tnwilly
1
I’m profiling with Nsight Compute remotely.
My host is linux OS and the device is AGX Orin.
Please let me know if this is a bug or what?
My step:
1) sudo /opt/nvidia/nsight-compute/2024.3.1/ncu-ui
2) Enter device IP and password
3) Launch and failed
I also tried to use 2024.3.2 but there’s no ARM device for choosing.
veraj
2
Hi, @tnwilly
From the screenshot, it seems there is permission issue.
I know that but I’ve used sudo why still see this?
veraj
4
Where do you run > sudo /opt/nvidia/nsight-compute/2024.3.1/ncu-ui
Your host machine or the AGX Orin?
I run the command on my host, and want to profile remotely.
The target device is AGX Orin.
veraj
6
Please check if ncu has been copied to the Orin side under /tmp/var/
If yes, please run $ncu sample directly in Orin to see what happens.
I can see ncu under the subfolder of /tmp/var/.
Profile with it directly on AGX Orin works well.
So, what’s wrong will remote profiling?
veraj
8
Please try launch in host without sudo.
If this still repro, I will contact our AGX Orin test team to check
veraj
10
Did you SSH connect to the root user ?
Sure, I do connect to the root.
