No display for gpu error
Hi, we update rootfs, and then the device cann’t dispaly, the below is the uart log:
[ 7.814031] tegra_cec 70015000.tegra_cec: Sent res: -62.
[ 7.822139] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 10.616870] gk20a 57000000.gpu: Direct firmware load for gm20b/acr_ucode.bin failed with error -2
[ 10.625765] gk20a 57000000.gpu: Falling back to user helper
[ 10.633042] nvgpu: 57000000.gpu gm20b_bootstrap_hs_acr:1279 [ERR] acr_ucode.bin ucode get fail for gm20b
[ 10.643591] nvgpu: 57000000.gpu gk20a_finalize_poweron:327 [ERR] ACR bootstrap failed
[ 10.658128] gk20a 57000000.gpu: Direct firmware load for gm20b/acr_ucode.bin failed with error -2
[ 10.667106] gk20a 57000000.gpu: Falling back to user helper
[ 10.673567] nvgpu: 57000000.gpu gm20b_bootstrap_hs_acr:1279 [ERR] acr_ucode.bin ucode get fail for gm20b
[ 10.684226] nvgpu: 57000000.gpu gk20a_finalize_poweron:327 [ERR] ACR bootstrap failed
[ 13.384045] gk20a 57000000.gpu: Direct firmware load for gm20b/acr_ucode.bin failed with error -2
[ 13.392936] gk20a 57000000.gpu: Falling back to user helper
[ 13.399522] nvgpu: 57000000.gpu gm20b_bootstrap_hs_acr:1279 [ERR] acr_ucode.bin ucode get fail for gm20b
[ 13.410087] nvgpu: 57000000.gpu gk20a_finalize_poweron:327 [ERR] ACR bootstrap failed
[ 13.424644] gk20a 57000000.gpu: Direct firmware load for gm20b/acr_ucode.bin failed with error -2
[ 13.433566] gk20a 57000000.gpu: Falling back to user helper
[ 13.440710] nvgpu: 57000000.gpu gm20b_bootstrap_hs_acr:1279 [ERR] acr_ucode.bin ucode get fail for gm20b
[ 13.451294] nvgpu: 57000000.gpu gk20a_finalize_poweron:327 [ERR] ACR bootstrap failed
[ 13.861117] gk20a 57000000.gpu: Direct firmware load for gm20b/acr_ucode.bin failed with error -2
[ 13.870035] gk20a 57000000.gpu: Falling back to user helper
[ 13.877256] nvgpu: 57000000.gpu gm20b_bootstrap_hs_acr:1279 [ERR] acr_ucode.bin ucode get fail for gm20b
[ 13.887872] nvgpu: 57000000.gpu gk20a_finalize_poweron:327 [ERR] ACR bootstrap failed
[ 13.902647] gk20a 57000000.gpu: Direct firmware load for gm20b/acr_ucode.bin failed with error -2
[ 13.911680] gk20a 57000000.gpu: Falling back to user helper
[ 13.918067] nvgpu: 57000000.gpu gm20b_bootstrap_hs_acr:1279 [ERR] acr_ucode.bin ucode get fail for gm20b
[ 13.928621] nvgpu: 57000000.gpu gk20a_finalize_poweron:327 [ERR] ACR bootstrap failed
[ 14.141706] gk20a 57000000.gpu: Direct firmware load for gm20b/acr_ucode.bin failed with error -2
[ 14.150760] gk20a 57000000.gpu: Falling back to user helper
[ 14.158577] nvgpu: 57000000.gpu gm20b_bootstrap_hs_acr:1279 [ERR] acr_ucode.bin ucode get fail for gm20b
[ 14.169153] nvgpu: 57000000.gpu gk20a_finalize_poweron:327 [ERR] ACR bootstrap failed
[ 14.183788] gk20a 57000000.gpu: Direct firmware load for gm20b/acr_ucode.bin failed with error -2
[ 14.192887] gk20a 57000000.gpu: Falling back to user helper
[ 14.200372] nvgpu: 57000000.gpu gm20b_bootstrap_hs_acr:1279 [ERR] acr_ucode.bin ucode get fail for gm20b
[ 14.211246] nvgpu: 57000000.gpu gk20a_finalize_poweron:327 [ERR] ACR bootstrap failed
[ 14.242575] gk20a 57000000.gpu: Direct firmware load for gm20b/acr_ucode.bin failed with error -2
[ 14.251844] gk20a 57000000.gpu: Falling back to user helper
[ 14.261255] nvgpu: 57000000.gpu gm20b_bootstrap_hs_acr:1279 [ERR] acr_ucode.bin ucode get fail for gm20b
[ 14.271858] nvgpu: 57000000.gpu gk20a_finalize_poweron:327 [ERR] ACR bootstrap failed
[ 14.324572] gk20a 57000000.gpu: Direct firmware load for gm20b/acr_ucode.bin failed with error -2
[ 14.334157] gk20a 57000000.gpu: Falling back to user helper
[ 14.341772] nvgpu: 57000000.gpu gm20b_bootstrap_hs_acr:1279 [ERR] acr_ucode.bin ucode get fail for gm20b
[ 14.352561] nvgpu: 57000000.gpu gk20a_finalize_poweron:327 [ERR] ACR bootstrap failed
[ 14.426124] gk20a 57000000.gpu: Direct firmware load for gm20b/acr_ucode.bin failed with error -2
[ 14.435110] gk20a 57000000.gpu: Falling back to user helper
[ 14.442506] nvgpu: 57000000.gpu gm20b_bootstrap_hs_acr:1279 [ERR] acr_ucode.bin ucode get fail for gm20b
[ 14.453063] nvgpu: 57000000.gpu gk20a_finalize_poweron:327 [ERR] ACR bootstrap failed
[ 14.468274] gk20a 57000000.gpu: Direct firmware load for gm20b/acr_ucode.bin failed with error -2
[ 14.477317] gk20a 57000000.gpu: Falling back to user helper
[ 14.485080] nvgpu: 57000000.gpu gm20b_bootstrap_hs_acr:1279 [ERR] acr_ucode.bin ucode get fail for gm20b
[ 14.495650] nvgpu: 57000000.gpu gk20a_finalize_poweron:327 [ERR] ACR bootstrap failed
[ 14.821291] gk20a 57000000.gpu: Direct firmware load for gm20b/acr_ucode.bin failed with error -2
[ 14.830301] gk20a 57000000.gpu: Falling back to user helper
[ 14.837651] nvgpu: 57000000.gpu gm20b_bootstrap_hs_acr:1279 [ERR] acr_ucode.bin ucode get fail for gm20b
[ 14.848268] nvgpu: 57000000.gpu gk20a_finalize_poweron:327 [ERR] ACR bootstrap failed
[ 14.862650] gk20a 57000000.gpu: Direct firmware load for gm20b/acr_ucode.bin failed with error -2
[ 14.871516] gk20a 57000000.gpu: Falling back to user helper
[ 14.878886] nvgpu: 57000000.gpu gm20b_bootstrap_hs_acr:1279 [ERR] acr_ucode.bin ucode get fail for gm20b
[ 14.889486] nvgpu: 57000000.gpu gk20a_finalize_poweron:327 [ERR] ACR bootstrap failed
[ 15.074955] gk20a 57000000.gpu: Direct firmware load for gm20b/acr_ucode.bin failed with error -2
[ 15.084582] gk20a 57000000.gpu: Falling back to user helper
[ 15.091922] nvgpu: 57000000.gpu gm20b_bootstrap_hs_acr:1279 [ERR] acr_ucode.bin ucode get fail for gm20b
[ 15.102718] nvgpu: 57000000.gpu gk20a_finalize_poweron:327 [ERR] ACR bootstrap failed
[ 15.117151] gk20a 57000000.gpu: Direct firmware load for gm20b/acr_ucode.bin failed with error -2
[ 15.126272] gk20a 57000000.gpu: Falling back to user helper
[ 15.133435] nvgpu: 57000000.gpu gm20b_bootstrap_hs_acr:1279 [ERR] acr_ucode.bin ucode get fail for gm20b
[ 15.144199] nvgpu: 57000000.gpu gk20a_finalize_poweron:327 [ERR] ACR bootstrap failed
Ubuntu 18.04.6 LTS localhost.localdomain ttyS0
localhost login:
What did you change in rootfs?
我们在新制作rootfs时,采用ustc路径, 之前不是,之前应该就是ubuntu-base-18.04.6-base-arm64默认的,其他的不变,我认为这不应该影响gpu部分。
echo “deb Index of /ubuntu-ports/ bionic main” > /tmp/mk-base-ubuntu-sources.list
echo “deb http://mirrors.ustc.edu.cn/ubuntu-ports/ bionic-updates main” >> /tmp/mk-base-ubuntu-sources.list
echo “deb http://mirrors.ustc.edu.cn/ubuntu-ports/ bionic universe” >> /tmp/mk-base-ubuntu-sources.list
echo “deb http://mirrors.ustc.edu.cn/ubuntu-ports/ bionic-updates universe” >> /tmp/mk-base-ubuntu-sources.list
echo “deb http://mirrors.ustc.edu.cn/ubuntu-ports/ bionic multiverse” >> /tmp/mk-base-ubuntu-sources.list
echo “deb http://mirrors.ustc.edu.cn/ubuntu-ports/ bionic-updates multiverse” >> /tmp/mk-base-ubuntu-sources.list
echo “deb http://mirrors.ustc.edu.cn/ubuntu-ports/ bionic-backports main restricted universe multiverse” >> /tmp/mk-base-ubuntu-sources.list
echo “deb http://mirrors.ustc.edu.cn/ubuntu-ports/ bionic-security main restricted” >> /tmp/mk-base-ubuntu-sources.list
echo “deb http://mirrors.ustc.edu.cn/ubuntu-ports/ bionic-security universe” >> /tmp/mk-base-ubuntu-sources.list
echo “deb http://mirrors.ustc.edu.cn/ubuntu-ports/ bionic-security multiverse” >> /tmp/mk-base-ubuntu-sources.list
sudo cp /tmp/mk-base-ubuntu-sources.list $TARGET_ROOTFS_DIR/etc/apt/sources.list
error no “-2” means the “No such file or directory”.
开机的logo画面可以显示,但进入kernel后,就开始出现gpu error, 但这个rootfs在我们把L4T 升级到R32.7.3上不会出错,在r32.5.1上会出这个错误。
之所以会有这个发现是:原本我们升级到R32.7.3时,使用之前的rootfs也是会出这个错误,所以修改了下rootfs后,尽然可以了,比较困惑,现象上看确实跟rootfs有关系
Boot logo is from cboot. Nothing to do with rootfs…
有命令可以重启下gpu吗,或者这个错误跟时序有没有什么关系
我大概知道什么原因了,你们从32.5.1升级到32.7.3时一些在rootfs中的deb包有更新,所以如果我们只升级L4T,不升级rootfs就会有问题
