Hi, I had my Jetson Nano for more than year, I didn’t really use it in the last 6 months but know I can’t get it to boot correctly. I’ve tried 2 SD cards, tried to flash them with BalenaEtcher on mac, with the terminal on mac and with the terminal on Ubuntu and it’s always the same error (see below).
Any advice ?
Here is an OCR of the error:
1.1471443 tegradc tegradc.1: dpd enable lookup fail:-19
1.3111481 imx219 7-0010: imx219_boarksetup: error during i2c read probe (-121)
1.3112151 imx219 7-0010: board setup failed
1.33504131 imx219 8-0010: imxZ19_board_setup: error during i2c read probe (-121)
1.32151053 imx219 8-0010: board setup failed
1.7848011 EXT4-fs error (device mmalkOpl): ext4Jookup:1603: i node #2: comm mount : deleted i node referenced: 655370 1.7971801 EXT4-fs error (deuice mmcblkOp1): ext4_lookup:1603: inode #2: comm mount : deleted inode referenced : 655370
mount : /mnt/sys: mount(Z) system call failed: Structure needs cleaning.
cp: not writing through dangling symlink letc/resolu.conf'
1.9566541 EXT4-fs error (device mmcblkOp1): ext4_lookup:1603: inode #2: comm init: deleted inode referenced : 655370
1.9894683 EXT4-fs error (device mmcblkOp1): ext4_lookup:1603: inode #2: comm systemd: deleted inode referenced : 655370
1.0047621 systemdfll: Failed to determine whether /sys is a mount point : Structure needs cleaning 2.0139741 EXT4-fs error (device mmcblkOp1): ext4_lookup:1603: inode #2: comm systemd : deleted inode referenced : 655370
2.028263 EXT4-fs error (device mmcblkOp1): ext4Jookup:1603: inode 112: comm systemd : deleted inode referenced : 655370
Failed to mount early API filesystems, freezing.
2.0401561 systemd[1]: Freezing execution.
