Not able to set EMC clock to maximum frequency
Running the jetsion_clocks.sh script provided in the L4T distribution is correctly setting the CPUs and GPUs to their Maximum frequency, but the EMC clock is still set at 204 MHz.
root@tegra-ubuntu:/home/ubuntu# ./jetson_clocks.sh
root@tegra-ubuntu:/home/ubuntu# ./jetson_clocks.sh --show
SOC family:tegra210  Machine:jetson_tx1
Online CPUs: 0-3
CPU Cluster Switching: Disabled
cpu0: Gonvernor=interactive MinFreq=1734000 MaxFreq=1734000 CurrentFreq=1734000
cpu1: Gonvernor=interactive MinFreq=1734000 MaxFreq=1734000 CurrentFreq=1734000
cpu2: Gonvernor=interactive MinFreq=1734000 MaxFreq=1734000 CurrentFreq=1734000
cpu3: Gonvernor=interactive MinFreq=1734000 MaxFreq=1734000 CurrentFreq=1734000
GPU MinFreq=998400000 MaxFreq=998400000 CurrentFreq=998400000
EMC MinFreq=12750000 MaxFreq=1600000000<b> <u>CurrentFreq=204000000 FreqOverride=1</u></b>
Fan: speed=255
I have also tried directly writing to the /sys/debug entries as shown in the L4T development guide with the same result, the EMC frequency stays at 204 MHz.
echo 1600000000 > /sys/kernel/debug/clk/override.emc/clk_update_rate
echo 1 > /sys/kernel/debug/clk/override.emc/clk_state
Is there some other power management or frequency scaling setting that I need to set as well to force the memory to always run at the maximum frequency.
Hi wkrit,
I can modify the emc frequency by your method. Could you give out the dmesg when you override the emc clk?
Hi Wayne,
Here is the dmesg output after I try to run the jetson_clocks.sh script. THe EMC clock is still set to 204 MHz.
[   62.756213] gk20a 57000000.gpu: railgate is disabled.
[  415.396211] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[  415.442578] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[  415.474898] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[  415.511239] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[  415.520491] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[  415.530597] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[  415.558713] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[  415.567726] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[  415.589427] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[  540.686312] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
Looking into the kernel source we noticed that it would not set the EMC clock to a given rate if the EMC training was not successful. I attached a serial port to the board and can see the following successful EMC training.
[0001.391] Total time taken by TegraBoot 1242014 us
[0001.396] Starting CPU & Halting co-processor
64NOTICE:  BL31: v1.2(release):cc5fd7c
NOTICE:  BL31: Built : 00:37:02, Jul 20 2017
NOTICE:  Trusty image missing.
ERROR:   Error initializing runtime service trusty_fast
[0001.536] RamCode = 0
[0001.558] LPDDR4 Training: Read DT: Number of tables = 10
[0001.563] EMC Training (SRC-freq: 204000; DST-freq: 40800)
[0001.568] EMC Training Skipped
[0001.571] EMC Training (SRC-freq: 204000; DST-freq: 68000)
[0001.576] EMC Training Skipped
[0001.579] EMC Training (SRC-freq: 204000; DST-freq: 102000)
[0001.584] EMC Training Skipped
[0001.587] EMC Training (SRC-freq: 204000; DST-freq: 204000)
[0001.592] EMC Training Skipped
[0001.595] EMC Training (SRC-freq: 204000; DST-freq: 408000)
[0001.601] EMC Training Successful
[0001.604] EMC Training (SRC-freq: 204000; DST-freq: 665600)
[0001.610] EMC Training Successful
[0001.613] EMC Training (SRC-freq: 204000; DST-freq: 800000)
[0001.624] EMC Training Successful
[0001.627] EMC Training (SRC-freq: 204000; DST-freq: 1065600)
[0001.650] EMC Training Successful
[0001.653] EMC Training (SRC-freq: 204000; DST-freq: 1331200)
[0001.675] EMC Training Successful
[0001.678] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.697] EMC Training Successful
[0001.701] Switching to 800000 KHz Success
[0001.710] RamCode = 0
[0001.714] DT Write: emc-table@40800 succeeded
[0001.721] DT Write: emc-table@68000 succeeded
[0001.727] DT Write: emc-table@102000 succeeded
[0001.733] DT Write: emc-table@204000 succeeded
[0001.739] DT Write: emc-table@408000 succeeded
[0001.745] DT Write: emc-table@665600 succeeded
[0001.751] DT Write: emc-table@800000 succeeded
[0001.757] DT Write: emc-table@1065600 succeeded
[0001.763] DT Write: emc-table@1331200 succeeded
[0001.769] DT Write: emc-table@1600000 succeeded
[0001.774] LPDDR4 Training: Write DT: Number of tables = 10
I should have stated this earlier, but I have a Jetson TX1 developement board , with L4T v28.1. The additional software we have installed above the L4T distribution does not modify the kernel or device tree at this time.
Hello again,
We ended up just re-flashing the development board with L4T 28.1 plus our software and the EMC clock problem went away. I can now again use the jetson_clocks.sh script as-is to set the CPU, GPU and EMC clocks all to their maximum values.
