We have managed to run isaac_ros_dnn_stereo_depth on ORIN NANO(8GB) / JP5.1.2, with HAWK stereo camera, although the disparity fps is much lower than that on ORIN.
Here we have several questions about NITROS and ESS DNN:
- No outputs from cmd ‘ros2 topic hz /disparity/nitros’, or /left/image_raw/nitros, /right/image_raw/nitros, and other topics ended with /nitros.
Instead, we can get outputs from ‘ros2 topic hz /disparity’, and other topics not ended with ‘/nitros’.
Why is there no ‘nitros’ topic/msg, if the msg is transported by NITROS?
Here is the list of ROS2 topics from ‘ros2 topic list’:
/disparity
/disparity/nitros
/left/camera_info_rect
/left/camera_info_rect/nitros
/left/camerainfo
/left/camerainfo/nitros
/left/camerainfo_resize
/left/camerainfo_resize/nitros
/left/image_raw
/left/image_rect
/left/image_rect/nitros
/left/image_resize
/left/image_resize/nitros
/left/image_resize/nitros/nitros_image_rgb8
/parameter_events
/points2
/points2/nitros
/right/camera_info_rect
/right/camera_info_rect/nitros
/right/camerainfo
/right/camerainfo/nitros
/right/camerainfo_resize
/right/camerainfo_resize/nitros
/right/image_raw
/right/image_rect
/right/image_rect/nitros
/right/image_rect/nitros/nitros_image_rgb8
/right/image_resize
/right/image_resize/nitros
/right/image_resize/nitros/nitros_image_rgb8
/rosout
/tf
- Some type negotiation failed in NITROS
From the log file of the ESS DNN application:
[INFO] [1714056728.410497542] [left_rectify_node]: [NitrosNode] Obtaining graph IO group info from the optimizer
[INFO] [1714056728.412414512] [left_rectify_node]: [NitrosNode] Creating negotiated publishers/subscribers
[INFO] [1714056728.424427220] [left_rectify_node]: [NitrosNode] Starting negotiation…
[INFO] [1714056728.430721821] [left_rectify_node]: Negotiating
[INFO] [1714056728.430786366] [left_rectify_node]: Could not negotiate
[INFO] [1714056728.430817759] [left_rectify_node]: Negotiating
[INFO] [1714056728.430833375] [left_rectify_node]: Could not negotiate
[INFO] [1714056729.000550111] [left_rectify_node]: Negotiating
[INFO] [1714056729.006689348] [left_rectify_node]: Negotiating
[INFO] [1714056729.259069732] [left_rectify_node]: Negotiating
[INFO] [1714056729.259222887] [left_rectify_node]: Could not negotiate
[INFO] [1714056729.261737918] [left_rectify_node]: Negotiating
[INFO] [1714056729.261828800] [left_rectify_node]: Could not negotiate
[INFO] [1714056729.262812789] [left_rectify_node]: Negotiating
[INFO] [1714056729.263392514] [left_rectify_node]: Negotiating
[INFO] [1714056729.426119082] [left_rectify_node]: [NitrosNode] Starting post negotiation setup
[INFO] [1714056729.426255053] [left_rectify_node]: [NitrosNode] Getting data format negotiation results
[INFO] [1714056729.426280718] [left_rectify_node]: [NitrosPublisher] Negotiation ended with no results
[INFO] [1714056729.426299214] [left_rectify_node]: [NitrosPublisher] Use only the compatible publisher: topic_name=“/left/image_rect”, data_format=“nitros_image_bgr8”
[INFO] [1714056729.426317614] [left_rectify_node]: [NitrosPublisher] Use the negotiated data format: “nitros_camera_info”
[INFO] [1714056729.426333327] [left_rectify_node]: [NitrosSubscriber] Use the negotiated data format: “nitros_image_rgb8”
[INFO] [1714056729.428122677] [left_rectify_node]: [NitrosSubscriber] Use the negotiated data format: “nitros_camera_info”
[INFO] [1714056729.428241976] [left_rectify_node]: [NitrosPublisherSubscriberGroup] Adjusted the compatible format of the component “image_sink/sink” (type=“nvidia::isaac_ros::MessageRelay”) from “nitros_image_bgr8” to “nitros_image_rgb8”
[INFO] [1714056730.000420045] [disparity]: [NitrosNode] Starting post negotiation setup
[INFO] [1714056730.000553264] [disparity]: [NitrosNode] Getting data format negotiation results
[INFO] [1714056730.000582897] [disparity]: [NitrosPublisher] Use the negotiated data format: “nitros_disparity_image_32FC1”
[INFO] [1714056730.000602641] [disparity]: [NitrosSubscriber] Negotiation ended with no results
[INFO] [1714056730.000617266] [disparity]: [NitrosSubscriber] Use the compatible subscriber: topic_name=“/left/image_rect”, data_format=“nitros_image_rgb8”
[INFO] [1714056730.000631794] [disparity]: [NitrosSubscriber] Use the negotiated data format: “nitros_image_rgb8”
[INFO] [1714056730.000646770] [disparity]: [NitrosSubscriber] Use the negotiated data format: “nitros_camera_info”
[INFO] [1714056730.000659923] [disparity]: [NitrosSubscriber] Use the negotiated data format: “nitros_camera_info”
[INFO] [1714056730.001036987] [disparity]: [NitrosNode] Exporting the final graph based on the negotiation results
[INFO] [1714056730.194574827] [disparity]: [NitrosNode] Wrote the final top level YAML
Why did these NITROS negotiations fail?
Is there anything wrong with the application?
