Im trying to install numba package on jetson xavier, numba respective packages llvmlite version had issue. I tried lot and did different ways. But i won’t be able to proceed and can’t able to resolve issue. Please help us to install package dependency issue.
Building wheels for collected packages: llvmlite
Building wheel for llvmlite (setup.py) ... error
ERROR: Complete output from command /usr/bin/python3 -u -c 'import setuptools, tokenize;__file__='"'"'/tmp/pip-install-bixpkw28/llvmlite/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-1wk_3yk6 --python-tag cp36:
ERROR: running bdist_wheel
/usr/bin/python3 /tmp/pip-install-bixpkw28/llvmlite/ffi/build.py
LLVM version... Traceback (most recent call last):
File "/tmp/pip-install-bixpkw28/llvmlite/ffi/build.py", line 105, in main_posix
out = subprocess.check_output([llvm_config, '--version'])
File "/usr/lib/python3.6/subprocess.py", line 336, in check_output
**kwargs).stdout
File "/usr/lib/python3.6/subprocess.py", line 403, in run
with Popen(*popenargs, **kwargs) as process:
File "/usr/lib/python3.6/subprocess.py", line 709, in __init__
restore_signals, start_new_session)
File "/usr/lib/python3.6/subprocess.py", line 1344, in _execute_child
raise child_exception_type(errno_num, err_msg, err_filename)
FileNotFoundError: [Errno 2] No such file or directory: 'llvm-config': 'llvm-config'
During handling of the above exception, another exception occurred:
File "/tmp/pip-install-bixpkw28/llvmlite/ffi/build.py", line 167, in <module>
main()
File "/tmp/pip-install-bixpkw28/llvmlite/ffi/build.py", line 157, in main
main_posix('linux', '.so')
File "/tmp/pip-install-bixpkw28/llvmlite/ffi/build.py", line 108, in main_posix
"to the path for llvm-config" % (llvm_config,))
RuntimeError: llvm-config failed executing, please point LLVM_CONFIG to the path for llvm-config
error: command '/usr/bin/python3' failed with exit status 1
ERROR: Failed building wheel for llvmlite
Running setup.py clean for llvmlite
Failed to build llvmlite
Installing collected packages: llvmlite, numba
Running setup.py install for llvmlite ... error
ERROR: Complete output from command /usr/bin/python3 -u -c 'import setuptools, tokenize;__file__='"'"'/tmp/pip-install-bixpkw28/llvmlite/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-2px7ila1/install-record.txt --single-version-externally-managed --compile:
ERROR: running install
running build
got version from file /tmp/pip-install-bixpkw28/llvmlite/llvmlite/_version.py {'version': '0.28.0', 'full': '685b7b6941617f616f3f0b609e381af52da26782'}
running build_ext
**kwargs).stdout
main()
ERROR: Command "/usr/bin/python3 -u -c 'import setuptools, tokenize;__file__='"'"'/tmp/pip-install-bixpkw28/llvmlite/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-2px7ila1/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-install-bixpkw28/llvmlite/
