No stream from sensor with CHANSEL_NOMATCH
I am using xavier NX . I get MIPI data from sensor. I have probed and confirmed it . But I am not getting stream in argus framework.I get the reace logs as mentioned below.
orker/0:0-11105 [000] … 6613.099171: rtcpu_vinotify_event: tstamp:206913127711 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:206912992460 data:0x000006e9
kworker/0:0-11105 [000] … 6613.099171: rtcpu_vinotify_error: tstamp:206913497776 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:206913496928 data:0x000000a0
kworker/0:0-11105 [000] … 6613.099171: rtcpu_vinotify_error: tstamp:206913512634 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:206913511799 data:0x000000a0
kworker/0:0-11105 [000] … 6613.099171: rtcpu_vinotify_event: tstamp:206913805321 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:206913496928 data:0x000000a0
kworker/0:0-11105 [000] … 6613.099171: rtcpu_vinotify_event: tstamp:206913805457 tag:FS channel:0x00 frame:0 vi_tstamp:206913496928 data:0x00000010
kworker/0:0-11105 [000] … 6613.099171: rtcpu_vinotify_event: tstamp:206913805614 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:206913511799 data:0x000000a0
kworker/0:0-11105 [000] … 6613.099172: rtcpu_vinotify_event: tstamp:206913805749 tag:FS channel:0x00 frame:0 vi_tstamp:206913511799 data:0x00000010
kworker/0:0-11105 [000] … 6613.099172: rtcpu_vinotify_event: tstamp:206913805905 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:206913513292 data:0x000006e9
kworker/0:0-11105 [000] … 6613.099172: rtcpu_vinotify_error: tstamp:206914018608 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:206914017759 data:0x000000a0
kworker/0:0-11105 [000] … 6613.099172: rtcpu_vinotify_error: tstamp:206914033482 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:206914032630 data:0x000000a0
kworker/0:0-11105 [000] … 6613.099172: rtcpu_vinotify_event: tstamp:206914033770 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:206914017759 data:0x000000a0
kworker/0:0-11105 [000] … 6613.099172: rtcpu_vinotify_event: tstamp:206914033927 tag:FS channel:0x00 frame:0 vi_tstamp:206914017759 data:0x00000010
kworker/0:0-11105 [000] … 6613.099172: rtcpu_vinotify_event: tstamp:206914034063 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:206914032630 data:0x000000a0
kworker/0:0-11105 [000] … 6613.099172: rtcpu_vinotify_event: tstamp:206914348009 tag:FS channel:0x00 frame:0 vi_tstamp:206914032630 data:0x00000010
kworker/0:0-11105 [000] … 6613.099173: rtcpu_vinotify_event: tstamp:206914348147 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:206914034122 data:0x000006e9
kworker/0:0-11105 [000] … 6613.155172: rtcpu_vinotify_error: tstamp:206914539441 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:206914538589 data:0x000000a0
kworker/0:0-11105 [000] … 6613.155185: rtcpu_vinotify_error: tstamp:206914554308 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:206914553461 data:0x000000a0
kworker/0:0-11105 [000] … 6613.155185: rtos_queue_peek_from_isr_failed: tstamp:206914677828 queue:0x0bcbcf78
kworker/0:0-11105 [000] … 6613.155185: rtcpu_vinotify_event: tstamp:206914686945 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:206914538589 data:0x000000a0
kworker/0:0-11105 [000] … 6613.155186: rtcpu_vinotify_event: tstamp:206914687085 tag:FS channel:0x00 frame:0 vi_tstamp:206914538590 data:0x00000010
kworker/0:0-11105 [000] … 6613.155186: rtcpu_vinotify_event: tstamp:206914687248 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:206914553461 data:0x000000a0
kworker/0:0-11105 [000] … 6613.155186: rtcpu_vinotify_event: tstamp:206914687384 tag:FS channel:0x00 frame:0 vi_tstamp:206914553461 data:0x00000010
kworker/0:0-11105 [000] … 6613.155187: rtcpu_vinotify_event: tstamp:206914687545 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:206914554953 data:0x000006e9
kworker/0:0-11105 [000] … 6613.155188: rtcpu_vinotify_error: tstamp:206915060268 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:206915059421 data:0x000000a0
kworker/0:0-11105 [000] … 6613.155188: rtcpu_vinotify_error: tstamp:206915075130 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:206915074292 data:0x000000a0
kworker/0:0-11105 [000] … 6613.155188: rtcpu_vinotify_event: tstamp:206915365206 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:206915059421 data:0x000000a0
kworker/0:0-11105 [000] … 6613.155188: rtcpu_vinotify_event: tstamp:206915365369 tag:FS channel:0x00 frame:0 vi_tstamp:206915059421 data:0x00000010
kworker/0:0-11105 [000] … 6613.155189: rtcpu_vinotify_event: tstamp:206915365505 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:206915074292 data:0x000000a0
kworker/0:0-11105 [000] … 6613.155189: rtcpu_vinotify_event: tstamp:206915365661 tag:FS channel:0x00 frame:0 vi_tstamp:206915074292 data:0x00000010
kworker/0:0-11105 [000] … 6613.155189: rtcpu_vinotify_event: tstamp:206915365794 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:206915075783 data:0x000006e9
kworker/0:0-11105 [000] … 6613.155189: rtcpu_vinotify_error: tstamp:206915581103 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:206915580252 data:0x000000a0
kworker/0:0-11105 [000] … 6613.155189: rtcpu_vinotify_error: tstamp:206915595977 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:206915595123 data:0x000000a0
kworker/0:0-11105 [000] … 6613.155189: rtcpu_vinotify_event: tstamp:206915596264 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:206915580252 data:0x000000a0
kworker/0:0-11105 [000] … 6613.155189: rtcpu_vinotify_event: tstamp:206915596400 tag:FS channel:0x00 frame:0 vi_tstamp:206915580252 data:0x00000010
kworker/0:0-11105 [000] … 6613.155189: rtcpu_vinotify_event: tstamp:206915596558 tag:CSIMUX_FRAME channel:0x00 fr
Any hint on this ? How could I map this to any nvcsi/vi registers in TRM ?
Sorry for the late response, have you managed to get issue resolved? Thanks
It could be the embedded data output from sensor but device tree didn’t define the embedded_metadata_height correctly.
https://elinux.org/Jetson/l4t/Camera_BringUp
