HI - my apologies if I am posting in the wrong place, and/or starting a duplicate topic, but I can’t find any other references to this problem.
I’m trying to configure a brand new Nano Developer Kit. I downloaded ‘nv-jetson-nano-sd-card-image-r32.3.1.zip’, flashed to a 64Gb card, installed, connected a monitor and a 4A power supply. No joy; serial text on screen ending in “Rebooting in 5 seconds…” Repeats until powered off.
After connecting a serial console I was able to capture the following boot sequence.
The “EXT4-fs error” messages led me to suspect an SD Card problem, but I’ve tried three different flashes to two different cards. Problem persists.
Any and all suggestions welcome :)
Cheers
Sean
U-Boot 2016.07-g0536cf2a27 (Dec 09 2019 - 22:40:32 -0800)
TEGRA210
Model: NVIDIA P3450-Porg
Board: NVIDIA P3450-PORG
DRAM: 4 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
SF: Detected MX25U3235F with page size 256 Bytes, erase size 4 KiB, total 4 MiB
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
733 bytes read in 160 ms (3.9 KiB/s)
1: primary kernel
Retrieving file: /boot/initrd
5487751 bytes read in 287 ms (18.2 MiB/s)
Retrieving file: /boot/Image
34191368 bytes read in 1532 ms (21.3 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet
## Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
reserving fdt memory region: addr=80000000 size=20000
Using Device Tree in place at 0000000083100000, end 00000000831776f0
Starting kernel ...
<hit enter to activate fiq debugger>
[ 1.002663] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.508789] Host read timeout at address 545c00c4
[ 1.824285] imx219 6-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.831843] imx219 6-0010: board setup failed
[ 2.249307] EXT4-fs error (device mmcblk0p1): ext4_iget:4591: inode #393931: comm mount: checksum invalid
[ 2.262549] EXT4-fs error (device mmcblk0p1): ext4_iget:4591: inode #393931: comm mount: checksum invalid
[ 2.279076] EXT4-fs error (device mmcblk0p1): ext4_iget:4591: inode #393217: comm mount: checksum invalid
[ 2.292360] EXT4-fs error (device mmcblk0p1): ext4_iget:4591: inode #393217: comm mount: checksum invalid
[ 2.308648] EXT4-fs error (device mmcblk0p1): ext4_iget:4591: inode #655361: comm cp: checksum invalid
[ 2.326703] EXT4-fs error (device mmcblk0p1): ext4_iget:4591: inode #393740: comm chroot: checksum invalid
[ 2.344383] EXT4-fs error (device mmcblk0p1): ext4_iget:4591: inode #393932: comm chroot: checksum invalid
[ 2.403611] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00007e00
[ 2.403611]
[ 2.412737] CPU: 1 PID: 1 Comm: chroot Not tainted 4.9.140-tegra #1
[ 2.418992] Hardware name: NVIDIA Jetson Nano Developer Kit (DT)
[ 2.424986] Call trace:
[ 2.427431] [<ffffff800808bdb8>] dump_backtrace+0x0/0x198
[ 2.432820] [<ffffff800808c37c>] show_stack+0x24/0x30
[ 2.437864] [<ffffff800845d820>] dump_stack+0x98/0xc0
[ 2.442908] [<ffffff80081c2198>] panic+0x11c/0x298
[ 2.447690] [<ffffff80080b9db4>] do_exit+0xa04/0xa08
[ 2.452644] [<ffffff80080b9e48>] do_group_exit+0x40/0xa8
[ 2.457946] [<ffffff80080b9ed0>] __wake_up_parent+0x0/0x40
[ 2.463421] [<ffffff80080838c0>] el0_svc_naked+0x34/0x38
[ 2.468724] SMP: stopping secondary CPUs
[ 2.472691] Kernel Offset: disabled
[ 2.476173] Memory Limit: none
[ 2.484254] Rebooting in 5 seconds..
