Nsys GetLogicalProcessorInformation GetSystemInfo mismatch
I wanted to use NSight Systems 2024.4.1 but it reports:
“Cannot connect to the target. Please try again.”
When launching nsys from the terminal it exits with the following message:
“GetLogicalProcessorInformationEx num of cores 96 does not match GetSystemInfo num of cores 48.”
The system has 2x AMD EPYC 74F3 24-Core Processor, 3201 Mhz, 24 Core(s), 48 Logical Processor(s)
How can I make nsys to work?
@rknight to respond.
Hi hrvthzs,
What nsys CLI command line did you try when the error occurred?
What OS is installed on this system?
Hi rknight,
nsys profile path-to-binary
I can execute nsys launch path-to-binary but when I do nsys start it prints again the same message.
Windows Server 2022 Standard
Sorry, but I’m going to ask the nsight systems Windows team to help. @dofek Can you help?
I have a similar problem with a Dual Xeon Processor system. See NSight Systems 2024.4.1 fails to profile on multi-CPU target machine for more information
This system is running Windows 10 BTW.
So this has now been reported twice, both times on Windows OS systems. @dofek can you loop back on this?
