HuiW
1
We got new Nano B01(ex:SN:1423019138891) and the Nanos failed to boot.
As We used a Nano with a SDcard which worked well on our previous Nano board(SN:1423219075767),
and Nano launched failed.
However, the Nano (ex:SN:1423019138891) worked well after be re-flashed by using SDKManager.
It’s similar with the previous Nano A2 issue.
Is there a way to fix it?
Thank you for any advice,
Hi HuiW,
I guess it is similar issue as before. Let me check this issue internally.
Thanks for your report. BTW, do you have other devices also suffer this issue?
kayccc
3
Hi HuiW,
That hasn’t been fixed yet, we’re targeting at 1H 2020, please be sure to flash the device with the SDKM, then boot first.
HuiW
4
Hi Kayccc and WayneWWW,
Thank you so much for your prompt support.
It would be great to get update if the issue is fixed.
Thanks,
