since my last Ubuntu update which was yesterday, after my vacation, I have noticed that the service nvidia-powerd is not working anymore and instead of suspend I get a log out…
------------------------ systemctl output begin----------------
sudo systemctl status nvidia-powerd.service
● nvidia-powerd.service - nvidia-powerd service
Loaded: loaded (/lib/systemd/system/nvidia-powerd.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Wed 2022-08-31 12:34:23 CEST; 6min ago
Process: 2063 ExecStart=/usr/bin/nvidia-powerd (code=exited, status=1/FAILURE)
Main PID: 2063 (code=exited, status=1/FAILURE)
Aug 31 12:34:22 hostname systemd[1]: Starting nvidia-powerd service…
Aug 31 12:34:22 hostname /usr/bin/nvidia-powerd[2063]: nvidia-powerd version:1.0(build 1)
Aug 31 12:34:23 hostname /usr/bin/nvidia-powerd[2063]: No matching GPU found
Aug 31 12:34:23 hostname /usr/bin/nvidia-powerd[2063]: Failed to initialize RM Client
Aug 31 12:34:23 hostname systemd[1]: nvidia-powerd.service: Main process exited, code=exited, status=1/FAILURE
Aug 31 12:34:23 hostname systemd[1]: nvidia-powerd.service: Failed with result ‘exit-code’.
Aug 31 12:34:23 hostname systemd[1]: Failed to start nvidia-powerd service.
------------------------ systemctl output end----------------
----------------------nvidia-smi partial output begin---------------
nvidia-smi
Wed Aug 31 12:43:48 2022
| NVIDIA-SMI 515.65.01 Driver Version: 515.65.01 CUDA Version: 11.7 |
| | | MIG M. |
| 0 NVIDIA GeForce … On | 00000000:08:00.0 On | N/A |
| 0% 39C P8 21W / 170W | 921MiB / 12288MiB | 1% Default |
| | | N/A |
----------------------nvidia-smi output end---------------
----------------------- inxi output begin-------------------------
Distro: Ubuntu 20.04.5 LTS (Focal Fossa)
inxi -Gxx
Graphics: Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: ASUSTeK driver: nvidia v: 515.65.01
bus ID: 08:00.0 chip ID: 10de:2504
Display: x11 server: X.Org 1.20.13 driver: nvidia compositor: gnome-shell
resolution: 1920x1080~60Hz, 1920x1080~60Hz
OpenGL: renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2 v: 4.6.0 NVIDIA 515.65.01 direct render: Yes
------------------------ inxi output end -------------------------------
Is there anybody else with such an issue?
Thanks,
Alexandru
nvidia-bug-report.log.gz (353.7 KB)
