Hi, i find nv-nsight gui can execute remote binary (jetson xavier) with ssh login, and does nv-nsight-cu-cli support this feature?? for example, pass the ssh username and password
felix_dt
2
You cannot launch remote executables using the Nsight Compute command line interface (CLI). You can use the CLI to attach to a remotely application, as long as it’s launched via a local CLI on the target system. See Nsight Compute CLI :: Nsight Compute Documentation for details.
Related topics
| Nsight compute CLI commands for remote profiling on Jetson TX2 | 3 | 991 | June 8, 2022 | |
| Nsight Compute 2024.3.1 remote launch failed | 10 | 388 | January 3, 2025 | |
| nv-nsight-cu command in Xshell | 3 | 1953 | October 25, 2019 | |
| Nsight Cannot Find Remote Application | 7 | 626 | April 1, 2024 | |
| Remote Profiling from CLI (Jetson AGX) | 3 | 1290 | March 14, 2022 | |
| Ncu does not launch process when called remotely, but does when called locally | 1 | 540 | July 30, 2020 | |
| Nsight compute ssh connection fail | 3 | 910 | May 17, 2024 | |
| The Compute can not attach the kernel on remote linux machine | 9 | 858 | November 4, 2022 | |
| Unable to run Nsight remote monitor on linux machine using CLI | 4 | 220 | August 29, 2024 | |
| Attach via SSH from MacOS host | 4 | 1000 | July 11, 2023 |
