Here is my problem. I have a Nvidia Quadro RTX 4000 installed on my ubuntu 18.04 workstation. I do not manage to get a graphics output from the nvidia card, instead I am using the output from the onboard aspeed graphics card.
I have installed Cuda 10.1 according to the nvidia website and my card is found by nvidia-smi
| NVIDIA-SMI 418.87.01 Driver Version: 418.87.01 CUDA Version: 10.1 |
| 0 Quadro RTX 4000 On | 00000000:AF:00.0 Off | N/A |
| 30% 38C P8 1W / 125W | 0MiB / 7952MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
If I start nvidia-settings I get an error message
ERROR: Unable to load info from any available system
If I want to start for instance the particles cuda test program a window opens and closes again immediately with the output
CUDA Particles Simulation Starting...
NOTE: The CUDA Samples are not meant for performance measurements. Results may vary when GPU Boost is enabled.
grid: 64 x 64 x 64 = 262144 cells
particles: 16384
GPU Device 0: "Quadro RTX 4000" with compute capability 7.5
CUDA error at particleSystem_cuda.cu:79 code=999(cudaErrorUnknown) "cudaGraphicsGLRegisterBuffer(cuda_vbo_resource, vbo, cudaGraphicsMapFlagsNone)"
Interestingly BOINC finds the graphics card and can run CUDA and OpenCL code.
I am really confused about this problem. I will also attach the nvidia bug report.
nvidia-bug-report.log.gz (1.18 MB)
