To address your issue, I’ll provide a step-by-step solution to flash only the boot image on your Jetson AGX Orin without re-flashing the entire system.
Understanding the Problem
When you flash a new boot image to the Jetson AGX Orin, the system reboots continuously and fails to enter the Ubuntu desktop. This is likely due to a mismatch between the boot image and the root file system (rootfs).
Solution
To flash only the boot image without re-flashing the entire system, you can use the flash.sh script provided by NVIDIA. Here’s a step-by-step guide:
- Put the device into recovery mode: Connect your Jetson AGX Orin to your host machine using a USB cable. Open a terminal on your host machine and run the following command to put the device into recovery mode:
$ sudo ./flash.sh -r jetson-agx-orin-devkit
This will reboot the device into recovery mode.
- Flash the boot image: Once the device is in recovery mode, run the following command to flash the new boot image:
$ sudo ./flash.sh -k boot.img jetson-agx-orin-devkit
Replace boot.img with the path to your new boot image file.
- Reboot the device: After flashing the boot image, reboot the device:
This will reboot the device normally.
Comparison with Full Flashing
Flashing only the boot image is different from flashing the entire system. When you flash the entire system, the flash.sh script will erase the entire device, including the root file system (rootfs), and re-flash everything. This is not what you want, as you have important files in the rootfs.
By flashing only the boot image, you can update the boot image without touching the rootfs. This approach is useful when you only need to update the boot image, and you don’t want to lose your files in the rootfs.
Additional Tips
- Make sure you have the correct boot image file for your Jetson AGX Orin device.
- If you’re using a custom boot image, ensure that it’s compatible with your device and the rootfs.
- If you encounter any issues during the flashing process, try re-flashing the entire system or seeking help from NVIDIA support.
I hope this helps you resolve your issue and flash only the boot image on your Jetson AGX Orin without re-flashing the entire system.
