Installation of numba on the jetson nano
i’m trying to download the library numba on my Jetson Nano. I followed the instruction described in this tutorial:
https://github.com/epicmario7133/install-Packages-Jetson-ARM-Family/blob/master/README.md
but i got this error:
``nvidia@nvidia-desktop:~$ pip3 install numba==0.47
Defaulting to user installation because normal site-packages is not writeable
Collecting numba==0.47
Downloading numba-0.47.0.tar.gz (1.9 MB)
|████████████████████████████████| 1.9 MB 2.2 MB/s
Requirement already satisfied: llvmlite>=0.31.0dev0 in ./.local/lib/python3.6/site-packages (from numba==0.47) (0.36.0)
Requirement already satisfied: numpy in ./.local/lib/python3.6/site-packages (from numba==0.47) (1.19.5)
Requirement already satisfied: setuptools in ./.local/lib/python3.6/site-packages (from numba==0.47) (57.0.0)
Building wheels for collected packages: numba
Building wheel for numba (setup.py) … error
ERROR: Command errored out with exit status -4:
command: /usr/bin/python3.6 -u -c ‘import io, os, sys, setuptools, tokenize; sys.argv[0] = ‘"’"’/tmp/pip-install-yuxpeptm/numba_3045ac3c092f4285876678b04c6cc35a/setup.py’“'”‘; file =’“'”‘/tmp/pip-install-yuxpeptm/numba_3045ac3c092f4285876678b04c6cc35a/setup.py’“'”‘;f = getattr(tokenize, ‘"’“‘open’”’“‘, open)( file ) if os.path.exists( file ) else io.StringIO(’”‘“‘from setuptools import setup; setup()’”’“‘);code = f.read().replace(’”‘"’\r\n’“'”‘, ‘"’"’\n’“'”‘);f.close();exec(compile(code, file , ‘"’“‘exec’”’"‘))’ bdist_wheel -d /tmp/pip-wheel-d0h5x_il
cwd: /tmp/pip-install-yuxpeptm/numba_3045ac3c092f4285876678b04c6cc35a/
Complete output (0 lines):
ERROR: Failed building wheel for numba
Running setup.py clean for numba
command: /usr/bin/python3.6 -u -c ‘import io, os, sys, setuptools, tokenize; sys.argv[0] = ‘"’"’/tmp/pip-install-yuxpeptm/numba_3045ac3c092f4285876678b04c6cc35a/setup.py’“'”‘; file =’“'”‘/tmp/pip-install-yuxpeptm/numba_3045ac3c092f4285876678b04c6cc35a/setup.py’“'”‘;f = getattr(tokenize, ‘"’“‘open’”’“‘, open)( file ) if os.path.exists( file ) else io.StringIO(’”‘“‘from setuptools import setup; setup()’”’“‘);code = f.read().replace(’”‘"’\r\n’“'”‘, ‘"’"’\n’“'”‘);f.close();exec(compile(code, file , ‘"’“‘exec’”’"‘))’ clean --all
ERROR: Failed cleaning build dir for numba
Failed to build numba
Installing collected packages: numba
Running setup.py install for numba … error
command: /usr/bin/python3.6 -u -c ‘import io, os, sys, setuptools, tokenize; sys.argv[0] = ‘"’"’/tmp/pip-install-yuxpeptm/numba_3045ac3c092f4285876678b04c6cc35a/setup.py’“'”‘; file =’“'”‘/tmp/pip-install-yuxpeptm/numba_3045ac3c092f4285876678b04c6cc35a/setup.py’“'”‘;f = getattr(tokenize, ‘"’“‘open’”’“‘, open)( file ) if os.path.exists( file ) else io.StringIO(’”‘“‘from setuptools import setup; setup()’”’“‘);code = f.read().replace(’”‘"’\r\n’“'”‘, ‘"’"’\n’“'”‘);f.close();exec(compile(code, file , ‘"’“‘exec’”’"‘))’ install --record /tmp/pip-record-kvb8y68o/install-record.txt --single-version-externally-managed --user --prefix= --compile --install-headers /home/nvidia/.local/include/python3.6m/numba
ERROR: Command errored out with exit status -4: /usr/bin/python3.6 -u -c ‘import io, os, sys, setuptools, tokenize; sys.argv[0] = ‘"’"’/tmp/pip-install-yuxpeptm/numba_3045ac3c092f4285876678b04c6cc35a/setup.py’“'”‘; file =’“'”‘/tmp/pip-install-yuxpeptm/numba_3045ac3c092f4285876678b04c6cc35a/setup.py’“'”‘;f = getattr(tokenize, ‘"’“‘open’”’“‘, open)( file ) if os.path.exists( file ) else io.StringIO(’”‘“‘from setuptools import setup; setup()’”’“‘);code = f.read().replace(’”‘"’\r\n’“'”‘, ‘"’"’\n’“'”‘);f.close();exec(compile(code, file , ‘"’“‘exec’”’"‘))’ install --record /tmp/pip-record-kvb8y68o/install-record.txt --single-version-externally-managed --user --prefix= --compile --install-headers /home/nvidia/.local/include/python3.6m/numba Check the logs for full command output.
WARNING: You are using pip version 21.1.3; however, version 21.2.4 is available.
You should consider upgrading via the ‘/usr/bin/python3.6 -m pip install --upgrade pip’ command.
Moving this topic to the Jetson Nano category so support has visibility.
Sorry for the late responsem it this still an issue to support?
The link for the instruction is invalidate.
