I have download a few months ago a trt_pose python file of jetcam module. Now I have download the jetson-inference module, but since the download of jetson-inference when I want to launch trt_pose with the line command ./trt_working.py, it tells me File "./trt_working.py", line 3, in <module>from jetcam.utils import bgr8_to_jpeg ModuleNotFoundError : No module named 'jetcam'
PS : I didn’t move the project file and its architecture.
What is the problem?
Thanks for your help.
T.
Since the script cannot file the jetcam module.
Would you mind to reinstall jetcam to see if it helps?
Thanks @AastaLLL for your help.
I reinstalled it in vain …
vraiplus@vraiplus-jetson:~/Documents/trt_pose/tasks/human_pose$ ./trt_working.pyTraceback (most recent call last): File "./trt_working.py", line 3, in <module> from jetcam.utils import bgr8_to_jpeg File "/usr/local/lib/python3.7/dist-packages/jetcam-0.0.0-py3.7.egg/jetcam/__init__.py", line 1, in <module> File "/usr/local/lib/python3.7/dist-packages/jetcam-0.0.0-py3.7.egg/jetcam/camera.py", line 1, in <module> ModuleNotFoundError: No module named 'traitlets'
Could you try below command to see if it helps?
$ sudo pip3 install traitlets
