Hi
Thank you for your inquiry about accessing the DOCA SDK v3.0.0 header files and libraries for Ubuntu, specifically for `doca_comm_channel.h` and related components.
## Solution
To access the DOCA SDK v3.0.0 header files and libraries for Ubuntu host, you need to:
1. **Create a NVIDIA Developer account** (if you don’t already have one)
2. **Download the DOCA Host package** for your specific Ubuntu version
3. **Install the package** on your host system
## Detailed Instructions
### 1. Create an NVIDIA Developer Account
If you don’t already have an NVIDIA Developer account:
- Visit https://developer.nvidia.com/
- Click on “Join” or “Sign Up” and follow the registration process
### 2. Download the DOCA Host Package
1. Go to the NVIDIA DOCA downloads page: NVIDIA DOCA Downloads | NVIDIA Developer
2. Log in with your NVIDIA Developer account
3. Select “DOCA 3.0.0” as the version
4. Select “Host” as the deployment platform
5. Select “Ubuntu” as your operating system and your specific version (e.g., Ubuntu 22.04)
6. Select “doca-host-repo” as the package type
7. Download the appropriate .deb package for your system
### 3. Install the Package
Once downloaded, install the repository package:
```bash
sudo apt-get update
sudo apt install ./doca-host-repo-ubuntu-3.0.0-.deb
sudo apt-get update
Then install the DOCA SDK development package:
```bash
sudo apt-get install doca-sdk
This will install all necessary header files and libraries, including `doca_comm_channel.h`, in the standard locations:
- Headers: `/opt/mellanox/doca/include/`
- Libraries: `/opt/mellanox/doca/lib/`
### 4. Set Up Your Development Environment
To compile applications using the DOCA SDK:
1. Add the DOCA include and library paths to your build environment:
```bash
export CPATH=$CPATH:/opt/mellanox/doca/include
export LIBRARY_PATH=$LIBRARY_PATH:/opt/mellanox/doca/lib
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/opt/mellanox/doca/lib
2. When compiling your application, link against the required DOCA libraries:
```bash
gcc -I/opt/mellanox/doca/include -L/opt/mellanox/doca/lib your_app.c -ldoca_comm_channel -o your_app
## Additional Resources
- DOCA Documentation: DOCA Documentation v3.0.0 - NVIDIA Docs
- DOCA Communication Channel API: DOCA Comch - NVIDIA Docs
- DOCA Sample Applications: https://github.com/NVIDIA/doca-samples
