When it fails, the kernel log shows the following messages:
[ 174.753229] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 174.753528] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 174.754573] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 174.754736] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 174.754963] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 174.755105] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 174.755701] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
This issue occurs in the L4T 35.1 version, while the same capture program can consistently capture images in L4T R32.5.1.
