Hi, I’m trying to factory reset (by reflashing the OS through SDK Manager) an Jetson AGX Xavier system. I’ve downloaded the SDK manager and put the system into recovery mode. It detects the xavier but the target operating system just reads “No Available Resources for Linux” so I’m stuck! Any ideas what I’m doing wrong.
I put the system into recovery mode by “powering on, press and hold the factory reset button, press and release the reset button, and then after 2s release the factory reset button”. Typing lsusb on the command line shows “Nvidia Corp” as expected.
Looks like an access issue from the verbose logging…
08:32:00.114 - info: Event: Login Progress: Loading and processing available products…
08:32:00.209 - info: sdkml2_drive_qnx.json from https://developer.download.nvidia.com/sdkmanager/sdkm-config/DRIVE/QNX/sdkml2_drive_qnx.json has been downloaded to /home/jonathan/.nvsdkm/dist successfully.
08:32:00.433 - info: validating product line for target OS: QNX
08:32:00.434 - info:
08:32:00.434 - info: validating release: DRIVE OS 5.2.3 SDK
08:32:00.434 - warn: No access to devzone program id -1
08:32:00.434 - warn: No access to release DRIVE OS 5.2.3 SDK.
08:32:00.435 - info:
08:32:00.435 - info: validating release: DRIVE OS 5.2.0 SDK
08:32:00.435 - warn: No access to devzone program id -1
08:32:00.435 - warn: No access to release DRIVE OS 5.2.0 SDK.
08:32:00.435 - info: validating release: DRIVE OS 5.1.15.0 SDK
08:32:00.436 - warn: No access to release DRIVE OS 5.1.15.0 SDK.
08:32:00.675 - info: Selecting Jetson product
08:32:00.676 - verbose: loadStage1: complete
Moving this topic to the Jetson AGX Xavier forum.
Hi jon,
Can you please share the full log and a screenshot of the error?
