System Configuration
Jetson Model: AGX Orin
JetPack Version: 6.2
CUDA Version: 12.6
Linux Kernel Version: 5.15.148-tegra
Nsight Compute Version: 2024.3.1.0
I’m Trying to Do
Profile my standalone CUDA application with Nsight Compute on the Jetson:
sudo ncu ./MyCudaApp
Observed Behavior
No package.json
Please add a package.json to the current directory, specify the --packageFile or --packageData options, or pipe a package.json to stdin and specify --stdin.
When I try to specify an output file:
sudo ncu -o profile ./MyCudaApp
I get:
error: unknown option '--o'
Yet ncu --help clearly lists -o|--output as a valid flag.
I’ve Tried
Running
ncu --helpto confirm-oexists -
Running
ncu -o profile ./MyCudaAppboth from$PATHand from the ncu installation folder -
Searching the Nsight Compute documentation for any mention of a required
package.json -
Confirming that this tooling works as expected on x86 hosts
Full Console Log
$ sudo ncu ./MyCudaApp
No package.json
$ sudo ncu -o profile ./MyCudaApp
Background With earlier JetPack releases (6.0 with CUDA 12.2), the exact same sudo ncu ./MyCudaApp and sudo ncu -o profile ./MyCudaApp commands worked without issue. This problem only started after upgrading to JetPack 6.2.
Questions
Why is Nsight Compute expecting a
package.jsonon Jetson AGX Orin? -
How can I profile my binary without supplying a JSON package?
Is there an extra installation or environment step I’m missing on JetPack 6.2 / CUDA 12.6?
