New AGX Thor Dev Kit – module EEPROM (CVM) reads all 0xFF, flash fails with "Target board not found" (SDKM error 607)
I have a brand-new Jetson AGX Thor Developer Kit, just taken out
of the box and never flashed before. Flashing fails before any write to the device because
the module EEPROM (CVM) reads back as all 0xFF.
Setup
  • Host: native Ubuntu 24.04.4 LTS (x86_64, kernel 6.17.0-1032-oem), no VM
  • SDK Manager 26.1.0-14392, JetPack 7.2.2
  • Host USB connected to USB-C port 5a (next to HDMI), power supply on port 5b
  • Board in Force Recovery Mode: lsusb shows “0955:7026 NVIDIA Corp. APX”
Symptom
SDK Manager reports “The connected Jetson device is not ready for flash / non-optimal USB
connection”. The SDKM log shows “Bootrom status check failed”, errorCode=607.
Running the check directly gives the same result:
sudo ./nvsdkmanager_flash.sh --check-all
Parsing module EEPROM:
— Parsing board ID (ERROR: calculated CRC8 0x35 != stored CRC8 0xff) succeeded.
— Parsing board version (ERROR: calculated CRC8 0x35 != stored CRC8 0xff) succeeded.
— Parsing board SKU (ERROR: calculated CRC8 0x35 != stored CRC8 0xff) succeeded.
— Parsing board REV (ERROR: calculated CRC8 0x35 != stored CRC8 0xff) succeeded.
Parsing baseboard EEPROM:
— Parsing baseboard ID (4071) succeeded.
Error: Target board not found.
Error: Parsing boardid failed.
What works
  • RCM communication: BR BCT, MB1, PSC BL1 and the MB2 applet download fine
    (BL version 0.25.1.2-t264-75019003-d5e8c900, last_boot_error: 0, MB2 Applet 01.00.0000)
  • Chip info: Chip SKU 0xA0, ramcode 0xC, chip minor rev 1, prod, fuselevel_production
  • Carrier board EEPROM (cvb.bin): valid data (699-14071-0000-200 H.1, 675-14070-0080-V00),
    CRC-8 matches the stored value (0xFB)
What fails
  • Module EEPROM dump bootloader/cvm.bin = 256 bytes, all 0xFF.
    The CRC-8 of 255 x 0xFF is 0x35, which matches the reported “calculated 0x35 != stored 0xff”.
    So the module EEPROM is either unprogrammed or not responding on I2C.
What I ruled out
  • USB: correct port (5a), two different USB-C cables, two host ports, no hub,
    USB autosuspend disabled. No USB errors in dmesg.
  • Host: rebooted (this also fixed an NVIDIA host driver version mismatch). No VM.
  • Power: full power cycle of the dev kit (power unplugged for ~60s).
  • Result is identical across 3 attempts (before and after host reboot, after power cycle).
I can send the cvb.bin, serial numbers, BR_CID and the full SDK Manager logs privately if needed.
Questions
  1. Is this a known factory defect (unprogrammed or faulty module EEPROM) that qualifies for RMA?
  2. If not, is there an official procedure to restore the module (CVM) EEPROM contents,
    or a supported way to flash with the board ID provided manually?
