.349850] uvcvideo: Marking buffer as bad (error bit set).
[  708.349854] uvcvideo: Marking buffer as bad (error bit set).
[  708.349857] uvcvideo: Marking buffer as bad (error bit set).
[  708.349860] uvcvideo: Marking buffer as bad (error bit set).
[  708.349862] uvcvideo: Marking buffer as bad (error bit set).
[  708.349863] uvcvideo: Marking buffer as bad (error bit set).
[  708.349864] uvcvideo: Marking buffer as bad (error bit set).
[  708.349866] uvcvideo: Marking buffer as bad (error bit set).
[  708.349867] uvcvideo: Marking buffer as bad (error bit set).
[  708.349868] uvcvideo: Marking buffer as bad (error bit set).
[  708.349870] uvcvideo: Marking buffer as bad (error bit set).
[  708.349872] uvcvideo: Marking buffer as bad (error bit set).
[  708.349873] uvcvideo: Marking buffer as bad (error bit set).
[  708.349875] uvcvideo: Marking buffer as bad (error bit set).
[  708.349876] uvcvideo: Marking buffer as bad (error bit set).
[  708.349878] uvcvideo: Marking buffer as bad (error bit set).
[  708.349881] uvcvideo: Marking buffer as bad (error bit set).
[  708.349883] uvcvideo: Marking buffer as bad (error bit set).
[  708.349887] uvcvideo: Marking buffer as bad (error bit set).
[  708.352226] uvcvideo: Marking buffer as bad (error bit set).
[  708.352230] uvcvideo: Marking buffer as bad (error bit set).
[  708.352231] uvcvideo: Marking buffer as bad (error bit set).
[  708.352233] uvcvideo: Marking buffer as bad (error bit set).
[  708.352235] uvcvideo: Marking buffer as bad (error bit set).
[  708.352236] uvcvideo: Marking buffer as bad (error bit set).
[  708.352237] uvcvideo: Marking buffer as bad (error bit set).
[  708.352239] uvcvideo: Marking buffer as bad (error bit set).
[  708.352241] uvcvideo: Marking buffer as bad (error bit set).
[  708.352243] uvcvideo: Marking buffer as bad (error bit set).
[  708.352244] uvcvideo: Marking buffer as bad (error bit set).
[  708.352245] uvcvideo: Marking buffer as bad (error bit set).
[  708.352247] uvcvideo: Marking buffer as bad (error bit set).
[  708.352248] uvcvideo: Marking buffer as bad (error bit set).
[  708.352249] uvcvideo: Marking buffer as bad (error bit set).
[  708.352251] uvcvideo: Marking buffer as bad (error bit set).
[  708.352253] uvcvideo: Marking buffer as bad (error bit set).
[  708.352254] uvcvideo: Marking buffer as bad (error bit set).
[  708.352256] uvcvideo: Marking buffer as bad (error bit set).
[  708.354600] uvcvideo: Marking buffer as bad (error bit set).
[  708.354604] uvcvideo: Marking buffer as bad (error bit set).
[  708.354606] uvcvideo: Marking buffer as bad (error bit set).
[  708.354608] uvcvideo: Marking buffer as bad (error bit set).
[  708.354609] uvcvideo: Marking buffer as bad (error bit set).
[  708.354612] uvcvideo: Marking buffer as bad (error bit set).
[  708.354613] uvcvideo: Marking buffer as bad (error bit set).
[  708.354615] uvcvideo: Marking buffer as bad (error bit set).
[  708.354616] uvcvideo: Marking buffer as bad (error bit set).
[  708.354618] uvcvideo: Marking buffer as bad (error bit set).
[  708.354619] uvcvideo: Marking buffer as bad (error bit set).
[  708.354621] uvcvideo: Marking buffer as bad (error bit set).
[  708.354622] uvcvideo: Marking buffer as bad (error bit set).
[  708.354624] uvcvideo: Marking buffer as bad (error bit set).
[  708.354626] uvcvideo: Marking buffer as bad (error bit set).
[  708.354627] uvcvideo: Marking buffer as bad (error bit set).
[  708.354628] uvcvideo: Marking buffer as bad (error bit set).
[  708.354630] uvcvideo: Marking buffer as bad (error bit set).
[  708.354631] uvcvideo: Marking buffer as bad (error bit set).
[  708.356976] uvcvideo: Marking buffer as bad (error bit set).
[  708.356980] uvcvideo: Marking buffer as bad (error bit set).
[  708.356984] uvcvideo: Marking buffer as bad (error bit set).
[  708.356985] uvcvideo: Marking buffer as bad (error bit set).
[  708.356986] uvcvideo: Marking buffer as bad (error bit set).
[  708.356988] uvcvideo: Marking buffer as bad (error bit set).
[  708.356989] uvcvideo: Marking buffer as bad (error bit set).
[  708.356991] uvcvideo: Marking buffer as bad (error bit set).
[  708.356992] uvcvideo: Marking buffer as bad (error bit set).
[  708.356994] uvcvideo: Marking buffer as bad (error bit set).
[  708.356996] uvcvideo: Marking buffer as bad (error bit set).
[  708.356997] uvcvideo: Marking buffer as bad (error bit set).
[  708.356999] uvcvideo: Marking buffer as bad (error bit set).
[  708.357000] uvcvideo: Marking buffer as bad (error bit set).
[  708.357001] uvcvideo: Marking buffer as bad (error bit set).
[  708.357003] uvcvideo: Marking buffer as bad (error bit set).
[  708.357004] uvcvideo: Marking buffer as bad (error bit set).
[  708.357005] uvcvideo: Marking buffer as bad (error bit set).
[  708.357008] uvcvideo: Marking buffer as bad (error bit set).
[  708.359349] uvcvideo: Marking buffer as bad (error bit set).
[  708.359353] uvcvideo: Marking buffer as bad (error bit set).
[  708.359354] uvcvideo: Marking buffer as bad (error bit set).
[  708.359356] uvcvideo: Marking buffer as bad (error bit set).
[  708.359357] uvcvideo: Marking buffer as bad (error bit set).
[  708.359358] uvcvideo: Marking buffer as bad (error bit set).
[  708.359360] uvcvideo: Marking buffer as bad (error bit set).
[  708.359362] uvcvideo: Marking buffer as bad (error bit set).
[  708.359364] uvcvideo: Marking buffer as bad (error bit set).
[  708.359365] uvcvideo: Marking buffer as bad (error bit set).
[  708.359366] uvcvideo: Marking buffer as bad (error bit set).
[  708.359367] uvcvideo: Marking buffer as bad (error bit set).
[  708.359369] uvcvideo: Marking buffer as bad (error bit set).
[  708.359370] uvcvideo: Marking buffer as bad (error bit set).
[  708.359371] uvcvideo: Marking buffer as bad (error bit set).
[  708.359373] uvcvideo: Marking buffer as bad (error bit set).
[  708.359375] uvcvideo: Marking buffer as bad (error bit set).
[  708.359376] uvcvideo: Marking buffer as bad (error bit set).
[  708.359377] uvcvideo: Marking buffer as bad (error bit set).
[  708.361724] uvcvideo: Marking buffer as bad (error bit set).
[  708.361729] uvcvideo: Marking buffer as bad (error bit set).
[  708.361730] uvcvideo: Marking buffer as bad (error bit set).
[  708.361732] uvcvideo: Marking buffer as bad (error bit set).
[  708.361734] uvcvideo: Marking buffer as bad (error bit set).
[  708.361736] uvcvideo: Marking buffer as bad (error bit set).
[  708.361737] uvcvideo: Marking buffer as bad (error bit set).
[  708.361739] uvcvideo: Marking buffer as bad (error bit set).
[  708.361740] uvcvideo: Marking buffer as bad (error bit set).
[  708.361742] uvcvideo: Marking buffer as bad (error bit set).
[  708.361743] uvcvideo: Marking buffer as bad (error bit set).
[  708.361744] uvcvideo: Marking buffer as bad (error bit set).
[  708.361747] uvcvideo: Marking buffer as bad (error bit set).
[  708.361748] uvcvideo: Marking buffer as bad (error bit set).
[  708.361749] uvcvideo: Marking buffer as bad (error bit set).
[  708.361751] uvcvideo: Marking buffer as bad (error bit set).
[  708.361752] uvcvideo: Marking buffer as bad (error bit set).
[  708.361753] uvcvideo: Marking buffer as bad (error bit set).
[  708.361755] uvcvideo: Marking buffer as bad (error bit set).
[  708.364092] uvcvideo: Marking buffer as bad (error bit set).
[  708.364096] uvcvideo: Marking buffer as bad (error bit set).
[  708.364098] uvcvideo: Marking buffer as bad (error bit set).
[  708.364099] uvcvideo: Marking buffer as bad (error bit set).
[  708.364100] uvcvideo: Marking buffer as bad (error bit set).
[  708.364102] uvcvideo: Marking buffer as bad (error bit set).
[  708.364103] uvcvideo: Marking buffer as bad (error bit set).
[  708.364104] uvcvideo: Marking buffer as bad (error bit set).
[  708.364106] uvcvideo: Marking buffer as bad (error bit set).
[  708.364108] uvcvideo: Marking buffer as bad (error bit set).
[  708.364109] uvcvideo: Marking buffer as bad (error bit set).
[  708.364110] uvcvideo: Marking buffer as bad (error bit set).
[  708.364112] uvcvideo: Marking buffer as bad (error bit set).
[  708.364113] uvcvideo: Marking buffer as bad (error bit set).
[  708.364114] uvcvideo: Marking buffer as bad (error bit set).
[  708.364116] uvcvideo: Marking buffer as bad (error bit set).
[  708.364117] uvcvideo: Marking buffer as bad (error bit set).
[  708.364119] uvcvideo: Marking buffer as bad (error bit set).
[  708.364121] uvcvideo: Marking buffer as bad (error bit set).
[  708.366476] uvcvideo: Marking buffer as bad (error bit set).
[  708.366480] uvcvideo: Marking buffer as bad (error bit set).
[  708.366481] uvcvideo: Marking buffer as bad (error bit set).
[  708.366482] uvcvideo: Marking buffer as bad (error bit set).
[  708.366484] uvcvideo: Marking buffer as bad (error bit set).
[  708.366486] uvcvideo: Marking buffer as bad (error bit set).
[  708.366488] uvcvideo: Marking buffer as bad (error bit set).
[  708.366490] uvcvideo: Marking buffer as bad (error bit set).
[  708.366491] uvcvideo: Marking buffer as bad (error bit set).
[  708.366492] uvcvideo: Marking buffer as bad (error bit set).
[  708.366493] uvcvideo: Marking buffer as bad (error bit set).
[  708.366495] uvcvideo: Marking buffer as bad (error bit set).
[  708.366496] uvcvideo: Marking buffer as bad (error bit set).
[  708.366497] uvcvideo: Marking buffer as bad (error bit set).
[  708.366500] uvcvideo: Marking buffer as bad (error bit set).
[  708.366501] uvcvideo: Marking buffer as bad (error bit set).
[  708.366502] uvcvideo: Marking buffer as bad (error bit set).
[  708.366504] uvcvideo: Marking buffer as bad (error bit set).
[  708.366505] uvcvideo: Marking buffer as bad (error bit set).
[  708.368852] uvcvideo: Marking buffer as bad (error bit set).
[  708.368856] uvcvideo: Marking buffer as bad (error bit set).
[  708.368857] uvcvideo: Marking buffer as bad (error bit set).
[  708.368860] uvcvideo: Marking buffer as bad (error bit set).
[  708.368861] uvcvideo: Marking buffer as bad (error bit set).
[  708.368862] uvcvideo: Marking buffer as bad (error bit set).
[  708.368864] uvcvideo: Marking buffer as bad (error bit set).
[  708.368865] uvcvideo: Marking buffer as bad (error bit set).
[  708.368867] uvcvideo: Marking buffer as bad (error bit set).
[  708.368868] uvcvideo: Marking buffer as bad (error bit set).
[  708.368869] uvcvideo: Marking buffer as bad (error bit set).
[  708.368871] uvcvideo: Marking buffer as bad (error bit set).
[  708.368873] uvcvideo: Marking buffer as bad (error bit set).
[  708.368874] uvcvideo: Marking buffer as bad (error bit set).
[  708.368875] uvcvideo: Marking buffer as bad (error bit set).
[  708.368877] uvcvideo: Marking buffer as bad (error bit set).
[  708.368878] uvcvideo: Marking buffer as bad (error bit set).
[  708.368879] uvcvideo: Marking buffer as bad (error bit set).
[  708.368880] uvcvideo: Marking buffer as bad (error bit set).
[  708.371226] uvcvideo: Marking buffer as bad (error bit set).
[  708.371231] uvcvideo: Marking buffer as bad (error bit set).
[  708.371232] uvcvideo: Marking buffer as bad (error bit set).
[  708.371234] uvcvideo: Marking buffer as bad (error bit set).
[  708.371235] uvcvideo: Marking buffer as bad (error bit set).
[  708.371237] uvcvideo: Marking buffer as bad (error bit set).
[  708.371238] uvcvideo: Marking buffer as bad (error bit set).
[  708.371240] uvcvideo: Marking buffer as bad (error bit set).
[  708.371242] uvcvideo: Marking buffer as bad (error bit set).
[  708.371244] uvcvideo: Marking buffer as bad (error bit set).
[  708.371245] uvcvideo: Marking buffer as bad (error bit set).
[  708.371247] uvcvideo: Marking buffer as bad (error bit set).
[  708.371248] uvcvideo: Marking buffer as bad (error bit set).
[  708.371249] uvcvideo: Marking buffer as bad (error bit set).
[  708.371251] uvcvideo: Marking buffer as bad (error bit set).
[  708.371252] uvcvideo: Marking buffer as bad (error bit set).
[  708.371255] uvcvideo: Marking buffer as bad (error bit set).
[  708.371256] uvcvideo: Marking buffer as bad (error bit set).
[  708.371258] uvcvideo: Marking buffer as bad (error bit set).
[  708.373602] uvcvideo: Marking buffer as bad (error bit set).
[  708.373608] uvcvideo: Marking buffer as bad (error bit set).
[  708.373610] uvcvideo: Marking buffer as bad (error bit set).
[  708.373611] uvcvideo: Marking buffer as bad (error bit set).
[  708.373612] uvcvideo: Marking buffer as bad (error bit set).
[  708.373615] uvcvideo: Marking buffer as bad (error bit set).
[  708.373616] uvcvideo: Marking buffer as bad (error bit set).
[  708.373618] uvcvideo: Marking buffer as bad (error bit set).
[  708.373620] uvcvideo: Marking buffer as bad (error bit set).
[  708.373621] uvcvideo: Marking buffer as bad (error bit set).
[  708.373622] uvcvideo: Marking buffer as bad (error bit set).
[  708.373624] uvcvideo: Marking buffer as bad (error bit set).
[  708.373625] uvcvideo: Marking buffer as bad (error bit set).
[  708.373627] uvcvideo: Marking buffer as bad (error bit set).
[  708.373629] uvcvideo: Marking buffer as bad (error bit set).
[  708.373630] uvcvideo: Marking buffer as bad (error bit set).
[  708.373632] uvcvideo: Marking buffer as bad (error bit set).
[  708.373633] uvcvideo: Marking buffer as bad (error bit set).
[  708.373634] uvcvideo: Marking buffer as bad (error bit set).
[  708.375977] uvcvideo: Marking buffer as bad (error bit set).
[  708.375982] uvcvideo: Marking buffer as bad (error bit set).
[  708.375985] uvcvideo: Marking buffer as bad (error bit set).
[  708.375986] uvcvideo: Marking buffer as bad (error bit set).
[  708.375988] uvcvideo: Marking buffer as bad (error bit set).
[  708.375989] uvcvideo: Marking buffer as bad (error bit set).
[  708.375990] uvcvideo: Marking buffer as bad (error bit set).
[  708.375992] uvcvideo: Marking buffer as bad (error bit set).
[  708.375993] uvcvideo: Marking buffer as bad (error bit set).
[  708.375994] uvcvideo: Marking buffer as bad (error bit set).
[  708.375997] uvcvideo: Marking buffer as bad (error bit set).
[  708.375998] uvcvideo: Marking buffer as bad (error bit set).
[  708.375999] uvcvideo: Marking buffer as bad (error bit set).
[  708.376000] uvcvideo: Marking buffer as bad (error bit set).
[  708.376002] uvcvideo: Marking buffer as bad (error bit set).
[  708.376003] uvcvideo: Marking buffer as bad (error bit set).
[  708.376004] uvcvideo: Marking buffer as bad (error bit set).
[  708.376006] uvcvideo: Marking buffer as bad (error bit set).
[  708.376008] uvcvideo: Marking buffer as bad (error bit set).
[  708.378349] uvcvideo: Marking buffer as bad (error bit set).
[  708.378354] uvcvideo: Marking buffer as bad (error bit set).
[  708.378355] uvcvideo: Marking buffer as bad (error bit set).
[  708.378357] uvcvideo: Marking buffer as bad (error bit set).
[  708.378358] uvcvideo: Marking buffer as bad (error bit set).
[  708.378360] uvcvideo: Marking buffer as bad (error bit set).
[  708.378362] uvcvideo: Marking buffer as bad (error bit set).
[  708.378364] uvcvideo: Marking buffer as bad (error bit set).
[  708.378366] uvcvideo: Marking buffer as bad (error bit set).
[  708.378367] uvcvideo: Marking buffer as bad (error bit set).
[  708.378368] uvcvideo: Marking buffer as bad (error bit set).
[  708.378370] uvcvideo: Marking buffer as bad (error bit set).
[  708.378371] uvcvideo: Marking buffer as bad (error bit set).
[  708.378372] uvcvideo: Marking buffer as bad (error bit set).
[  708.378373] uvcvideo: Marking buffer as bad (error bit set).
[  708.378376] uvcvideo: Marking buffer as bad (error bit set).
[  708.378377] uvcvideo: Marking buffer as bad (error bit set).
[  708.378378] uvcvideo: Marking buffer as bad (error bit set).
[  708.378380] uvcvideo: Marking buffer as bad (error bit set).
[  708.380727] uvcvideo: Marking buffer as bad (error bit set).
[  708.380731] uvcvideo: Marking buffer as bad (error bit set).
[  708.380732] uvcvideo: Marking buffer as bad (error bit set).
[  708.380734] uvcvideo: Marking buffer as bad (error bit set).
[  708.380737] uvcvideo: Marking buffer as bad (error bit set).
[  708.380738] uvcvideo: Marking buffer as bad (error bit set).
[  708.380739] uvcvideo: Marking buffer as bad (error bit set).
[  708.380741] uvcvideo: Marking buffer as bad (error bit set).
[  708.380742] uvcvideo: Marking buffer as bad (error bit set).
[  708.380743] uvcvideo: Marking buffer as bad (error bit set).
[  708.380745] uvcvideo: Marking buffer as bad (error bit set).
[  708.380746] uvcvideo: Marking buffer as bad (error bit set).
[  708.380748] uvcvideo: Marking buffer as bad (error bit set).
[  708.380750] uvcvideo: Marking buffer as bad (error bit set).
[  708.380751] uvcvideo: Marking buffer as bad (error bit set).
[  708.380752] uvcvideo: Marking buffer as bad (error bit set).
[  708.380754] uvcvideo: Marking buffer as bad (error bit set).
[  708.380755] uvcvideo: Marking buffer as bad (error bit set).
[  708.380756] uvcvideo: Marking buffer as bad (error bit set).
[  708.383099] uvcvideo: Marking buffer as bad (error bit set).
[  708.383105] uvcvideo: Marking buffer as bad (error bit set).
[  708.383106] uvcvideo: Marking buffer as bad (error bit set).
[  708.383108] uvcvideo: Marking buffer as bad (error bit set).
[  708.383109] uvcvideo: Marking buffer as bad (error bit set).
[  708.383111] uvcvideo: Marking buffer as bad (error bit set).
[  708.383113] uvcvideo: Marking buffer as bad (error bit set).
[  708.383114] uvcvideo: Marking buffer as bad (error bit set).
[  708.383115] uvcvideo: Marking buffer as bad (error bit set).
[  708.383118] uvcvideo: Marking buffer as bad (error bit set).
[  708.383119] uvcvideo: Marking buffer as bad (error bit set).
[  708.383120] uvcvideo: Marking buffer as bad (error bit set).
[  708.383122] uvcvideo: Marking buffer as bad (error bit set).
[  708.383123] uvcvideo: Marking buffer as bad (error bit set).
[  708.383124] uvcvideo: Marking buffer as bad (error bit set).
[  708.383126] uvcvideo: Marking buffer as bad (error bit set).
[  708.383127] uvcvideo: Marking buffer as bad (error bit set).
[  708.383129] uvcvideo: Marking buffer as bad (error bit set).
[  708.383130] uvcvideo: Marking buffer as bad (error bit set).
[  708.385476] uvcvideo: Marking buffer as bad (error bit set).
[  708.385481] uvcvideo: Marking buffer as bad (error bit set).
[  708.385483] uvcvideo: Marking buffer as bad (error bit set).
[  708.385484] uvcvideo: Marking buffer as bad (error bit set).
[  708.385486] uvcvideo: Marking buffer as bad (error bit set).
[  708.385487] uvcvideo: Marking buffer as bad (error bit set).
[  708.385490] uvcvideo: Marking buffer as bad (error bit set).
[  708.385492] uvcvideo: Marking buffer as bad (error bit set).
[  708.385494] uvcvideo: Marking buffer as bad (error bit set).
[  708.385495] uvcvideo: Marking buffer as bad (error bit set).
[  708.385496] uvcvideo: Marking buffer as bad (error bit set).
[  708.385498] uvcvideo: Marking buffer as bad (error bit set).
[  708.385499] uvcvideo: Marking buffer as bad (error bit set).
[  708.385501] uvcvideo: Marking buffer as bad (error bit set).
[  708.385503] uvcvideo: Marking buffer as bad (error bit set).
[  708.385504] uvcvideo: Marking buffer as bad (error bit set).
[  708.385506] uvcvideo: Marking buffer as bad (error bit set).
[  708.385507] uvcvideo: Marking buffer as bad (error bit set).
[  708.385508] uvcvideo: Marking buffer as bad (error bit set).
[  708.387850] uvcvideo: Marking buffer as bad (error bit set).
[  708.387856] uvcvideo: Marking buffer as bad (error bit set).
[  708.387858] uvcvideo: Marking buffer as bad (error bit set).
[  708.387861] uvcvideo: Marking buffer as bad (error bit set).
[  708.387862] uvcvideo: Marking buffer as bad (error bit set).
[  708.387863] uvcvideo: Marking buffer as bad (error bit set).
[  708.387865] uvcvideo: Marking buffer as bad (error bit set).
[  708.387866] uvcvideo: Marking buffer as bad (error bit set).
[  708.387867] uvcvideo: Marking buffer as bad (error bit set).
[  708.387869] uvcvideo: Marking buffer as bad (error bit set).
[  708.387870] uvcvideo: Marking buffer as bad (error bit set).
[  708.387872] uvcvideo: Marking buffer as bad (error bit set).
[  708.387874] uvcvideo: Marking buffer as bad (error bit set).
[  708.387875] uvcvideo: Marking buffer as bad (error bit set).
[  708.387876] uvcvideo: Marking buffer as bad (error bit set).
[  708.387877] uvcvideo: Marking buffer as bad (error bit set).
[  708.387879] uvcvideo: Marking buffer as bad (error bit set).
[  708.387880] uvcvideo: Marking buffer as bad (error bit set).
[  708.387881] uvcvideo: Marking buffer as bad (error bit set).
[  708.390225] uvcvideo: Marking buffer as bad (error bit set).
[  708.390230] uvcvideo: Marking buffer as bad (error bit set).
[  708.390232] uvcvideo: Marking buffer as bad (error bit set).
[  708.390233] uvcvideo: Marking buffer as bad (error bit set).
[  708.390234] uvcvideo: Marking buffer as bad (error bit set).
[  708.390237] uvcvideo: Marking buffer as bad (error bit set).
[  708.390238] uvcvideo: Marking buffer as bad (error bit set).
[  708.390239] uvcvideo: Marking buffer as bad (error bit set).
[  708.390241] uvcvideo: Marking buffer as bad (error bit set).
[  708.390243] uvcvideo: Marking buffer as bad (error bit set).
[  708.390244] uvcvideo: Marking buffer as bad (error bit set).
[  708.390245] uvcvideo: Marking buffer as bad (error bit set).
[  708.390247] uvcvideo: Marking buffer as bad (error bit set).
[  708.390248] uvcvideo: Marking buffer as bad (error bit set).
[  708.390249] uvcvideo: Marking buffer as bad (error bit set).
[  708.390250] uvcvideo: Marking buffer as bad (error bit set).
[  708.390253] uvcvideo: Marking buffer as bad (error bit set).
[  708.390254] uvcvideo: Marking buffer as bad (error bit set).
[  708.390255] uvcvideo: Marking buffer as bad (error bit set).
[  708.392601] uvcvideo: Marking buffer as bad (error bit set).
[  708.392606] uvcvideo: Marking buffer as bad (error bit set).
[  708.392607] uvcvideo: Marking buffer as bad (error bit set).
[  708.392610] uvcvideo: Marking buffer as bad (error bit set).
[  708.392611] uvcvideo: Marking buffer as bad (error bit set).
[  708.392613] uvcvideo: Marking buffer as bad (error bit set).
[  708.392615] uvcvideo: Marking buffer as bad (error bit set).
[  708.392616] uvcvideo: Marking buffer as bad (error bit set).
[  708.392617] uvcvideo: Marking buffer as bad (error bit set).
[  708.392619] uvcvideo: Marking buffer as bad (error bit set).
[  708.392620] uvcvideo: Marking buffer as bad (error bit set).
[  708.392621] uvcvideo: Marking buffer as bad (error bit set).
[  708.392623] uvcvideo: Marking buffer as bad (error bit set).
[  708.392625] uvcvideo: Marking buffer as bad (error bit set).
[  708.392626] uvcvideo: Marking buffer as bad (error bit set).
[  708.392628] uvcvideo: Marking buffer as bad (error bit set).
[  708.392629] uvcvideo: Marking buffer as bad (error bit set).
[  708.392630] uvcvideo: Marking buffer as bad (error bit set).
[  708.392631] uvcvideo: Marking buffer as bad (error bit set).
[  708.394980] uvcvideo: Marking buffer as bad (error bit set).
[  708.394985] uvcvideo: Marking buffer as bad (error bit set).
[  708.394988] uvcvideo: Marking buffer as bad (error bit set).
[  708.394990] uvcvideo: Marking buffer as bad (error bit set).
[  708.394991] uvcvideo: Marking buffer as bad (error bit set).
[  708.394993] uvcvideo: Marking buffer as bad (error bit set).
[  708.394994] uvcvideo: Marking buffer as bad (error bit set).
[  708.394995] uvcvideo: Marking buffer as bad (error bit set).
[  708.394997] uvcvideo: Marking buffer as bad (error bit set).
[  708.394998] uvcvideo: Marking buffer as bad (error bit set).
[  708.395001] uvcvideo: Marking buffer as bad (error bit set).
[  708.395002] uvcvideo: Marking buffer as bad (error bit set).
[  708.395003] uvcvideo: Marking buffer as bad (error bit set).
[  708.395005] uvcvideo: Marking buffer as bad (error bit set).
[  708.395006] uvcvideo: Marking buffer as bad (error bit set).
[  708.395007] uvcvideo: Marking buffer as bad (error bit set).
[  708.395009] uvcvideo: Marking buffer as bad (error bit set).
[  708.395010] uvcvideo: Marking buffer as bad (error bit set).
[  708.395012] uvcvideo: Marking buffer as bad (error bit set).
[  708.397351] uvcvideo: Marking buffer as bad (error bit set).
[  708.397356] uvcvideo: Marking buffer as bad (error bit set).
[  708.397358] uvcvideo: Marking buffer as bad (error bit set).
[  708.397359] uvcvideo: Marking buffer as bad (error bit set).
[  708.397361] uvcvideo: Marking buffer as bad (error bit set).
[  708.397362] uvcvideo: Marking buffer as bad (error bit set).
[  708.397363] uvcvideo: Marking buffer as bad (error bit set).
[  708.397366] uvcvideo: Marking buffer as bad (error bit set).
[  708.397367] uvcvideo: Marking buffer as bad (error bit set).
[  708.397369] uvcvideo: Marking buffer as bad (error bit set).
[  708.397370] uvcvideo: Marking buffer as bad (error bit set).
[  708.397371] uvcvideo: Marking buffer as bad (error bit set).
[  708.397372] uvcvideo: Marking buffer as bad (error bit set).
[  708.397374] uvcvideo: Marking buffer as bad (error bit set).
[  708.397375] uvcvideo: Marking buffer as bad (error bit set).
[  708.397377] uvcvideo: Marking buffer as bad (error bit set).
[  708.397379] uvcvideo: Marking buffer as bad (error bit set).
[  708.397380] uvcvideo: Marking buffer as bad (error bit set).
[  708.397381] uvcvideo: Marking buffer as bad (error bit set).
[  708.399725] uvcvideo: Marking buffer as bad (error bit set).
[  708.399730] uvcvideo: Marking buffer as bad (error bit set).
[  708.399731] uvcvideo: Marking buffer as bad (error bit set).
[  708.399733] uvcvideo: Marking buffer as bad (error bit set).
[  708.399736] uvcvideo: Marking buffer as bad (error bit set).
[  708.399737] uvcvideo: Marking buffer as bad (error bit set).
[  708.399739] uvcvideo: Marking buffer as bad (error bit set).
[  708.399740] uvcvideo: Marking buffer as bad (error bit set).
[  708.399742] uvcvideo: Marking buffer as bad (error bit set).
[  708.399743] uvcvideo: Marking buffer as bad (error bit set).
[  708.399744] uvcvideo: Marking buffer as bad (error bit set).
[  708.399746] uvcvideo: Marking buffer as bad (error bit set).
[  708.399748] uvcvideo: Marking buffer as bad (error bit set).
[  708.399749] uvcvideo: Marking buffer as bad (error bit set).
[  708.399751] uvcvideo: Marking buffer as bad (error bit set).
[  708.399752] uvcvideo: Marking buffer as bad (error bit set).
[  708.399753] uvcvideo: Marking buffer as bad (error bit set).
[  708.399754] uvcvideo: Marking buffer as bad (error bit set).
[  708.399756] uvcvideo: Marking buffer as bad (error bit set).
[  708.402100] uvcvideo: Marking buffer as bad (error bit set).
[  708.402106] uvcvideo: Marking buffer as bad (error bit set).
[  708.402108] uvcvideo: Marking buffer as bad (error bit set).
[  708.402109] uvcvideo: Marking buffer as bad (error bit set).
[  708.402111] uvcvideo: Marking buffer as bad (error bit set).
[  708.402113] uvcvideo: Marking buffer as bad (error bit set).
[  708.402114] uvcvideo: Marking buffer as bad (error bit set).
[  708.402115] uvcvideo: Marking buffer as bad (error bit set).
[  708.402116] uvcvideo: Marking buffer as bad (error bit set).
[  708.402119] uvcvideo: Marking buffer as bad (error bit set).
[  708.402120] uvcvideo: Marking buffer as bad (error bit set).
[  708.402122] uvcvideo: Marking buffer as bad (error bit set).
[  708.402123] uvcvideo: Marking buffer as bad (error bit set).
[  708.402124] uvcvideo: Marking buffer as bad (error bit set).
[  708.402126] uvcvideo: Marking buffer as bad (error bit set).
[  708.402127] uvcvideo: Marking buffer as bad (error bit set).
[  708.402128] uvcvideo: Marking buffer as bad (error bit set).
[  708.402130] uvcvideo: Marking buffer as bad (error bit set).
[  708.402132] uvcvideo: Marking buffer as bad (error bit set).
[  708.404474] uvcvideo: Marking buffer as bad (error bit set).
[  708.404475] uvcvideo: Marking buffer as bad (error bit set).
[  708.404478] uvcvideo: Marking buffer as bad (error bit set).
[  708.404479] uvcvideo: Marking buffer as bad (error bit set).
[  708.404481] uvcvideo: Marking buffer as bad (error bit set).
[  708.404482] uvcvideo: Marking buffer as bad (error bit set).
[  708.404484] uvcvideo: Marking buffer as bad (error bit set).
[  708.404486] uvcvideo: Marking buffer as bad (error bit set).
[  708.404487] uvcvideo: Marking buffer as bad (error bit set).
[  708.404488] uvcvideo: Marking buffer as bad (error bit set).
[  708.404490] uvcvideo: Marking buffer as bad (error bit set).
[  708.404491] uvcvideo: Marking buffer as bad (error bit set).
[  708.404493] uvcvideo: Marking buffer as bad (error bit set).
[  708.404494] uvcvideo: Marking buffer as bad (error bit set).
[  708.404497] uvcvideo: Marking buffer as bad (error bit set).
[  708.404498] uvcvideo: Marking buffer as bad (error bit set).
[  708.404499] uvcvideo: Marking buffer as bad (error bit set).
[  708.404501] uvcvideo: Marking buffer as bad (error bit set).
[  708.404502] uvcvideo: Marking buffer as bad (error bit set).
[  708.406850] uvcvideo: Marking buffer as bad (error bit set).
[  708.406855] uvcvideo: Marking buffer as bad (error bit set).
[  708.406857] uvcvideo: Marking buffer as bad (error bit set).
[  708.406859] uvcvideo: Marking buffer as bad (error bit set).
[  708.406861] uvcvideo: Marking buffer as bad (error bit set).
[  708.406862] uvcvideo: Marking buffer as bad (error bit set).
[  708.406864] uvcvideo: Marking buffer as bad (error bit set).
[  708.406866] uvcvideo: Marking buffer as bad (error bit set).
[  708.406867] uvcvideo: Marking buffer as bad (error bit set).
[  708.406868] uvcvideo: Marking buffer as bad (error bit set).
[  708.406870] uvcvideo: Marking buffer as bad (error bit set).
[  708.406873] uvcvideo: Marking buffer as bad (error bit set).
[  708.406874] uvcvideo: Marking buffer as bad (error bit set).
[  708.406876] uvcvideo: Marking buffer as bad (error bit set).
[  708.406877] uvcvideo: Marking buffer as bad (error bit set).
[  708.406879] uvcvideo: Marking buffer as bad (error bit set).
[  708.406881] uvcvideo: Marking buffer as bad (error bit set).
[  708.406882] uvcvideo: Marking buffer as bad (error bit set).
[  708.406883] uvcvideo: Marking buffer as bad (error bit set).
[  708.409227] uvcvideo: Marking buffer as bad (error bit set).
[  708.409233] uvcvideo: Marking buffer as bad (error bit set).
[  708.409235] uvcvideo: Marking buffer as bad (error bit set).
[  708.409236] uvcvideo: Marking buffer as bad (error bit set).
[  708.409238] uvcvideo: Marking buffer as bad (error bit set).
[  708.409240] uvcvideo: Marking buffer as bad (error bit set).
[  708.409241] uvcvideo: Marking buffer as bad (error bit set).
[  708.409243] uvcvideo: Marking buffer as bad (error bit set).
[  708.409245] uvcvideo: Marking buffer as bad (error bit set).
[  708.409247] uvcvideo: Marking buffer as bad (error bit set).
[  708.409248] uvcvideo: Marking buffer as bad (error bit set).
[  708.409250] uvcvideo: Marking buffer as bad (error bit set).
[  708.409251] uvcvideo: Marking buffer as bad (error bit set).
[  708.409253] uvcvideo: Marking buffer as bad (error bit set).
[  708.409255] uvcvideo: Marking buffer as bad (error bit set).
[  708.409256] uvcvideo: Marking buffer as bad (error bit set).
[  708.409259] uvcvideo: Marking buffer as bad (error bit set).
[  708.409261] uvcvideo: Marking buffer as bad (error bit set).
[  708.409265] uvcvideo: Marking buffer as bad (error bit set).
[  708.411606] uvcvideo: Marking buffer as bad (error bit set).
[  708.411611] uvcvideo: Marking buffer as bad (error bit set).
[  708.411612] uvcvideo: Marking buffer as bad (error bit set).
[  708.411613] uvcvideo: Marking buffer as bad (error bit set).
[  708.411615] uvcvideo: Marking buffer as bad (error bit set).
[  708.411618] uvcvideo: Marking buffer as bad (error bit set).
[  708.411619] uvcvideo: Marking buffer as bad (error bit set).
[  708.411620] uvcvideo: Marking buffer as bad (error bit set).
[  708.411622] uvcvideo: Marking buffer as bad (error bit set).
[  708.411623] uvcvideo: Marking buffer as bad (error bit set).
[  708.411624] uvcvideo: Marking buffer as bad (error bit set).
[  708.411626] uvcvideo: Marking buffer as bad (error bit set).
[  708.411627] uvcvideo: Marking buffer as bad (error bit set).
[  708.411629] uvcvideo: Marking buffer as bad (error bit set).
[  708.411630] uvcvideo: Marking buffer as bad (error bit set).
[  708.411632] uvcvideo: Marking buffer as bad (error bit set).
[  708.411633] uvcvideo: Marking buffer as bad (error bit set).
[  708.411635] uvcvideo: Marking buffer as bad (error bit set).
[  708.411642] uvcvideo: frame 1 stats: 0/1139/1139 packets, 0/0/1139 pts (early !initial), 1138/1139 scr, last pts/stc/sof 6710/4506781/423
[  708.428249] uvcvideo: Frame complete (EOF found).
[  708.428255] uvcvideo: Dropping payload (out of sync).
[  708.428257] uvcvideo: Dropping payload (out of sync).
[  708.428260] uvcvideo: Dropping payload (out of sync).
[  708.428261] uvcvideo: Dropping payload (out of sync).
[  708.428263] uvcvideo: Dropping payload (out of sync).
[  708.430608] uvcvideo: Dropping payload (out of sync).
[  708.430612] uvcvideo: Dropping payload (out of sync).
[  708.430614] uvcvideo: Dropping payload (out of sync).
[  708.430615] uvcvideo: Dropping payload (out of sync).
[  708.430625] uvcvideo: frame 2 stats: 0/9/138 packets, 0/0/138 pts (!early initial), 137/138 scr, last pts/stc/sof 4495454/5044808/440
[  708.444883] uvcvideo: Frame complete (EOF found).
[  708.445038] uvcvideo: uvc_v4l2_poll
[  708.447254] uvcvideo: Dropping payload (out of sync).
[  708.447259] uvcvideo: Dropping payload (out of sync).
[  708.447261] uvcvideo: Dropping payload (out of sync).
[  708.447263] uvcvideo: Dropping payload (out of sync).
[  708.447264] uvcvideo: Dropping payload (out of sync).
[  708.447265] uvcvideo: Dropping payload (out of sync).
[  708.447267] uvcvideo: Dropping payload (out of sync).
[  708.447268] uvcvideo: Dropping payload (out of sync).
[  708.447271] uvcvideo: Dropping payload (out of sync).
[  708.447280] uvcvideo: frame 3 stats: 0/9/138 packets, 0/0/138 pts (!early initial), 137/138 scr, last pts/stc/sof 5033301/5582836/458
[  708.449136] uvcvideo: uvc_v4l2_poll
[  708.463873] uvcvideo: Frame complete (EOF found).
[  708.463894] uvcvideo: Dropping payload (out of sync).
[  708.463896] uvcvideo: Dropping payload (out of sync).
[  708.463898] uvcvideo: Dropping payload (out of sync).
[  708.463899] uvcvideo: Dropping payload (out of sync).
[  708.463900] uvcvideo: Dropping payload (out of sync).
[  708.463902] uvcvideo: Dropping payload (out of sync).
[  708.463905] uvcvideo: Dropping payload (out of sync).
[  708.463906] uvcvideo: Dropping payload (out of sync).
[  708.463907] uvcvideo: Dropping payload (out of sync).
And when I start the 4th camera with GStreamer:
[ 1635.654562] uvcvideo: Device requested 32768 B/frame bandwidth.
[ 1635.654570] uvcvideo: Selecting alternate setting 11 (32768 B/frame bandwidth).
[ 1635.657892] usb 2-3.1.4: Not enough bandwidth for new device state.
[ 1635.658060] usb 2-3.1.4: Not enough bandwidth for altsetting 11
Seems there is not enough bandwidth for the 4th camera.
In fact, the 60fps framerate is not necessary, but I cannot find suitable USB3.0 camera with 640x480 30fps.
Are there any methods can let the cameras work with lower bandwidth?
Thank you so much.
Ambrose
You may try this:
Two 1080p USB cameras on Nano - #17 by DaneLLL
