Hello, I am trying to run a python script generated from the notebook “csi_camera.ipynb” of the example of AI course. I am new to jupyter lab, so sorry if this a basic approach.
Well, I already generated the file “csi_camera.py” with jupyter nbconvert.
The first error that I found is the “get_iphython is not defined”. I commented this line to proceed with the code execution. Is that ok?
The error that I have, after commenting the previous line, is the “Import Error: No module named jetcam.csi_camera”.
The code runs ok from the notebook, but not from the python script. How to proceed to import it properly? Thank you.
I’m closing this topic due to there is no update from you for a period, assuming this issue was resolved.
If still need the support, please open a new topic. Thanks
If you are following the Jetson AI Fundamentals course, then you don’t need to use JetCard image, just flash the official NVIDIA JetPack SD card image:
