Hello!
I’m working with an Nvidia AGX Orin developer kit with jetpack 5.1.2 and Intel D435i.
We mounted it on our custom mobile base to test the Nvblox module.
After some testing, we noticed that the cost map generated in some areas is too wide for the robot. I tried looking for parameters similar to those used in ROS1 for the cost map, but they are not present in nvblox_example_bringup. Can anyone help us adjust the parameters to reduce the inflation map in the cost map generated for nvblox? and some tips to adjust the rest of the parameters? we have been looking in the config folder inside the nvblox_example_bringup
Welcome to the Isaac ROS forum.
Before moving forward, have you tried the new Isaac ROS 3.0? We have introduced many new updates on Isaac ROS nvblox.
For comprehensive documentation on Isaac ROS 3.0, please visit: ROS Parameters — isaac_ros_docs documentation
Best,
Raffaello
Hello Rafaello,
Thanks for the reply. We don’t want to update because we have seen some problems with Intel D435i and Jetpack 6.0 on the forum and we are not sure if the problem is only with the Orin Nano or also occurs in the Orin AGX.
We recently fixed the issue on the Realsense camera.
Simply run sudo apt-get update and reinstall the package to make it work.
I suggest working with the latest version of Isaac ROS, where we’ve added many updates and made improvements compared to the previous version.
Raffaello
