NetworkDirect API: Loading of "NDv2 Provider for Mellanox WinOF-2" requires admin privileges
Hello everybody,
I have an issue in my NetworkDirect RDMA application when loading the Mellanox NDv2 provider. It seems as the newer WinOF-2 driver for ConnectX-4 IB HCAs (mlx5nd.dll) requires that the connecting process has adminstrator privileges.
Because when running my application with normal user privileges, I get an error 0x80070005 (Access denied), whereas this has never been an issue with the older WinOF driver for ConnectX-3 HCAs (mlx4nd.dll).
Here the failing code sequence from my ndhelper.cpp:
static HMODULE g_hProvider = NULL;
static IND2Provider g_pIProvider = NULL;
static HRESULT LoadProvider( __in WSAPROTOCOL_INFOW* pProtocol )
WCHAR* pPath = ::GetProviderPath( pProtocol ); // %SystemRoot%\System32\mlx5nd.dll
g_hProvider = ::LoadLibraryW( pPath );
::HeapFree( ::GetProcessHeap(), 0, pPath );
DLLGETCLASSOBJECT pfnDllGetClassObject = reinterpret_cast(
::GetProcAddress( g_hProvider, “DllGetClassObject” )
DLLGETCLASSOBJECT pfnDllCanUnloadNow = reinterpret_cast(
::GetProcAddress(g_hProvider, “DllCanUnloadNow”)
IClassFactory* pClassFactory;
HRESULT hr = pfnDllGetClassObject(
pProtocol->ProviderId,
IID_IClassFactory,
reinterpret_cast<void**>(&pClassFactory)
if (g_pIProvider == NULL) {
hr = pClassFactory->CreateInstance(
NULL,
IID_IND2Provider,
reinterpret_cast<void**>(&g_pIProvider)
if (FAILED(hr)) {
TRACE(“ClassFactory->CreateInstance(IID_IND2Provider) failed with error 0x%08X”, hr); // Without having admin rights, always ending up here!
pClassFactory->Release();
Unfortunately, just giving my process admin privileges is not an option for me. So I would appreciate if someone has an idea how to overcome this issue.
Perhaps some tuning of security configuration via dcomcnfg or the like(?)
BTW: The Mellanox-provided tools nd_read_bw.exe and nd_write_bw.exe have the same behavior:
  • Those from WinOF driver 5.35 on ConnectX-3 FDR HCA can run WITH or WITHOUT admin privileges.
  • Those from WinOF-2 driver 1.80 on ConnectX-4 EDR HCA can run only WITH admin privileges.
My system configuration:
  • HPE DL380Gen10
  • ConnectX-4 EDR Infiniband HCA (HPEIB EDR/EN 100Gb 2P 840QSFP28)
  • Windows Server 2012 R2
  • Mellanox WinOF-2 version 1.80
Thanks and Regards
