I have the Jetson Nano 2GB Developer Kit. The issue that I am having is that it turns on (the green light turns on), but it doesn’t seem to boot (when I plug it into the monitor nothing is on the screen, and when I try headless, it doesn’t show up as a COM port). I have reflashing my SD card but that doesn’t seem to work. I also tried using the SDK manager to setup my Jetson but I keep getting the same error that File System and OS failed. These are the logs:
sdkmanagererrorlog.zip (149.9 KB)
I haven’t been able to find another solution.
Please delete this file and proceed again:
mknod: /home/arav/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/rootfs/dev/random
Hey Dave, thanks for the response. I tried this but I got the same exact error. There was another file in there too called “urandom”. After trying what you suggested. I also tried again but by deleting both random and urandom, but still no luck. I had the same error. Is there anything else I could try?
Or delete the entire Linux_for_Tegra folder and let SDKM download it again.
I tried this but I got the same error again. I also wanted to let you know that I am running the SDK manager on WSL, in case that helps with anything.
WSL is not really recommended.
Will be good if you can verify on a real Ubuntu host PC.
I will try that tmmrw and let you know what happens.
