No matching GPU found with 510.47.03
I’m trying new driver and nvidia-powerd.service is failing to start
systemctl status nvidia-powerd.service
/usr/bin/nvidia-powerd[1439]: nvidia-powerd version:1.0(build 1)
/usr/bin/nvidia-powerd[1439]: No matching GPU found
/usr/bin/nvidia-powerd[1439]: Failed to initialize RM Client
systemd[1]: nvidia-powerd.service: Main process exited, code=exited, status=1/FAILURE
systemd[1]: nvidia-powerd.service: Failed with result 'exit-code'.
systemd[1]: Failed to start nvidia-powerd service.
GPU: 3080 Ti
CPU: Intel i9 12900k
OS: Fedora 35
Kernel: 5.16.5
DE: Gnome 41.3
Windowing System: both Wayland and Xorg
Nvidia Drivers (installed from RPM Fusion): 510.47.03
AMD cpu?
Intel i9 12900k
AFAIK nvidia-powerd by now only supports some Intel cpus and no AMD cpus. And it is at its current state not enabled by default, but meant for distros to test. Anyways you can ignore the message and disable or mask the systemd unit.
Moreover, nvidia-powerd is only for mobile gpus (“No matching GPU”), so running it on a desktop system is useless. Just disable it.
