Nsight Compute issue
Software Version
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
[*] DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.1.10844
other
Host Machine Version
[*] native Ubuntu Linux 20.04 Host installed with SDK Manager
other
Hi, I can successfully run Nsight-system at my host laptop through SSH config.
But I med below issue with Nsight-compute at my host laptop.
Pls kindly help me on this, thank you in advance!
Dear @ting.wang,
Did you follow Nsight Compute :: Nsight Compute Documentation ?
Do you see other executables running?
Is trtexec executable path in the log for host or target?
Thanks for all of your reminder.
One quick question, does Nsight compute can used for tensor-rt profiling?
I saw the example case just for cuda program .
I strictly follow the documentation.
No other executable is running.
I already set the executable as below. this trtexec and its path are working well in Nsight system.
The problem is why I have this error?
ERROR: ld.so: object ‘/tmp/var/target/linux-desktop-glibc_2_11_3-x64/libcuda-injection.so’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
The similar problem is here, finally the solution can only work at remote AGX Xavier target side.
I want it working on my host laptop.
I asked if the nsight compute working with any other sample other than trtexec application? I will check repro this issue. Mean while could you check if NSIGHT Compute error works for you.
@SivaRamaKrishnaNV Are you sure you have related experience using Nsight- compute on Orin?
I feel most of your suggestion/instructions are misleading.
Sorry I find the reason and solve it.Nothing related to those suggestions and instructions.
Dear @ting.wang,
I am glad to hear the issue is resolved.
I have not tested nsight compute for remote profile.
Is there any gap in the nsight documentation steps for remote profiling? Could you share how the issue is resolved to help others in community?
