Hello JerryChang,
Thanks for your previous reply, after some digging, the trace complains no more CHANSEL_FAULT, and v4l2-ctl command can now receive data. Really appreciate your help.
However, the received raw image is not correct. I checked the trace, findind it werid werid that the frame number is always 0, and there is no CHANSEL_LOAD_FRMAED.
What does this possibily mean?
My trace is as below
# tracer: nop
# entries-in-buffer/entries-written: 5198/5198 #P:6
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/1:3-252 [001] .... 140.621372: rtos_queue_peek_from_isr_failed: tstamp:4723833275 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 140.774370: rtos_queue_peek_from_isr_failed: tstamp:4728833276 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 140.927357: rtos_queue_peek_from_isr_failed: tstamp:4733833278 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 141.131356: rtos_queue_peek_from_isr_failed: tstamp:4738833275 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 141.284373: rtos_queue_peek_from_isr_failed: tstamp:4743833275 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 141.437363: rtos_queue_peek_from_isr_failed: tstamp:4748833275 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 141.590363: rtos_queue_peek_from_isr_failed: tstamp:4753833275 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 141.743355: rtos_queue_peek_from_isr_failed: tstamp:4758833276 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 141.896372: rtos_queue_peek_from_isr_failed: tstamp:4763833278 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 142.049365: rtos_queue_peek_from_isr_failed: tstamp:4768833275 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 142.202373: rtos_queue_peek_from_isr_failed: tstamp:4773833278 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 142.406372: rtos_queue_peek_from_isr_failed: tstamp:4778833276 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 142.559406: rtos_queue_peek_from_isr_failed: tstamp:4783833275 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 142.712381: rtos_queue_peek_from_isr_failed: tstamp:4788833276 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 142.865388: rtos_queue_peek_from_isr_failed: tstamp:4793833275 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 143.018356: rtos_queue_peek_from_isr_failed: tstamp:4798833275 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 143.171360: rtos_queue_peek_from_isr_failed: tstamp:4803833275 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 143.324353: rtos_queue_peek_from_isr_failed: tstamp:4808833280 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 143.528353: rtos_queue_peek_from_isr_failed: tstamp:4813833275 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 143.681355: rtos_queue_peek_from_isr_failed: tstamp:4818833278 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 143.834371: rtos_queue_peek_from_isr_failed: tstamp:4823833278 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 143.987361: rtos_queue_peek_from_isr_failed: tstamp:4828833278 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 144.140356: rtos_queue_peek_from_isr_failed: tstamp:4833833275 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 144.293346: rtos_queue_peek_from_isr_failed: tstamp:4838833275 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 144.446353: rtos_queue_peek_from_isr_failed: tstamp:4843833279 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 144.650355: rtos_queue_peek_from_isr_failed: tstamp:4848833276 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 144.803365: rtos_queue_peek_from_isr_failed: tstamp:4853833275 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 144.956339: rtos_queue_peek_from_isr_failed: tstamp:4858833279 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 145.109353: rtos_queue_peek_from_isr_failed: tstamp:4863833278 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 145.262353: rtos_queue_peek_from_isr_failed: tstamp:4868833278 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 145.415351: rtos_queue_peek_from_isr_failed: tstamp:4873833279 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 145.568351: rtos_queue_peek_from_isr_failed: tstamp:4878833278 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 145.721352: rtos_queue_peek_from_isr_failed: tstamp:4883833278 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 145.925386: rtos_queue_peek_from_isr_failed: tstamp:4888833276 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 146.078369: rtos_queue_peek_from_isr_failed: tstamp:4893833279 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 146.231353: rtos_queue_peek_from_isr_failed: tstamp:4898833276 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 146.333365: rtos_queue_peek_from_isr_failed: tstamp:4902700264 queue:0x0bcbb8b8
v4l2-ctl-3008 [002] .... 156.217333: tegra_channel_open: vi-output, imx299 30-001a
v4l2-ctl-3008 [000] .... 156.218945: tegra_channel_set_power: imx299 30-001a : 0x1
v4l2-ctl-3008 [000] .... 156.218959: camera_common_s_power: status : 0x1
v4l2-ctl-3008 [000] .... 156.234602: tegra_channel_set_power: 15a00000.nvcsi--3 : 0x1
v4l2-ctl-3008 [000] .... 156.234608: csi_s_power: enable : 0x1
v4l2-ctl-3008 [000] .... 156.252166: tegra_channel_capture_setup: vnc_id 0 W 3884 H 2176 fmt c4
v4l2-ctl-3008 [000] .... 156.258003: tegra_channel_set_stream: enable : 0x1
v4l2-ctl-3008 [000] .... 156.260400: tegra_channel_set_stream: 15a00000.nvcsi--3 : 0x1
v4l2-ctl-3008 [000] .... 156.260404: csi_s_stream: enable : 0x1
v4l2-ctl-3008 [000] .... 156.260413: tegra_channel_set_stream: imx299 30-001a : 0x1
kworker/1:3-252 [001] .... 156.278330: rtos_queue_peek_from_isr_failed: tstamp:5213071619 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 156.278336: rtcpu_start: tstamp:5213074132
kworker/1:3-252 [001] .... 156.278338: rtos_queue_send_from_isr_failed: tstamp:5213095406 queue:0x0bcb2b38
kworker/1:3-252 [001] .... 156.278340: rtos_queue_send_from_isr_failed: tstamp:5213095551 queue:0x0bcb73a0
kworker/1:3-252 [001] .... 156.278341: rtos_queue_send_from_isr_failed: tstamp:5213095693 queue:0x0bcb8f20
kworker/1:3-252 [001] .... 156.278342: rtos_queue_send_from_isr_failed: tstamp:5213095832 queue:0x0bcb9ce0
kworker/1:3-252 [001] .... 156.278343: rtos_queue_send_from_isr_failed: tstamp:5213095971 queue:0x0bcbaaa0
kworker/1:3-252 [001] .... 156.278372: rtcpu_string: tstamp:5213096383 id:0x04010000 str:"Configuring VI GoS.
kworker/1:3-252 [001] .... 156.278392: rtcpu_string: tstamp:5213096571 id:0x04010000 str:"VM GOS[#0] addr=0xbe100000
kworker/1:3-252 [001] .... 156.278401: rtcpu_string: tstamp:5213096818 id:0x04010000 str:"VM GOS[#1] addr=0xbe101000
kworker/1:3-252 [001] .... 156.278409: rtcpu_string: tstamp:5213097052 id:0x04010000 str:"VM GOS[#2] addr=0xbe102000
kworker/1:3-252 [001] .... 156.278417: rtcpu_string: tstamp:5213097275 id:0x04010000 str:"VM GOS[#3] addr=0xbe103000
kworker/1:3-252 [001] .... 156.278424: rtcpu_string: tstamp:5213097514 id:0x04010000 str:"VM GOS[#4] addr=0xbe104000
kworker/1:3-252 [001] .... 156.278432: rtcpu_string: tstamp:5213097736 id:0x04010000 str:"VM GOS[#5] addr=0xbe105000
kworker/1:3-252 [001] .... 156.278460: rtcpu_string: tstamp:5213106469 id:0x04010000 str:"vi5_hwinit: firmware CL2018101701 protocol vers"
kworker/1:3-252 [001] .... 156.278464: rtcpu_string: tstamp:5213106579 id:0x04010000 str:"on 2.2
kworker/1:3-252 [001] .... 156.278475: rtos_queue_send_from_isr_failed: tstamp:5213121920 queue:0x0bcb2b38
kworker/1:3-252 [001] .... 156.278477: rtos_queue_send_from_isr_failed: tstamp:5213122078 queue:0x0bcb73a0
kworker/1:3-252 [001] .... 156.278478: rtos_queue_send_from_isr_failed: tstamp:5213122226 queue:0x0bcb8f20
kworker/1:3-252 [001] .... 156.278479: rtos_queue_send_from_isr_failed: tstamp:5213122366 queue:0x0bcb9ce0
kworker/1:3-252 [001] .... 156.278480: rtos_queue_send_from_isr_failed: tstamp:5213122505 queue:0x0bcbaaa0
kworker/1:3-252 [001] .... 156.278481: rtcpu_string: tstamp:5213123429 id:0x04010000 str:"VI GOS[#0] set to VM GOS[4] base 0xbe104000
kworker/1:3-252 [001] .... 156.278491: rtos_queue_send_from_isr_failed: tstamp:5213201230 queue:0x0bcb2b38
kworker/1:3-252 [001] .... 156.278492: rtos_queue_send_from_isr_failed: tstamp:5213201373 queue:0x0bcb73a0
kworker/1:3-252 [001] .... 156.278493: rtos_queue_send_from_isr_failed: tstamp:5213201518 queue:0x0bcb8f20
kworker/1:3-252 [001] .... 156.278495: rtos_queue_send_from_isr_failed: tstamp:5213201658 queue:0x0bcb9ce0
kworker/1:3-252 [001] .... 156.278496: rtos_queue_send_from_isr_failed: tstamp:5213201797 queue:0x0bcbaaa0
kworker/1:3-252 [001] .... 156.278498: rtcpu_nvcsi_intr: tstamp:5213204355 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000089
kworker/1:3-252 [001] .... 156.278499: rtcpu_nvcsi_intr: tstamp:5213204355 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000088
kworker/1:3-252 [001] .... 156.278501: rtcpu_vinotify_event: tstamp:5213578501 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3611229760 data:0x10000000
kworker/1:3-252 [001] .... 156.278502: rtcpu_vinotify_event: tstamp:5213578636 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3611237952 data:0x31000001
kworker/1:3-252 [001] .... 156.278503: rtcpu_vinotify_event: tstamp:5213578786 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3611240128 data:0x07020001
kworker/1:3-252 [001] .... 156.278505: rtcpu_vinotify_event: tstamp:5213578913 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3611273824 data:0x10000000
kworker/1:3-252 [001] .... 156.278506: rtcpu_vinotify_event: tstamp:5213579061 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3611282144 data:0x31000002
kworker/1:3-252 [001] .... 156.380349: rtcpu_nvcsi_intr: tstamp:5216332349 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
kworker/1:3-252 [001] .... 156.380353: rtcpu_nvcsi_intr: tstamp:5216332349 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
kworker/1:3-252 [001] .... 156.380354: rtcpu_nvcsi_intr: tstamp:5216332349 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000e00
kworker/1:3-252 [001] .... 156.380355: rtcpu_nvcsi_intr: tstamp:5216332349 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00000600
vi-output, imx2-3010 [001] .... 156.417787: tegra_channel_capture_frame: sof:166.955378304
vi-output, imx2-3010 [001] .... 156.417789: tegra_channel_capture_frame: eof:166.979556064
kworker/1:3-252 [001] .... 156.431363: rtcpu_vinotify_event: tstamp:5217484332 tag:FS channel:0x00 frame:0 vi_tstamp:5217352125 data:0x00000010
kworker/1:3-252 [001] .... 156.431365: rtcpu_vinotify_event: tstamp:5217484490 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:5217352128 data:0x00000000
kworker/1:3-252 [001] .... 156.431367: rtcpu_vinotify_event: tstamp:5217484625 tag:CHANSEL_EMBED_SOF channel:0x23 frame:0 vi_tstamp:5217352447 data:0x00000004
kworker/1:3-252 [001] .... 156.431368: rtcpu_vinotify_event: tstamp:5217484774 tag:CHANSEL_EMBED_EOF channel:0x23 frame:0 vi_tstamp:5217352454 data:0x00000008
kworker/1:3-252 [001] .... 156.431369: rtcpu_vinotify_event: tstamp:5217484901 tag:ATOMP_EMB_DATA_DONE channel:0x23 frame:0 vi_tstamp:5217352498 data:0x00000000
kworker/1:3-252 [001] .... 156.431371: rtcpu_vinotify_event: tstamp:5217485050 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3746532096 data:0x03020001
kworker/1:3-252 [001] .... 156.431372: rtcpu_vinotify_event: tstamp:5217485179 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:5217352793 data:0x000006e9
kworker/1:3-252 [001] .... 156.431373: rtcpu_vinotify_event: tstamp:5217485325 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:5217355572 data:0x00000001
kworker/1:3-252 [001] .... 156.431374: rtcpu_vinotify_event: tstamp:5217485455 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3746626848 data:0x08020001
kworker/1:3-252 [001] .... 156.431376: rtos_queue_peek_from_isr_failed: tstamp:5218071966 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 156.431378: rtcpu_vinotify_event: tstamp:5218115600 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:5218110990 data:0x087f0002
kworker/1:3-252 [001] .... 156.431379: rtcpu_vinotify_event: tstamp:5218115732 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:5218111015 data:0x00000000
kworker/1:3-252 [001] .... 156.431382: rtos_queue_send_from_isr_failed: tstamp:5218122374 queue:0x0bcb2b38
kworker/1:3-252 [001] .... 156.431383: rtos_queue_send_from_isr_failed: tstamp:5218122522 queue:0x0bcb73a0
kworker/1:3-252 [001] .... 156.431384: rtos_queue_send_from_isr_failed: tstamp:5218122668 queue:0x0bcb8f20
kworker/1:3-252 [001] .... 156.431409: rtos_queue_send_from_isr_failed: tstamp:5218122808 queue:0x0bcb9ce0
kworker/1:3-252 [001] .... 156.431416: rtos_queue_send_from_isr_failed: tstamp:5218122947 queue:0x0bcbaaa0
kworker/1:3-252 [001] .... 156.431418: rtcpu_vinotify_event: tstamp:5218405924 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3770806816 data:0x02020001
kworker/1:3-252 [001] .... 156.431419: rtcpu_vinotify_event: tstamp:5218406060 tag:FE channel:0x00 frame:0 vi_tstamp:5218111124 data:0x00000020
kworker/1:3-252 [001] .... 156.431420: rtcpu_vinotify_event: tstamp:5218406215 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:5218111127 data:0x00000000
kworker/1:3-252 [001] .... 156.431422: rtcpu_vinotify_event: tstamp:5218406346 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3770829728 data:0x00020001
kworker/1:3-252 [001] .... 156.431423: rtcpu_vinotify_event: tstamp:5218406495 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3770849824 data:0x07020002
kworker/1:3-252 [001] .... 156.431424: rtcpu_vinotify_event: tstamp:5218406624 tag:FS channel:0x00 frame:0 vi_tstamp:5218393792 data:0x00000010
kworker/1:3-252 [001] .... 156.431425: rtcpu_vinotify_event: tstamp:5218406775 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:5218393794 data:0x00000000
kworker/1:3-252 [001] .... 156.431426: rtcpu_vinotify_event: tstamp:5218406906 tag:CHANSEL_EMBED_SOF channel:0x23 frame:0 vi_tstamp:5218394113 data:0x00000004
kworker/1:3-252 [001] .... 156.431429: rtcpu_vinotify_event: tstamp:5218407055 tag:CHANSEL_EMBED_EOF channel:0x23 frame:0 vi_tstamp:5218394121 data:0x00000008
kworker/1:3-252 [001] .... 156.431430: rtcpu_vinotify_event: tstamp:5218407191 tag:ATOMP_EMB_DATA_DONE channel:0x23 frame:0 vi_tstamp:5218394141 data:0x00000000
kworker/1:3-252 [001] .... 156.431431: rtcpu_vinotify_event: tstamp:5218407339 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3779865440 data:0x03020002
kworker/1:3-252 [001] .... 156.431432: rtcpu_vinotify_event: tstamp:5218407467 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:5218394460 data:0x000006e9
kworker/1:3-252 [001] .... 156.431459: rtcpu_vinotify_event: tstamp:5218407614 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:5218397238 data:0x00000001
kworker/1:3-252 [001] .... 156.431460: rtcpu_vinotify_event: tstamp:5218407741 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3779960256 data:0x08020002
kworker/1:3-252 [001] .... 156.431462: rtcpu_vinotify_event: tstamp:5218407887 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3780137824 data:0x10000000
kworker/1:3-252 [001] .... 156.431463: rtcpu_vinotify_event: tstamp:5218408015 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3780164032 data:0x31000003
vi-output, imx2-3010 [000] .... 156.451081: tegra_channel_capture_frame: sof:166.988711616
vi-output, imx2-3010 [000] .... 156.451084: tegra_channel_capture_frame: eof:167.12889376
kworker/1:3-252 [001] .... 156.482365: rtos_queue_send_from_isr_failed: tstamp:5219162537 queue:0x0bcb2b38
kworker/1:3-252 [001] .... 156.482368: rtos_queue_send_from_isr_failed: tstamp:5219162688 queue:0x0bcb73a0
kworker/1:3-252 [001] .... 156.482369: rtos_queue_send_from_isr_failed: tstamp:5219162834 queue:0x0bcb8f20
kworker/1:3-252 [001] .... 156.482371: rtos_queue_send_from_isr_failed: tstamp:5219162974 queue:0x0bcb9ce0
kworker/1:3-252 [001] .... 156.482372: rtos_queue_send_from_isr_failed: tstamp:5219163113 queue:0x0bcbaaa0
kworker/1:3-252 [001] .... 156.482374: rtcpu_vinotify_event: tstamp:5219193529 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:5219152657 data:0x087f0002
kworker/1:3-252 [001] .... 156.482375: rtcpu_vinotify_event: tstamp:5219193663 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:5219152682 data:0x00000000
kworker/1:3-252 [001] .... 156.482377: rtcpu_vinotify_event: tstamp:5219193817 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3804134816 data:0x02020002
kworker/1:3-252 [001] .... 156.482378: rtcpu_vinotify_event: tstamp:5219193948 tag:FE channel:0x00 frame:0 vi_tstamp:5219152791 data:0x00000020
kworker/1:3-252 [001] .... 156.482379: rtcpu_vinotify_event: tstamp:5219194100 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:5219152793 data:0x00000000
kworker/1:3-252 [001] .... 156.482409: rtcpu_vinotify_event: tstamp:5219194228 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3804157472 data:0x00020002
kworker/1:3-252 [001] .... 156.482410: rtcpu_vinotify_event: tstamp:5219194376 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3804177184 data:0x07020003
kworker/1:3-252 [001] .... 156.482412: rtcpu_vinotify_event: tstamp:5219442602 tag:FS channel:0x00 frame:0 vi_tstamp:5219435459 data:0x00000010
kworker/1:3-252 [001] .... 156.482413: rtcpu_vinotify_event: tstamp:5219442754 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:5219435461 data:0x00000000
kworker/1:3-252 [001] .... 156.482414: rtcpu_vinotify_event: tstamp:5219442886 tag:CHANSEL_EMBED_SOF channel:0x23 frame:0 vi_tstamp:5219435780 data:0x00000004
kworker/1:3-252 [001] .... 156.482415: rtcpu_vinotify_event: tstamp:5219443035 tag:CHANSEL_EMBED_EOF channel:0x23 frame:0 vi_tstamp:5219435787 data:0x00000008
kworker/1:3-252 [001] .... 156.482416: rtcpu_vinotify_event: tstamp:5219443164 tag:ATOMP_EMB_DATA_DONE channel:0x23 frame:0 vi_tstamp:5219435809 data:0x00000000
kworker/1:3-252 [001] .... 156.482417: rtcpu_vinotify_event: tstamp:5219443317 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3813198784 data:0x03020003
kworker/1:3-252 [001] .... 156.482419: rtcpu_vinotify_event: tstamp:5219443446 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:5219436127 data:0x000006e9
kworker/1:3-252 [001] .... 156.482420: rtcpu_vinotify_event: tstamp:5219443594 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:5219438905 data:0x00000001
kworker/1:3-252 [001] .... 156.482421: rtcpu_vinotify_event: tstamp:5219443723 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3813293536 data:0x08020003
kworker/1:3-252 [001] .... 156.482444: rtcpu_vinotify_event: tstamp:5219925831 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3813547936 data:0x10000000
kworker/1:3-252 [001] .... 156.482445: rtcpu_vinotify_event: tstamp:5219925963 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3813574112 data:0x31000004
vi-output, imx2-3010 [000] .... 156.484418: tegra_channel_capture_frame: sof:167.22044960
vi-output, imx2-3010 [000] .... 156.484421: tegra_channel_capture_frame: eof:167.46222688
vi-output, imx2-3010 [001] .... 156.517780: tegra_channel_capture_frame: sof:167.55378304
vi-output, imx2-3010 [001] .... 156.517783: tegra_channel_capture_frame: eof:167.79556064
kworker/1:3-252 [001] .... 156.533334: rtos_queue_send_from_isr_failed: tstamp:5220203038 queue:0x0bcb2b38
kworker/1:3-252 [001] .... 156.533337: rtos_queue_send_from_isr_failed: tstamp:5220203187 queue:0x0bcb73a0
kworker/1:3-252 [001] .... 156.533338: rtos_queue_send_from_isr_failed: tstamp:5220203332 queue:0x0bcb8f20
kworker/1:3-252 [001] .... 156.533340: rtos_queue_send_from_isr_failed: tstamp:5220203472 queue:0x0bcb9ce0
kworker/1:3-252 [001] .... 156.533341: rtos_queue_send_from_isr_failed: tstamp:5220203610 queue:0x0bcbaaa0
kworker/1:3-252 [001] .... 156.533344: rtcpu_vinotify_event: tstamp:5220413982 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:5220194323 data:0x087f0002
kworker/1:3-252 [001] .... 156.533345: rtcpu_vinotify_event: tstamp:5220414117 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:5220194349 data:0x00000000
kworker/1:3-252 [001] .... 156.533346: rtcpu_vinotify_event: tstamp:5220414272 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3837468192 data:0x02020003
kworker/1:3-252 [001] .... 156.533347: rtcpu_vinotify_event: tstamp:5220414403 tag:FE channel:0x00 frame:0 vi_tstamp:5220194457 data:0x00000020
kworker/1:3-252 [001] .... 156.533349: rtcpu_vinotify_event: tstamp:5220414554 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:5220194459 data:0x00000000
kworker/1:3-252 [001] .... 156.533350: rtcpu_vinotify_event: tstamp:5220414683 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3837490784 data:0x00020003
kworker/1:3-252 [001] .... 156.533351: rtcpu_vinotify_event: tstamp:5220414831 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3837510528 data:0x07020004
kworker/1:3-252 [001] .... 156.533382: rtcpu_vinotify_event: tstamp:5220483520 tag:FS channel:0x00 frame:0 vi_tstamp:5220477125 data:0x00000010
kworker/1:3-252 [001] .... 156.533383: rtcpu_vinotify_event: tstamp:5220483669 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:5220477128 data:0x00000000
kworker/1:3-252 [001] .... 156.533384: rtcpu_vinotify_event: tstamp:5220483800 tag:CHANSEL_EMBED_SOF channel:0x23 frame:0 vi_tstamp:5220477447 data:0x00000004
kworker/1:3-252 [001] .... 156.533386: rtcpu_vinotify_event: tstamp:5220483952 tag:CHANSEL_EMBED_EOF channel:0x23 frame:0 vi_tstamp:5220477454 data:0x00000008
kworker/1:3-252 [001] .... 156.533387: rtcpu_vinotify_event: tstamp:5220484079 tag:ATOMP_EMB_DATA_DONE channel:0x23 frame:0 vi_tstamp:5220477474 data:0x00000000
kworker/1:3-252 [001] .... 156.533388: rtcpu_vinotify_event: tstamp:5220484227 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3846532096 data:0x03020004
kworker/1:3-252 [001] .... 156.533389: rtcpu_vinotify_event: tstamp:5220484354 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:5220477793 data:0x000006e9
kworker/1:3-252 [001] .... 156.533391: rtcpu_vinotify_event: tstamp:5220951711 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:5220480572 data:0x00000001
kworker/1:3-252 [001] .... 156.533393: rtcpu_vinotify_event: tstamp:5220951845 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3846626048 data:0x08020004
kworker/1:3-252 [001] .... 156.533394: rtcpu_vinotify_event: tstamp:5220951995 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3846849984 data:0x10000000
kworker/1:3-252 [001] .... 156.533395: rtcpu_vinotify_event: tstamp:5220952125 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3846876192 data:0x31000005
kworker/1:3-252 [001] .... 156.533397: rtos_queue_send_from_isr_failed: tstamp:5221246653 queue:0x0bcb2b38
kworker/1:3-252 [001] .... 156.533427: rtos_queue_send_from_isr_failed: tstamp:5221246802 queue:0x0bcb73a0
kworker/1:3-252 [001] .... 156.533434: rtos_queue_send_from_isr_failed: tstamp:5221246947 queue:0x0bcb8f20
kworker/1:3-252 [001] .... 156.533435: rtos_queue_send_from_isr_failed: tstamp:5221247086 queue:0x0bcb9ce0
kworker/1:3-252 [001] .... 156.533436: rtos_queue_send_from_isr_failed: tstamp:5221247224 queue:0x0bcbaaa0
kworker/1:3-252 [001] .... 156.533438: rtcpu_vinotify_event: tstamp:5221439760 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:5221235991 data:0x087f0002
kworker/1:3-252 [001] .... 156.533439: rtcpu_vinotify_event: tstamp:5221439893 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:5221236015 data:0x00000000
kworker/1:3-252 [001] .... 156.533440: rtcpu_vinotify_event: tstamp:5221440049 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3870801536 data:0x02020004
kworker/1:3-252 [001] .... 156.533441: rtcpu_vinotify_event: tstamp:5221440179 tag:FE channel:0x00 frame:0 vi_tstamp:5221236124 data:0x00000020
kworker/1:3-252 [001] .... 156.533442: rtcpu_vinotify_event: tstamp:5221440329 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:5221236127 data:0x00000000
kworker/1:3-252 [001] .... 156.533443: rtcpu_vinotify_event: tstamp:5221440456 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3870824160 data:0x00020004
kworker/1:3-252 [001] .... 156.533445: rtcpu_vinotify_event: tstamp:5221440604 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3870843872 data:0x07020005
kworker/1:3-252 [001] .... 156.533446: rtcpu_vinotify_event: tstamp:5221525193 tag:FS channel:0x00 frame:0 vi_tstamp:5221518791 data:0x00000010
kworker/1:3-252 [001] .... 156.533447: rtcpu_vinotify_event: tstamp:5221525343 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:5221518794 data:0x00000000
kworker/1:3-252 [001] .... 156.533448: rtcpu_vinotify_event: tstamp:5221525474 tag:CHANSEL_EMBED_SOF channel:0x23 frame:0 vi_tstamp:5221519113 data:0x00000004
kworker/1:3-252 [001] .... 156.533449: rtcpu_vinotify_event: tstamp:5221525635 tag:CHANSEL_EMBED_EOF channel:0x23 frame:0 vi_tstamp:5221519121 data:0x00000008
kworker/1:3-252 [001] .... 156.533450: rtcpu_vinotify_event: tstamp:5221525762 tag:ATOMP_EMB_DATA_DONE channel:0x23 frame:0 vi_tstamp:5221519141 data:0x00000000
vi-output, imx2-3010 [001] .... 156.551075: tegra_channel_capture_frame: sof:167.88711616
vi-output, imx2-3010 [001] .... 156.551078: tegra_channel_capture_frame: eof:167.112889376
kworker/1:3-252 [001] .... 156.584384: rtcpu_vinotify_event: tstamp:5221976892 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3879870720 data:0x03020005
kworker/1:3-252 [001] .... 156.584387: rtcpu_vinotify_event: tstamp:5221977033 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:5221519460 data:0x000006e9
kworker/1:3-252 [001] .... 156.584388: rtcpu_vinotify_event: tstamp:5221977185 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:5221522238 data:0x00000001
kworker/1:3-252 [001] .... 156.584389: rtcpu_vinotify_event: tstamp:5221977318 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3879959456 data:0x08020005
kworker/1:3-252 [001] .... 156.584391: rtcpu_vinotify_event: tstamp:5221977467 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3880173120 data:0x10000000
kworker/1:3-252 [001] .... 156.584421: rtcpu_vinotify_event: tstamp:5221977597 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3880199296 data:0x31000006
kworker/1:3-252 [001] .... 156.584426: rtos_queue_send_from_isr_failed: tstamp:5222286117 queue:0x0bcb2b38
kworker/1:3-252 [001] .... 156.584428: rtos_queue_send_from_isr_failed: tstamp:5222286265 queue:0x0bcb73a0
kworker/1:3-252 [001] .... 156.584429: rtos_queue_send_from_isr_failed: tstamp:5222286409 queue:0x0bcb8f20
kworker/1:3-252 [001] .... 156.584430: rtos_queue_send_from_isr_failed: tstamp:5222286548 queue:0x0bcb9ce0
kworker/1:3-252 [001] .... 156.584431: rtos_queue_send_from_isr_failed: tstamp:5222286685 queue:0x0bcbaaa0
kworker/1:3-252 [001] .... 156.584432: rtcpu_vinotify_event: tstamp:5222464822 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:5222277657 data:0x087f0002
kworker/1:3-252 [001] .... 156.584434: rtcpu_vinotify_event: tstamp:5222464954 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:5222277682 data:0x00000000
kworker/1:3-252 [001] .... 156.584435: rtcpu_vinotify_event: tstamp:5222465110 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3904134816 data:0x02020005
kworker/1:3-252 [001] .... 156.584436: rtcpu_vinotify_event: tstamp:5222465240 tag:FE channel:0x00 frame:0 vi_tstamp:5222277791 data:0x00000020
kworker/1:3-252 [001] .... 156.584437: rtcpu_vinotify_event: tstamp:5222465391 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:5222277793 data:0x00000000
kworker/1:3-252 [001] .... 156.584438: rtcpu_vinotify_event: tstamp:5222465521 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3904157472 data:0x00020005
kworker/1:3-252 [001] .... 156.584460: rtcpu_vinotify_event: tstamp:5222465670 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3904177184 data:0x07020006
kworker/1:3-252 [001] .... 156.584461: rtcpu_vinotify_event: tstamp:5222566857 tag:FS channel:0x00 frame:0 vi_tstamp:5222560459 data:0x00000010
kworker/1:3-252 [001] .... 156.584463: rtcpu_vinotify_event: tstamp:5222567007 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:5222560461 data:0x00000000
kworker/1:3-252 [001] .... 156.584464: rtcpu_vinotify_event: tstamp:5222567138 tag:CHANSEL_EMBED_SOF channel:0x23 frame:0 vi_tstamp:5222560780 data:0x00000004
kworker/1:3-252 [001] .... 156.584466: rtcpu_vinotify_event: tstamp:5223002055 tag:CHANSEL_EMBED_EOF channel:0x23 frame:0 vi_tstamp:5222560787 data:0x00000008
kworker/1:3-252 [001] .... 156.584467: rtcpu_vinotify_event: tstamp:5223002186 tag:ATOMP_EMB_DATA_DONE channel:0x23 frame:0 vi_tstamp:5222560808 data:0x00000000
kworker/1:3-252 [001] .... 156.584468: rtcpu_vinotify_event: tstamp:5223002353 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3913204096 data:0x03020006
kworker/1:3-252 [001] .... 156.584469: rtcpu_vinotify_event: tstamp:5223002484 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:5222561127 data:0x000006e9
kworker/1:3-252 [001] .... 156.584471: rtcpu_vinotify_event: tstamp:5223002632 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:5222563905 data:0x00000001
kworker/1:3-252 [001] .... 156.584473: rtcpu_vinotify_event: tstamp:5223002760 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3913292704 data:0x08020006
kworker/1:3-252 [001] .... 156.584474: rtcpu_vinotify_event: tstamp:5223002908 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3913482304 data:0x10000000
kworker/1:3-252 [001] .... 156.584475: rtcpu_vinotify_event: tstamp:5223003035 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3913508512 data:0x31000007
kworker/1:3-252 [001] .... 156.584477: rtos_queue_peek_from_isr_failed: tstamp:5223071966 queue:0x0bcbb8b8
vi-output, imx2-3010 [001] .... 156.584511: tegra_channel_capture_frame: sof:167.122044960
vi-output, imx2-3010 [001] .... 156.584513: tegra_channel_capture_frame: eof:167.146222688
vi-output, imx2-3010 [001] .... 156.617839: tegra_channel_capture_frame: sof:167.155378304
vi-output, imx2-3010 [001] .... 156.617842: tegra_channel_capture_frame: eof:167.179556064
kworker/1:3-252 [001] .... 156.635379: rtos_queue_send_from_isr_failed: tstamp:5223331530 queue:0x0bcb2b38
kworker/1:3-252 [001] .... 156.635382: rtos_queue_send_from_isr_failed: tstamp:5223331680 queue:0x0bcb73a0
kworker/1:3-252 [001] .... 156.635383: rtos_queue_send_from_isr_failed: tstamp:5223331828 queue:0x0bcb8f20
kworker/1:3-252 [001] .... 156.635385: rtos_queue_send_from_isr_failed: tstamp:5223331968 queue:0x0bcb9ce0
kworker/1:3-252 [001] .... 156.635386: rtos_queue_send_from_isr_failed: tstamp:5223332104 queue:0x0bcbaaa0
kworker/1:3-252 [001] .... 156.635388: rtcpu_vinotify_event: tstamp:5223490587 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:5223319324 data:0x087f0002
kworker/1:3-252 [001] .... 156.635414: rtcpu_vinotify_event: tstamp:5223490721 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:5223319348 data:0x00000000
kworker/1:3-252 [001] .... 156.635415: rtcpu_vinotify_event: tstamp:5223490875 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3937468160 data:0x02020006
kworker/1:3-252 [001] .... 156.635417: rtcpu_vinotify_event: tstamp:5223491003 tag:FE channel:0x00 frame:0 vi_tstamp:5223319457 data:0x00000020
kworker/1:3-252 [001] .... 156.635418: rtcpu_vinotify_event: tstamp:5223491155 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:5223319459 data:0x00000000
kworker/1:3-252 [001] .... 156.635419: rtcpu_vinotify_event: tstamp:5223491283 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3937490784 data:0x00020006
kworker/1:3-252 [001] .... 156.635421: rtcpu_vinotify_event: tstamp:5223491431 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3937510496 data:0x07020007
kworker/1:3-252 [001] .... 156.635422: rtcpu_vinotify_event: tstamp:5223608528 tag:FS channel:0x00 frame:0 vi_tstamp:5223602124 data:0x00000010
kworker/1:3-252 [001] .... 156.635428: rtcpu_vinotify_event: tstamp:5224076763 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:5223602127 data:0x00000000
kworker/1:3-252 [001] .... 156.635430: rtcpu_vinotify_event: tstamp:5224076897 tag:CHANSEL_EMBED_SOF channel:0x23 frame:0 vi_tstamp:5223602447 data:0x00000004
kworker/1:3-252 [001] .... 156.635431: rtcpu_vinotify_event: tstamp:5224077047 tag:CHANSEL_EMBED_EOF channel:0x23 frame:0 vi_tstamp:5223602454 data:0x00000008
kworker/1:3-252 [001] .... 156.635432: rtcpu_vinotify_event: tstamp:5224077176 tag:ATOMP_EMB_DATA_DONE channel:0x23 frame:0 vi_tstamp:5223602474 data:0x00000000
kworker/1:3-252 [001] .... 156.635433: rtcpu_vinotify_event: tstamp:5224077329 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3946537376 data:0x03020007
kworker/1:3-252 [001] .... 156.635461: rtcpu_vinotify_event: tstamp:5224077460 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:5223602793 data:0x000006e9
kworker/1:3-252 [001] .... 156.635462: rtcpu_vinotify_event: tstamp:5224077609 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:5223605572 data:0x00000001
kworker/1:3-252 [001] .... 156.635463: rtcpu_vinotify_event: tstamp:5224077738 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3946626176 data:0x08020007
kworker/1:3-252 [001] .... 156.635465: rtcpu_vinotify_event: tstamp:5224077886 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3946806560 data:0x10000000
kworker/1:3-252 [001] .... 156.635466: rtcpu_vinotify_event: tstamp:5224078017 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3946832736 data:0x31000008
kworker/1:3-252 [001] .... 156.635467: rtcpu_vinotify_event: tstamp:5224365595 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:5224360991 data:0x087f0002
kworker/1:3-252 [001] .... 156.635468: rtcpu_vinotify_event: tstamp:5224365723 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:5224361015 data:0x00000000
kworker/1:3-252 [001] .... 156.635469: rtcpu_vinotify_event: tstamp:5224365872 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3970801536 data:0x02020007
kworker/1:3-252 [001] .... 156.635470: rtcpu_vinotify_event: tstamp:5224366001 tag:FE channel:0x00 frame:0 vi_tstamp:5224361124 data:0x00000020
kworker/1:3-252 [001] .... 156.635472: rtcpu_vinotify_event: tstamp:5224366149 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:5224361127 data:0x00000000
kworker/1:3-252 [001] .... 156.635473: rtcpu_vinotify_event: tstamp:5224366278 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3970824160 data:0x00020007
kworker/1:3-252 [001] .... 156.635475: rtos_queue_send_from_isr_failed: tstamp:5224372878 queue:0x0bcb2b38
kworker/1:3-252 [001] .... 156.635476: rtos_queue_send_from_isr_failed: tstamp:5224373029 queue:0x0bcb73a0
kworker/1:3-252 [001] .... 156.635477: rtos_queue_send_from_isr_failed: tstamp:5224373175 queue:0x0bcb8f20
kworker/1:3-252 [001] .... 156.635479: rtos_queue_send_from_isr_failed: tstamp:5224373315 queue:0x0bcb9ce0
kworker/1:3-252 [001] .... 156.635480: rtos_queue_send_from_isr_failed: tstamp:5224373455 queue:0x0bcbaaa0
kworker/1:3-252 [001] .... 156.635482: rtcpu_vinotify_event: tstamp:5224808770 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3970849888 data:0x07020008
kworker/1:3-252 [001] .... 156.635483: rtcpu_vinotify_event: tstamp:5224808921 tag:FS channel:0x00 frame:0 vi_tstamp:5224643791 data:0x00000010
kworker/1:3-252 [001] .... 156.635484: rtcpu_vinotify_event: tstamp:5224809074 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:5224643794 data:0x00000000
kworker/1:3-252 [001] .... 156.635485: rtcpu_vinotify_event: tstamp:5224809206 tag:CHANSEL_EMBED_SOF channel:0x23 frame:0 vi_tstamp:5224644113 data:0x00000004
kworker/1:3-252 [001] .... 156.635486: rtcpu_vinotify_event: tstamp:5224809355 tag:CHANSEL_EMBED_EOF channel:0x23 frame:0 vi_tstamp:5224644121 data:0x00000008
kworker/1:3-252 [001] .... 156.635487: rtcpu_vinotify_event: tstamp:5224809482 tag:ATOMP_EMB_DATA_DONE channel:0x23 frame:0 vi_tstamp:5224644141 data:0x00000000
kworker/1:3-252 [001] .... 156.635489: rtcpu_vinotify_event: tstamp:5224809633 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3979865440 data:0x03020008
kworker/1:3-252 [001] .... 156.635490: rtcpu_vinotify_event: tstamp:5224809761 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:5224644460 data:0x000006e9
kworker/1:3-252 [001] .... 156.635491: rtcpu_vinotify_event: tstamp:5224809908 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:5224647238 data:0x00000001
kworker/1:3-252 [001] .... 156.635492: rtcpu_vinotify_event: tstamp:5224810036 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3979960416 data:0x08020008
kworker/1:3-252 [001] .... 156.635493: rtcpu_vinotify_event: tstamp:5224810184 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3980142912 data:0x10000000
kworker/1:3-252 [001] .... 156.635494: rtcpu_vinotify_event: tstamp:5224810311 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3980169120 data:0x31000009
vi-output, imx2-3010 [001] .... 156.651145: tegra_channel_capture_frame: sof:167.188711616
vi-output, imx2-3010 [001] .... 156.651148: tegra_channel_capture_frame: eof:167.212889376
vi-output, imx2-3010 [001] .... 156.684471: tegra_channel_capture_frame: sof:167.222044960
vi-output, imx2-3010 [001] .... 156.684474: tegra_channel_capture_frame: eof:167.246222720
kworker/1:3-252 [001] .... 156.686356: rtcpu_vinotify_event: tstamp:5225407261 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:5225402657 data:0x087f0002
kworker/1:3-252 [001] .... 156.686359: rtcpu_vinotify_event: tstamp:5225407396 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:5225402682 data:0x00000000
kworker/1:3-252 [001] .... 156.686361: rtcpu_vinotify_event: tstamp:5225407549 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4004134816 data:0x02020008
kworker/1:3-252 [001] .... 156.686362: rtcpu_vinotify_event: tstamp:5225407680 tag:FE channel:0x00 frame:0 vi_tstamp:5225402791 data:0x00000020
kworker/1:3-252 [001] .... 156.686366: rtos_queue_send_from_isr_failed: tstamp:5225413795 queue:0x0bcb2b38
kworker/1:3-252 [001] .... 156.686368: rtos_queue_send_from_isr_failed: tstamp:5225413943 queue:0x0bcb73a0
kworker/1:3-252 [001] .... 156.686369: rtos_queue_send_from_isr_failed: tstamp:5225414089 queue:0x0bcb8f20
kworker/1:3-252 [001] .... 156.686370: rtos_queue_send_from_isr_failed: tstamp:5225414231 queue:0x0bcb9ce0
kworker/1:3-252 [001] .... 156.686399: rtos_queue_send_from_isr_failed: tstamp:5225414370 queue:0x0bcbaaa0
kworker/1:3-252 [001] .... 156.686402: rtcpu_vinotify_event: tstamp:5225882821 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:5225402793 data:0x00000000
kworker/1:3-252 [001] .... 156.686403: rtcpu_vinotify_event: tstamp:5225882960 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4004163072 data:0x00020008
kworker/1:3-252 [001] .... 156.686404: rtcpu_vinotify_event: tstamp:5225883113 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4004183232 data:0x07020009
kworker/1:3-252 [001] .... 156.686405: rtcpu_vinotify_event: tstamp:5225883243 tag:FS channel:0x00 frame:0 vi_tstamp:5225685458 data:0x00000010
kworker/1:3-252 [001] .... 156.686406: rtcpu_vinotify_event: tstamp:5225883397 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:5225685461 data:0x00000000
kworker/1:3-252 [001] .... 156.686408: rtcpu_vinotify_event: tstamp:5225883528 tag:CHANSEL_EMBED_SOF channel:0x23 frame:0 vi_tstamp:5225685780 data:0x00000004
kworker/1:3-252 [001] .... 156.686409: rtcpu_vinotify_event: tstamp:5225883677 tag:CHANSEL_EMBED_EOF channel:0x23 frame:0 vi_tstamp:5225685787 data:0x00000008
kworker/1:3-252 [001] .... 156.686410: rtcpu_vinotify_event: tstamp:5225883804 tag:ATOMP_EMB_DATA_DONE channel:0x23 frame:0 vi_tstamp:5225685808 data:0x00000000
kworker/1:3-252 [001] .... 156.686411: rtcpu_vinotify_event: tstamp:5225883952 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4013198752 data:0x03020009
kworker/1:3-252 [001] .... 156.686412: rtcpu_vinotify_event: tstamp:5225884082 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:5225686127 data:0x000006e9
kworker/1:3-252 [001] .... 156.686413: rtcpu_vinotify_event: tstamp:5225884230 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:5225688905 data:0x00000001
kworker/1:3-252 [001] .... 156.686415: rtcpu_vinotify_event: tstamp:5225884359 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4013293664 data:0x08020009
kworker/1:3-252 [001] .... 156.686416: rtcpu_vinotify_event: tstamp:5225884508 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4013457056 data:0x10000000
kworker/1:3-252 [001] .... 156.686417: rtcpu_vinotify_event: tstamp:5225884639 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4013483296 data:0x3100000a
kworker/1:3-252 [001] .... 156.686418: rtcpu_vinotify_event: tstamp:5226448929 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:5226444323 data:0x087f0002
kworker/1:3-252 [001] .... 156.686419: rtcpu_vinotify_event: tstamp:5226449062 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:5226444349 data:0x00000000
kworker/1:3-252 [001] .... 156.686421: rtos_queue_send_from_isr_failed: tstamp:5226455381 queue:0x0bcb2b38
kworker/1:3-252 [001] .... 156.686422: rtos_queue_send_from_isr_failed: tstamp:5226455527 queue:0x0bcb73a0
kworker/1:3-252 [001] .... 156.686424: rtos_queue_send_from_isr_failed: tstamp:5226455674 queue:0x0bcb8f20
kworker/1:3-252 [001] .... 156.686425: rtos_queue_send_from_isr_failed: tstamp:5226455811 queue:0x0bcb9ce0
kworker/1:3-252 [001] .... 156.686426: rtos_queue_send_from_isr_failed: tstamp:5226455950 queue:0x0bcbaaa0
vi-output, imx2-3010 [001] .... 156.717749: tegra_channel_capture_frame: sof:167.255378304
vi-output, imx2-3010 [001] .... 156.717752: tegra_channel_capture_frame: eof:167.279556064
kworker/1:3-252 [001] .... 156.737359: rtcpu_vinotify_event: tstamp:5226739397 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4037473504 data:0x02020009
kworker/1:3-252 [001] .... 156.737362: rtcpu_vinotify_event: tstamp:5226739547 tag:FE channel:0x00 frame:0 vi_tstamp:5226444458 data:0x00000020
kworker/1:3-252 [001] .... 156.737364: rtcpu_vinotify_event: tstamp:5226739702 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:5226444460 data:0x00000000
kworker/1:3-252 [001] .... 156.737365: rtcpu_vinotify_event: tstamp:5226739835 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4037496384 data:0x00020009
kworker/1:3-252 [001] .... 156.737366: rtcpu_vinotify_event: tstamp:5226739984 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4037516544 data:0x0702000a
kworker/1:3-252 [001] .... 156.737367: rtcpu_vinotify_event: tstamp:5226740128 tag:FS channel:0x00 frame:0 vi_tstamp:5226727124 data:0x00000010
kworker/1:3-252 [001] .... 156.737369: rtcpu_vinotify_event: tstamp:5226740277 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:5226727127 data:0x00000000
kworker/1:3-252 [001] .... 156.737370: rtcpu_vinotify_event: tstamp:5226740409 tag:CHANSEL_EMBED_SOF channel:0x23 frame:0 vi_tstamp:5226727447 data:0x00000004
kworker/1:3-252 [001] .... 156.737371: rtcpu_vinotify_event: tstamp:5226740561 tag:CHANSEL_EMBED_EOF channel:0x23 frame:0 vi_tstamp:5226727454 data:0x00000008
kworker/1:3-252 [001] .... 156.737372: rtcpu_vinotify_event: tstamp:5226740691 tag:ATOMP_EMB_DATA_DONE channel:0x23 frame:0 vi_tstamp:5226727474 data:0x00000000
kworker/1:3-252 [001] .... 156.737374: rtcpu_vinotify_event: tstamp:5226740841 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4046532064 data:0x0302000a
kworker/1:3-252 [001] .... 156.737405: rtcpu_vinotify_event: tstamp:5226740972 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:5226727793 data:0x000006e9
kworker/1:3-252 [001] .... 156.737406: rtcpu_vinotify_event: tstamp:5226741120 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:5226730572 data:0x00000001
kworker/1:3-252 [001] .... 156.737407: rtcpu_vinotify_event: tstamp:5226741250 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4046626944 data:0x0802000a
kworker/1:3-252 [001] .... 156.737408: rtcpu_vinotify_event: tstamp:5226741398 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4046808928 data:0x10000000
kworker/1:3-252 [001] .... 156.737410: rtcpu_vinotify_event: tstamp:5226741527 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4046835136 data:0x3100000b
kworker/1:3-252 [001] .... 156.737412: rtcpu_vinotify_event: tstamp:5227494799 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:5227485990 data:0x087f0002
kworker/1:3-252 [001] .... 156.737413: rtos_queue_send_from_isr_failed: tstamp:5227494953 queue:0x0bcb2b38
kworker/1:3-252 [001] .... 156.737415: rtos_queue_send_from_isr_failed: tstamp:5227495106 queue:0x0bcb73a0
kworker/1:3-252 [001] .... 156.737416: rtos_queue_send_from_isr_failed: tstamp:5227495254 queue:0x0bcb8f20
kworker/1:3-252 [001] .... 156.737417: rtos_queue_send_from_isr_failed: tstamp:5227495398 queue:0x0bcb9ce0
kworker/1:3-252 [001] .... 156.737419: rtos_queue_send_from_isr_failed: tstamp:5227495540 queue:0x0bcbaaa0
kworker/1:3-252 [001] .... 156.737420: rtcpu_vinotify_event: tstamp:5227495736 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:5227486015 data:0x00000000
kworker/1:3-252 [001] .... 156.737444: rtcpu_vinotify_event: tstamp:5227495889 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4070801504 data:0x0202000a
kworker/1:3-252 [001] .... 156.737445: rtcpu_vinotify_event: tstamp:5227496019 tag:FE channel:0x00 frame:0 vi_tstamp:5227486124 data:0x00000020
kworker/1:3-252 [001] .... 156.737446: rtcpu_vinotify_event: tstamp:5227496169 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:5227486127 data:0x00000000
kworker/1:3-252 [001] .... 156.737447: rtcpu_vinotify_event: tstamp:5227496302 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4070824128 data:0x0002000a
kworker/1:3-252 [001] .... 156.737448: rtcpu_vinotify_event: tstamp:5227496451 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4070843840 data:0x0702000b
kworker/1:3-252 [001] .... 156.737449: rtcpu_vinotify_event: tstamp:5227775948 tag:FS channel:0x00 frame:0 vi_tstamp:5227768792 data:0x00000010
kworker/1:3-252 [001] .... 156.737451: rtcpu_vinotify_event: tstamp:5227776101 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:5227768794 data:0x00000000
kworker/1:3-252 [001] .... 156.737452: rtcpu_vinotify_event: tstamp:5227776239 tag:CHANSEL_EMBED_SOF channel:0x23 frame:0 vi_tstamp:5227769113 data:0x00000004
kworker/1:3-252 [001] .... 156.737453: rtcpu_vinotify_event: tstamp:5227776390 tag:CHANSEL_EMBED_EOF channel:0x23 frame:0 vi_tstamp:5227769121 data:0x00000008
kworker/1:3-252 [001] .... 156.737454: rtcpu_vinotify_event: tstamp:5227776518 tag:ATOMP_EMB_DATA_DONE channel:0x23 frame:0 vi_tstamp:5227769141 data:0x00000000
kworker/1:3-252 [001] .... 156.737455: rtcpu_vinotify_event: tstamp:5227776667 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4079865440 data:0x0302000b
kworker/1:3-252 [001] .... 156.737456: rtcpu_vinotify_event: tstamp:5227776797 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:5227769461 data:0x000006e9
kworker/1:3-252 [001] .... 156.737458: rtcpu_vinotify_event: tstamp:5227776942 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:5227772238 data:0x00000001
kworker/1:3-252 [001] .... 156.737459: rtcpu_vinotify_event: tstamp:5227777071 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4079960384 data:0x0802000b
kworker/1:3-252 [001] .... 156.737461: rtos_queue_peek_from_isr_failed: tstamp:5228071966 queue:0x0bcbb8b8
vi-output, imx2-3010 [001] .... 156.751075: tegra_channel_capture_frame: sof:167.288711616
vi-output, imx2-3010 [001] .... 156.751078: tegra_channel_capture_frame: eof:167.312889376
vi-output, imx2-3010 [001] .... 156.784414: tegra_channel_capture_frame: sof:167.322044960
vi-output, imx2-3010 [001] .... 156.784417: tegra_channel_capture_frame: eof:167.346222720
kworker/1:3-252 [001] .... 156.788372: rtcpu_vinotify_event: tstamp:5228226604 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4080208928 data:0x10000000
kworker/1:3-252 [001] .... 156.788375: rtcpu_vinotify_event: tstamp:5228226744 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4080235136 data:0x3100000c
kworker/1:3-252 [001] .... 156.788379: rtos_queue_send_from_isr_failed: tstamp:5228536269 queue:0x0bcb2b38
kworker/1:3-252 [001] .... 156.788380: rtos_queue_send_from_isr_failed: tstamp:5228536418 queue:0x0bcb73a0
kworker/1:3-252 [001] .... 156.788409: rtos_queue_send_from_isr_failed: tstamp:5228536565 queue:0x0bcb8f20
kworker/1:3-252 [001] .... 156.788411: rtos_queue_send_from_isr_failed: tstamp:5228536704 queue:0x0bcb9ce0
kworker/1:3-252 [001] .... 156.788412: rtos_queue_send_from_isr_failed: tstamp:5228536844 queue:0x0bcbaaa0
kworker/1:3-252 [001] .... 156.788413: rtcpu_vinotify_event: tstamp:5228715238 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:5228527657 data:0x087f0002
kworker/1:3-252 [001] .... 156.788414: rtcpu_vinotify_event: tstamp:5228715373 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:5228527682 data:0x00000000
kworker/1:3-252 [001] .... 156.788416: rtcpu_vinotify_event: tstamp:5228715526 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4104134848 data:0x0202000b
kworker/1:3-252 [001] .... 156.788417: rtcpu_vinotify_event: tstamp:5228715657 tag:FE channel:0x00 frame:0 vi_tstamp:5228527791 data:0x00000020
kworker/1:3-252 [001] .... 156.788418: rtcpu_vinotify_event: tstamp:5228715809 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:5228527793 data:0x00000000
kworker/1:3-252 [001] .... 156.788419: rtcpu_vinotify_event: tstamp:5228715937 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4104157472 data:0x0002000b
kworker/1:3-252 [001] .... 156.788420: rtcpu_vinotify_event: tstamp:5228716085 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4104177184 data:0x0702000c
kworker/1:3-252 [001] .... 156.788421: rtcpu_vinotify_event: tstamp:5228816854 tag:FS channel:0x00 frame:0 vi_tstamp:5228810458 data:0x00000010
kworker/1:3-252 [001] .... 156.788423: rtcpu_vinotify_event: tstamp:5228817003 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:5228810460 data:0x00000000
kworker/1:3-252 [001] .... 156.788424: rtcpu_vinotify_event: tstamp:5228817134 tag:CHANSEL_EMBED_SOF channel:0x23 frame:0 vi_tstamp:5228810780 data:0x00000004
kworker/1:3-252 [001] .... 156.788425: rtcpu_vinotify_event: tstamp:5228817283 tag:CHANSEL_EMBED_EOF channel:0x23 frame:0 vi_tstamp:5228810787 data:0x00000008
kworker/1:3-252 [001] .... 156.788426: rtcpu_vinotify_event: tstamp:5228817410 tag:ATOMP_EMB_DATA_DONE channel:0x23 frame:0 vi_tstamp:5228810808 data:0x00000000
kworker/1:3-252 [001] .... 156.788427: rtcpu_vinotify_event: tstamp:5228817559 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4113198752 data:0x0302000c
kworker/1:3-252 [001] .... 156.788428: rtcpu_vinotify_event: tstamp:5228817688 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:5228811128 data:0x000006e9
kworker/1:3-252 [001] .... 156.788430: rtcpu_vinotify_event: tstamp:5229252470 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:5228813905 data:0x00000001
kworker/1:3-252 [001] .... 156.788431: rtcpu_vinotify_event: tstamp:5229252602 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4113292576 data:0x0802000c
kworker/1:3-252 [001] .... 156.788433: rtcpu_vinotify_event: tstamp:5229252753 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4113495616 data:0x10000000
kworker/1:3-252 [001] .... 156.788434: rtcpu_vinotify_event: tstamp:5229252882 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4113521792 data:0x3100000d
kworker/1:3-252 [001] .... 156.788436: rtos_queue_send_from_isr_failed: tstamp:5229577871 queue:0x0bcb2b38
kworker/1:3-252 [001] .... 156.788437: rtos_queue_send_from_isr_failed: tstamp:5229578020 queue:0x0bcb73a0
kworker/1:3-252 [001] .... 156.788438: rtos_queue_send_from_isr_failed: tstamp:5229578166 queue:0x0bcb8f20
kworker/1:3-252 [001] .... 156.788439: rtos_queue_send_from_isr_failed: tstamp:5229578305 queue:0x0bcb9ce0
kworker/1:3-252 [001] .... 156.788441: rtos_queue_send_from_isr_failed: tstamp:5229578442 queue:0x0bcbaaa0
vi-output, imx2-3010 [001] .... 156.817735: tegra_channel_capture_frame: sof:167.355378304
vi-output, imx2-3010 [001] .... 156.817738: tegra_channel_capture_frame: eof:167.379556032
kworker/1:3-252 [001] .... 156.839357: rtcpu_vinotify_event: tstamp:5229740290 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:5229569324 data:0x087f0002
kworker/1:3-252 [001] .... 156.839359: rtcpu_vinotify_event: tstamp:5229740429 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:5229569349 data:0x00000000
kworker/1:3-252 [001] .... 156.839361: rtcpu_vinotify_event: tstamp:5229740583 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4137468160 data:0x0202000c
kworker/1:3-252 [001] .... 156.839362: rtcpu_vinotify_event: tstamp:5229740714 tag:FE channel:0x00 frame:0 vi_tstamp:5229569458 data:0x00000020
kworker/1:3-252 [001] .... 156.839363: rtcpu_vinotify_event: tstamp:5229740866 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:5229569460 data:0x00000000
kworker/1:3-252 [001] .... 156.839393: rtcpu_vinotify_event: tstamp:5229740996 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4137490784 data:0x0002000c
kworker/1:3-252 [001] .... 156.839394: rtcpu_vinotify_event: tstamp:5229741146 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4137510496 data:0x0702000d
kworker/1:3-252 [001] .... 156.839395: rtcpu_vinotify_event: tstamp:5229858529 tag:FS channel:0x00 frame:0 vi_tstamp:5229852124 data:0x00000010
kworker/1:3-252 [001] .... 156.839396: rtcpu_vinotify_event: tstamp:5229858681 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:5229852127 data:0x00000000
kworker/1:3-252 [001] .... 156.839397: rtcpu_vinotify_event: tstamp:5229858813 tag:CHANSEL_EMBED_SOF channel:0x23 frame:0 vi_tstamp:5229852447 data:0x00000004
kworker/1:3-252 [001] .... 156.839398: rtcpu_vinotify_event: tstamp:5229858962 tag:CHANSEL_EMBED_EOF channel:0x23 frame:0 vi_tstamp:5229852454 data:0x00000008
kworker/1:3-252 [001] .... 156.839400: rtcpu_vinotify_event: tstamp:5229859091 tag:ATOMP_EMB_DATA_DONE channel:0x23 frame:0 vi_tstamp:5229852474 data:0x00000000
kworker/1:3-252 [001] .... 156.839403: rtcpu_vinotify_event: tstamp:5230326474 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4146537440 data:0x0302000d
kworker/1:3-252 [001] .... 156.839404: rtcpu_vinotify_event: tstamp:5230326606 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:5229852793 data:0x000006e9
kworker/1:3-252 [001] .... 156.839405: rtcpu_vinotify_event: tstamp:5230326755 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:5229855572 data:0x00000001
kworker/1:3-252 [001] .... 156.839406: rtcpu_vinotify_event: tstamp:5230326885 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4146626240 data:0x0802000d
kworker/1:3-252 [001] .... 156.839430: rtcpu_vinotify_event: tstamp:5230327037 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4146842432 data:0x10000000
kworker/1:3-252 [001] .... 156.839431: rtcpu_vinotify_event: tstamp:5230327165 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4146868640 data:0x3100000e
kworker/1:3-252 [001] .... 156.839433: rtos_queue_send_from_isr_failed: tstamp:5230620106 queue:0x0bcb2b38
kworker/1:3-252 [001] .... 156.839435: rtos_queue_send_from_isr_failed: tstamp:5230620255 queue:0x0bcb73a0
kworker/1:3-252 [001] .... 156.839436: rtos_queue_send_from_isr_failed: tstamp:5230620400 queue:0x0bcb8f20
kworker/1:3-252 [001] .... 156.839438: rtos_queue_send_from_isr_failed: tstamp:5230620540 queue:0x0bcb9ce0
kworker/1:3-252 [001] .... 156.839439: rtos_queue_send_from_isr_failed: tstamp:5230620679 queue:0x0bcbaaa0
kworker/1:3-252 [001] .... 156.839440: rtcpu_vinotify_event: tstamp:5230814516 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:5230610991 data:0x087f0002
kworker/1:3-252 [001] .... 156.839441: rtcpu_vinotify_event: tstamp:5230814648 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:5230611014 data:0x00000000
kworker/1:3-252 [001] .... 156.839442: rtcpu_vinotify_event: tstamp:5230814805 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4170801536 data:0x0202000d
kworker/1:3-252 [001] .... 156.839444: rtcpu_vinotify_event: tstamp:5230814935 tag:FE channel:0x00 frame:0 vi_tstamp:5230611124 data:0x00000020
kworker/1:3-252 [001] .... 156.839445: rtcpu_vinotify_event: tstamp:5230815085 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:5230611126 data:0x00000000
kworker/1:3-252 [001] .... 156.839446: rtcpu_vinotify_event: tstamp:5230815215 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4170824160 data:0x0002000d
kworker/1:3-252 [001] .... 156.839447: rtcpu_vinotify_event: tstamp:5230815362 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4170843872 data:0x0702000e
kworker/1:3-252 [001] .... 156.839448: rtcpu_vinotify_event: tstamp:5230900192 tag:FS channel:0x00 frame:0 vi_tstamp:5230893791 data:0x00000010
kworker/1:3-252 [001] .... 156.839449: rtcpu_vinotify_event: tstamp:5230900342 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:5230893794 data:0x00000000
kworker/1:3-252 [001] .... 156.839451: rtcpu_vinotify_event: tstamp:5230900473 tag:CHANSEL_EMBED_SOF channel:0x23 frame:0 vi_tstamp:5230894113 data:0x00000004
vi-output, imx2-3010 [001] .... 156.851076: tegra_channel_capture_frame: sof:167.388711616
vi-output, imx2-3010 [001] .... 156.851079: tegra_channel_capture_frame: eof:167.412889376
vi-output, imx2-3010 [001] .... 156.884480: tegra_channel_capture_frame: sof:167.422044960
vi-output, imx2-3010 [001] .... 156.884483: tegra_channel_capture_frame: eof:167.446222720
kworker/1:3-252 [001] .... 156.890351: rtcpu_vinotify_event: tstamp:5231351644 tag:CHANSEL_EMBED_EOF channel:0x23 frame:0 vi_tstamp:5230894121 data:0x00000008
kworker/1:3-252 [001] .... 156.890354: rtcpu_vinotify_event: tstamp:5231351797 tag:ATOMP_EMB_DATA_DONE channel:0x23 frame:0 vi_tstamp:5230894141 data:0x00000000
kworker/1:3-252 [001] .... 156.890355: rtcpu_vinotify_event: tstamp:5231351950 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4179870720 data:0x0302000e
kworker/1:3-252 [001] .... 156.890356: rtcpu_vinotify_event: tstamp:5231352082 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:5230894460 data:0x000006e9
kworker/1:3-252 [001] .... 156.890387: rtcpu_vinotify_event: tstamp:5231352233 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:5230897238 data:0x00000001
kworker/1:3-252 [001] .... 156.890389: rtcpu_vinotify_event: tstamp:5231352365 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4179959456 data:0x0802000e
kworker/1:3-252 [001] .... 156.890390: rtcpu_vinotify_event: tstamp:5231352514 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4180165376 data:0x10000000
kworker/1:3-252 [001] .... 156.890391: rtcpu_vinotify_event: tstamp:5231352641 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4180191584 data:0x3100000f
kworker/1:3-252 [001] .... 156.890395: rtos_queue_send_from_isr_failed: tstamp:5231660976 queue:0x0bcb2b38
kworker/1:3-252 [001] .... 156.890396: rtos_queue_send_from_isr_failed: tstamp:5231661125 queue:0x0bcb73a0
kworker/1:3-252 [001] .... 156.890398: rtos_queue_send_from_isr_failed: tstamp:5231661270 queue:0x0bcb8f20
kworker/1:3-252 [001] .... 156.890399: rtos_queue_send_from_isr_failed: tstamp:5231661411 queue:0x0bcb9ce0
kworker/1:3-252 [001] .... 156.890400: rtos_queue_send_from_isr_failed: tstamp:5231661549 queue:0x0bcbaaa0
kworker/1:3-252 [001] .... 156.890402: rtcpu_vinotify_event: tstamp:5231840281 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:5231652657 data:0x087f0002
kworker/1:3-252 [001] .... 156.890403: rtcpu_vinotify_event: tstamp:5231840415 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:5231652683 data:0x00000000
kworker/1:3-252 [001] .... 156.890404: rtcpu_vinotify_event: tstamp:5231840569 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4204134848 data:0x0202000e
kworker/1:3-252 [001] .... 156.890426: rtcpu_vinotify_event: tstamp:5231840697 tag:FE channel:0x00 frame:0 vi_tstamp:5231652791 data:0x00000020
kworker/1:3-252 [001] .... 156.890428: rtcpu_vinotify_event: tstamp:5231840849 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:5231652793 data:0x00000000
kworker/1:3-252 [001] .... 156.890429: rtcpu_vinotify_event: tstamp:5231840977 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4204157472 data:0x0002000e
kworker/1:3-252 [001] .... 156.890430: rtcpu_vinotify_event: tstamp:5231841127 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4204177184 data:0x0702000f
kworker/1:3-252 [001] .... 156.890431: rtcpu_vinotify_event: tstamp:5231941863 tag:FS channel:0x00 frame:0 vi_tstamp:5231935458 data:0x00000010
kworker/1:3-252 [001] .... 156.890433: rtcpu_vinotify_event: tstamp:5232377517 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:5231935460 data:0x00000000
kworker/1:3-252 [001] .... 156.890434: rtcpu_vinotify_event: tstamp:5232377668 tag:CHANSEL_EMBED_SOF channel:0x23 frame:0 vi_tstamp:5231935779 data:0x00000004
kworker/1:3-252 [001] .... 156.890435: rtcpu_vinotify_event: tstamp:5232377824 tag:CHANSEL_EMBED_EOF channel:0x23 frame:0 vi_tstamp:5231935787 data:0x00000008
kworker/1:3-252 [001] .... 156.890437: rtcpu_vinotify_event: tstamp:5232377952 tag:ATOMP_EMB_DATA_DONE channel:0x23 frame:0 vi_tstamp:5231935808 data:0x00000000
kworker/1:3-252 [001] .... 156.890438: rtcpu_vinotify_event: tstamp:5232378103 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4213204128 data:0x0302000f
kworker/1:3-252 [001] .... 156.890439: rtcpu_vinotify_event: tstamp:5232378234 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:5231936127 data:0x000006e9
kworker/1:3-252 [001] .... 156.890440: rtcpu_vinotify_event: tstamp:5232378381 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:5231938905 data:0x00000001
kworker/1:3-252 [001] .... 156.890441: rtcpu_vinotify_event: tstamp:5232378511 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4213292864 data:0x0802000f
kworker/1:3-252 [001] .... 156.890442: rtcpu_vinotify_event: tstamp:5232378659 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4213474528 data:0x10000000
kworker/1:3-252 [001] .... 156.890444: rtcpu_vinotify_event: tstamp:5232378786 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4213500736 data:0x31000010
kworker/1:3-252 [001] .... 156.890445: rtcpu_vinotify_event: tstamp:5232698926 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:5232694323 data:0x087f0002
kworker/1:3-252 [001] .... 156.890446: rtcpu_vinotify_event: tstamp:5232699054 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:5232694349 data:0x00000000
kworker/1:3-252 [001] .... 156.890447: rtcpu_vinotify_event: tstamp:5232699205 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4237468192 data:0x0202000f
kworker/1:3-252 [001] .... 156.890448: rtcpu_vinotify_event: tstamp:5232699332 tag:FE channel:0x00 frame:0 vi_tstamp:5232694457 data:0x00000020
kworker/1:3-252 [001] .... 156.890449: rtcpu_vinotify_event: tstamp:5232699478 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:5232694460 data:0x00000000
kworker/1:3-252 [001] .... 156.890451: rtcpu_vinotify_event: tstamp:5232699607 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4237490816 data:0x0002000f
kworker/1:3-252 [001] .... 156.890452: rtos_queue_send_from_isr_failed: tstamp:5232705875 queue:0x0bcb2b38
kworker/1:3-252 [001] .... 156.890454: rtos_queue_send_from_isr_failed: tstamp:5232706024 queue:0x0bcb73a0
kworker/1:3-252 [001] .... 156.890455: rtos_queue_send_from_isr_failed: tstamp:5232706169 queue:0x0bcb8f20
kworker/1:3-252 [001] .... 156.890456: rtos_queue_send_from_isr_failed: tstamp:5232706309 queue:0x0bcb9ce0
kworker/1:3-252 [001] .... 156.890457: rtos_queue_send_from_isr_failed: tstamp:5232706448 queue:0x0bcbaaa0
vi-output, imx2-3010 [001] .... 156.917799: tegra_channel_capture_frame: sof:167.455378304
vi-output, imx2-3010 [001] .... 156.917802: tegra_channel_capture_frame: eof:167.479556064
kworker/1:3-252 [001] .... 156.941352: rtos_queue_peek_from_isr_failed: tstamp:5233071966 queue:0x0bcbb8b8
kworker/1:3-252 [001] .... 156.941354: rtcpu_vinotify_event: tstamp:5233158244 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4237516512 data:0x07020010
kworker/1:3-252 [001] .... 156.941356: rtcpu_vinotify_event: tstamp:5233158380 tag:FS channel:0x00 frame:0 vi_tstamp:5232977124 data:0x00000010
kworker/1:3-252 [001] .... 156.941357: rtcpu_vinotify_event: tstamp:5233158538 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:5232977127 data:0x00000000
kworker/1:3-252 [001] .... 156.941358: rtcpu_vinotify_event: tstamp:5233158672 tag:CHANSEL_EMBED_SOF channel:0x23 frame:0 vi_tstamp:5232977447 data:0x00000004
kworker/1:3-252 [001] .... 156.941359: rtcpu_vinotify_event: tstamp:5233158821 tag:CHANSEL_EMBED_EOF channel:0x23 frame:0 vi_tstamp:5232977454 data:0x00000008
kworker/1:3-252 [001] .... 156.941386: rtcpu_vinotify_event: tstamp:5233158948 tag:ATOMP_EMB_DATA_DONE channel:0x23 frame:0 vi_tstamp:5232977474 data:0x00000000
kworker/1:3-252 [001] .... 156.941387: rtcpu_vinotify_event: tstamp:5233159099 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4246532128 data:0x03020010
kworker/1:3-252 [001] .... 156.941388: rtcpu_vinotify_event: tstamp:5233159230 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:5232977793 data:0x000006e9
kworker/1:3-252 [001] .... 156.941389: rtcpu_vinotify_event: tstamp:5233159377 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:5232980572 data:0x00000001
kworker/1:3-252 [001] .... 156.941391: rtcpu_vinotify_event: tstamp:5233159507 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4246626976 data:0x08020010
kworker/1:3-252 [001] .... 156.941392: rtcpu_vinotify_event: tstamp:5233159656 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4246789504 data:0x10000000
kworker/1:3-252 [001] .... 156.941393: rtcpu_vinotify_event: tstamp:5233159800 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4246815680 data:0x31000011
kworker/1:3-252 [001] .... 156.941394: rtcpu_vinotify_event: tstamp:5233740595 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:5233735991 data:0x087f0002
kworker/1:3-252 [001] .... 156.941395: rtcpu_vinotify_event: tstamp:5233740728 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:5233736015 data:0x00000000
kworker/1:3-252 [001] .... 156.941396: rtcpu_vinotify_event: tstamp:5233740883 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4270801504 data:0x02020010
kworker/1:3-252 [001] .... 156.941398: rtcpu_vinotify_event: tstamp:5233741011 tag:FE channel:0x00 frame:0 vi_tstamp:5233736123 data:0x00000020
kworker/1:3-252 [001] .... 156.941400: rtos_queue_send_from_isr_failed: tstamp:5233746256 queue:0x0bcb2b38
kworker/1:3-252 [001] .... 156.941422: rtos_queue_send_from_isr_failed: tstamp:5233746404 queue:0x0bcb73a0
kworker/1:3-252 [001] .... 156.941423: rtos_queue_send_from_isr_failed: tstamp:5233746549 queue:0x0bcb8f20
kworker/1:3-252 [001] .... 156.941424: rtos_queue_send_from_isr_failed: tstamp:5233746688 queue:0x0bcb9ce0
kworker/1:3-252 [001] .... 156.941425: rtos_queue_send_from_isr_failed: tstamp:5233746824 queue:0x0bcbaaa0
kworker/1:3-252 [001] .... 156.941427: rtcpu_vinotify_event: tstamp:5234184284 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:5233736127 data:0x00000000
kworker/1:3-252 [001] .... 156.941428: rtcpu_vinotify_event: tstamp:5234184420 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4270829792 data:0x00020010
kworker/1:3-252 [001] .... 156.941430: rtcpu_vinotify_event: tstamp:5234184573 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4270849888 data:0x07020011
kworker/1:3-252 [001] .... 156.941431: rtcpu_vinotify_event: tstamp:5234184704 tag:FS channel:0x00 frame:0 vi_tstamp:5234018791 data:0x00000010
kworker/1:3-252 [001] .... 156.941432: rtcpu_vinotify_event: tstamp:5234184855 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:5234018794 data:0x00000000
kworker/1:3-252 [001] .... 156.941433: rtcpu_vinotify_event: tstamp:5234184987 tag:CHANSEL_EMBED_SOF channel:0x23 frame:0 vi_tstamp:5234019113 data:0x00000004
kworker/1:3-252 [001] .... 156.941434: rtcpu_vinotify_event: tstamp:5234185135 tag:CHANSEL_EMBED_EOF channel:0x23 frame:0 vi_tstamp:5234019121 data:0x00000008
kworker/1:3-252 [001] .... 156.941435: rtcpu_vinotify_event: tstamp:5234185263 tag:ATOMP_EMB_DATA_DONE channel:0x23 frame:0 vi_tstamp:5234019141 data:0x00000000
kworker/1:3-252 [001] .... 156.941437: rtcpu_vinotify_event: tstamp:5234185412 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4279865440 data:0x03020011
kworker/1:3-252 [001] .... 156.941438: rtcpu_vinotify_event: tstamp:5234185542 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:5234019460 data:0x000006e9
kworker/1:3-252 [001] .... 156.941439: rtcpu_vinotify_event: tstamp:5234185687 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:5234022238 data:0x00000001
kworker/1:3-252 [001] .... 156.941440: rtcpu_vinotify_event: tstamp:5234185814 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4279960352 data:0x08020011
kworker/1:3-252 [001] .... 156.941441: rtcpu_vinotify_event: tstamp:5234185962 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4280140352 data:0x10000000
kworker/1:3-252 [001] .... 156.941442: rtcpu_vinotify_event: tstamp:5234186089 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4280166560 data:0x31000012
vi-output, imx2-3010 [001] .... 156.951139: tegra_channel_capture_frame: sof:167.488711616
vi-output, imx2-3010 [001] .... 156.951141: tegra_channel_capture_frame: eof:167.512889376
vi-output, imx2-3010 [001] .... 156.984399: tegra_channel_capture_frame: sof:167.522044960
vi-output, imx2-3010 [001] .... 156.984402: tegra_channel_capture_frame: eof:167.546222720
kworker/1:3-252 [001] .... 156.992352: rtcpu_vinotify_event: tstamp:5234782262 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:5234777657 data:0x087f0002
kworker/1:3-252 [001] .... 156.992354: rtcpu_vinotify_event: tstamp:5234782402 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:5234777681 data:0x00000000
kworker/1:3-252 [001] .... 156.992358: rtos_queue_send_from_isr_failed: tstamp:5234788492 queue:0x0bcb2b38
kworker/1:3-252 [001] .... 156.992359: rtos_queue_send_from_isr_failed: tstamp:5234788641 queue:0x0bcb73a0
kworker/1:3-252 [001] .... 156.992360: rtos_queue_send_from_isr_failed: tstamp:5234788787 queue:0x0bcb8f20
kworker/1:3-252 [001] .... 156.992362: rtos_queue_send_from_isr_failed: tstamp:5234788927 queue:0x0bcb9ce0
kworker/1:3-252 [001] .... 156.992363: rtos_queue_send_from_isr_failed: tstamp:5234789066 queue:0x0bcbaaa0
kworker/1:3-252 [001] .... 156.992364: rtcpu_vinotify_event: tstamp:5235072055 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4304140128 data:0x02020011
kworker/1:3-252 [001] .... 156.992366: rtcpu_vinotify_event: tstamp:5235072189 tag:FE channel:0x00 frame:0 vi_tstamp:5234777790 data:0x00000020
kworker/1:3-252 [001] .... 156.992367: rtcpu_vinotify_event: tstamp:5235072348 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:5234777793 data:0x00000000
kworker/1:3-252 [001] .... 156.992368: rtcpu_vinotify_event: tstamp:5235072482 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4304163040 data:0x00020011
kworker/1:3-252 [001] .... 156.992393: rtcpu_vinotify_event: tstamp:5235072632 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4304183200 data:0x07020012
kworker/1:3-252 [001] .... 156.992395: rtcpu_vinotify_event: tstamp:5235072760 tag:FS channel:0x00 frame:0 vi_tstamp:5235060459 data:0x00000010
kworker/1:3-252 [001] .... 156.992396: rtcpu_vinotify_event: tstamp:5235072908 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:5235060461 data:0x00000000
kworker/1:3-252 [001] .... 156.992397: rtcpu_vinotify_event: tstamp:5235073035 tag:CHANSEL_EMBED_SOF channel:0x23 frame:0 vi_tstamp:5235060780 data:0x00000004
kworker/1:3-252 [001] .... 156.992398: rtcpu_vinotify_event: tstamp:5235073183 tag:CHANSEL_EMBED_EOF channel:0x23 frame:0 vi_tstamp:5235060787 data:0x00000008
kworker/1:3-252 [001] .... 156.992400: rtcpu_vinotify_event: tstamp:5235073310 tag:ATOMP_EMB_DATA_DONE channel:0x23 frame:0 vi_tstamp:5235060808 data:0x00000000
kworker/1:3-252 [001] .... 156.992402: rtcpu_vinotify_event: tstamp:5235073458 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4313198720 data:0x03020012
kworker/1:3-252 [001] .... 156.992403: rtcpu_vinotify_event: tstamp:5235073586 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:5235061127 data:0x000006e9
kworker/1:3-252 [001] .... 156.992404: rtcpu_vinotify_event: tstamp:5235073733 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:5235063905 data:0x00000001
kworker/1:3-252 [001] .... 156.992405: rtcpu_vinotify_event: tstamp:5235073861 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4313293824 data:0x08020012
kworker/1:3-252 [001] .... 156.992406: rtcpu_vinotify_event: tstamp:5235074009 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4313454368 data:0x10000000
kworker/1:3-252 [001] .... 156.992407: rtcpu_vinotify_event: tstamp:5235074136 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4313480544 data:0x31000013
kworker/1:3-252 [001] .... 156.992432: rtos_queue_send_from_isr_failed: tstamp:5235827483 queue:0x0bcb2b38
kworker/1:3-252 [001] .... 156.992433: rtos_queue_send_from_isr_failed: tstamp:5235827631 queue:0x0bcb73a0
kworker/1:3-252 [001] .... 156.992434: rtos_queue_send_from_isr_failed: tstamp:5235827776 queue:0x0bcb8f20
kworker/1:3-252 [001] .... 156.992436: rtos_queue_send_from_isr_failed: tstamp:5235827916 queue:0x0bcb9ce0
kworker/1:3-252 [001] .... 156.992437: rtos_queue_send_from_isr_failed: tstamp:5235828052 queue:0x0bcbaaa0
kworker/1:3-252 [001] .... 156.992438: rtcpu_vinotify_event: tstamp:5235844495 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:5235819323 data:0x087f0002
kworker/1:3-252 [001] .... 156.992439: rtcpu_vinotify_event: tstamp:5235844630 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:5235819348 data:0x00000000
kworker/1:3-252 [001] .... 156.992440: rtcpu_vinotify_event: tstamp:5235844782 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4337468192 data:0x02020012
kworker/1:3-252 [001] .... 156.992442: rtcpu_vinotify_event: tstamp:5235844910 tag:FE channel:0x00 frame:0 vi_tstamp:5235819458 data:0x00000020
kworker/1:3-252 [001] .... 156.992443: rtcpu_vinotify_event: tstamp:5235845061 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:5235819460 data:0x00000000
kworker/1:3-252 [001] .... 156.992444: rtcpu_vinotify_event: tstamp:5235845189 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4337490816 data:0x00020012
kworker/1:3-252 [001] .... 156.992445: rtcpu_vinotify_event: tstamp:5235845338 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4337510496 data:0x07020013
vi-output, imx2-3010 [001] .... 157.017757: tegra_channel_capture_frame: sof:167.555378304
vi-output, imx2-3010 [001] .... 157.017760: tegra_channel_capture_frame: eof:167.579556064
kworker/1:3-252 [001] .... 157.043354: rtcpu_vinotify_event: tstamp:5236109276 tag:FS channel:0x00 frame:0 vi_tstamp:5236102125 data:0x00000010
kworker/1:3-252 [001] .... 157.043357: rtcpu_vinotify_event: tstamp:5236109434 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:5236102128 data:0x00000000
kworker/1:3-252 [001] .... 157.043358: rtcpu_vinotify_event: tstamp:5236109569 tag:CHANSEL_EMBED_SOF channel:0x23 frame:0 vi_tstamp:5236102447 data:0x00000004
kworker/1:3-252 [001] .... 157.043360: rtcpu_vinotify_event: tstamp:5236109722 tag:CHANSEL_EMBED_EOF channel:0x23 frame:0 vi_tstamp:5236102454 data:0x00000008
kworker/1:3-252 [001] .... 157.043361: rtcpu_vinotify_event: tstamp:5236109852 tag:ATOMP_EMB_DATA_DONE channel:0x23 frame:0 vi_tstamp:5236102474 data:0x00000000
kworker/1:3-252 [001] .... 157.043362: rtcpu_vinotify_event: tstamp:5236110001 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4346532096 data:0x03020013
kworker/1:3-252 [001] .... 157.043363: rtcpu_vinotify_event: tstamp:5236110128 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:5236102793 data:0x000006e9
kworker/1:3-252 [001] .... 157.043365: rtcpu_vinotify_event: tstamp:5236110275 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:5236105572 data:0x00000001
kworker/1:3-252 [001] .... 157.043366: rtcpu_vinotify_event: tstamp:5236110403 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4346626944 data:0x08020013
kworker/1:3-252 [001] .... 157.043369: rtcpu_vinotify_event: tstamp:5236576903 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4346878752 data:0x10000000
kworker/1:3-252 [001] .... 157.043370: rtcpu_vinotify_event: tstamp:5236577047 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4346904960 data:0x31000014
kworker/1:3-252 [001] .... 157.043398: rtos_queue_send_from_isr_failed: tstamp:5236869582 queue:0x0bcb2b38
