I’m using SDK manager on a host Ubuntu computer to reset my Xavier board ( I want to reinstall OS and some jetson sdk components). The problem is that after the Jetson OS image is downloaded and finished flashing Jetson OS, my Xavier only shows a Nvidia logo on screen but no ubuntu setting pages after that.
I don’t understand the problem because the SDK manager said that the Jetson OS is successfully flashed but my Xavier is not working.
Here is the SDK manage logs
- 18:21:19 INFO : Flash Jetson AGX Xavier : *** The target t186ref has been flashed successfully. ***
- 18:21:19 INFO : Flash Jetson AGX Xavier : Reset the board to boot from internal eMMC.
- 18:21:19 INFO : Flash Jetson AGX Xavier : exec_command: sleep 20
- 18:21:39 INFO : Flash Jetson AGX Xavier : [ Component Install Finished Successfully ]
- 18:21:39 INFO : Flash Jetson AGX Xavier : [ 3.98 MB used. Disk Avail: 461.33 GB ]
- 18:21:39 INFO : Flash Jetson AGX Xavier : [ NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP Install took 5m38s ]
- 18:21:39 INFO : Flash Jetson AGX Xavier : command finished successfully
- 18:21:39 INFO : Flash Jetson AGX Xavier : install ‘Flash Jetson AGX Xavier’ success
- 18:21:51 DEBUG : running command < [
lsusb | grep -c "0955:"-ne 1 ] > - 18:21:51 DEBUG : command terminated with error
- 18:21:51 INFO : Only one nvidia device detected, as expected.
- 18:21:51 DEBUG : running command < ip addr | grep 192.168.55.1 >
- 18:21:51 ERROR : Could not connect to the target device. Verify that: 1. The device is connected to this host machine with a USB cable. 2. Ubuntu ‘System configuration wizard’ is completed on the device. 3. Jetson’s Ubuntu OS is up and running. 4. Jetson usb device mode service is started successfully. * See readme file in the auto-mounted “L4T-README” folder for more details.
- 18:21:54 DEBUG : running command < [
lsusb | grep -c "0955:"-ne 1 ] > - 18:21:54 DEBUG : command terminated with error
- 18:21:54 INFO : Only one nvidia device detected, as expected.
- 18:21:54 DEBUG : running command < ip addr | grep 192.168.55.1 >
- 18:21:54 ERROR : Could not connect to the target device. Verify that: 1. The device is connected to this host machine with a USB cable. 2. Ubuntu ‘System configuration wizard’ is completed on the device. 3. Jetson’s Ubuntu OS is up and running. 4. Jetson usb device mode service is started successfully. * See readme file in the auto-mounted “L4T-README” folder for more details.
