When the asset path in default_config.yaml is changed from warehouse to rivermark and the following command is executed:
"NavMesh building failed. Please check whether the stage has a valid NavmeshVolume. Will not load assets to scene."
this message is output and execution halts. This error does not occur in the warehouse scene, so asset generation completes without issues in that case.
I’m looking for a way to prevent the error from appearing, or to disable NavMesh entirely—are there any known workarounds?
I referred to the following Q&A but the result didn’t change:
isaacsim.replicator.agent:
version: 0.5.1
global:
seed: 123456
simulation_length: 300
scene:
asset_path: https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/Isaac/4.5/Isaac/Environments/Outdoor/Rivermark/rivermark.usd
camera_num: 5
character:
asset_path: [Isaac Sim Assets Path]/Isaac/People/Characters/
command_file: default_command.txt
filters: ''
num: 10
robot:
command_file: default_robot_command.txt
nova_carter_num: 0
transporter_num: 0
write_data: false
replicator:
writer: IRABasicWriter
parameters:
output_dir:
rgb: true
object_info_bounding_box_2d_tight: true
object_info_bounding_box_2d_loose: true
object_info_bounding_box_3d: true
Isaac Sim Version
4.5.0
Operating System
Ubuntu 22.04
