[Nvblox] Issues with nvblox: RViz2 Rendering Crash and 3D Reconstruction Quality
Hi everyone,
I’m trying to use nvblox for 3D object reconstruction, but I’m running into visual and generation issues. I am able to generate the point cloud and the TSDF layer marker, but RViz crashes when I try to visualize the mesh or the occupancy grid.
System Specs:
  • Environment: Isaac ROS (Docker container)
  • Simulation: Isaac Lab
  • GPU: NVIDIA GeForce RTX 3080 Ti
  • ROS 2 Version: Humble
  • Isaac ROS-nvblox Version: release-3.2
    Here is my current node graph:
This is the point cloud generated from Isaac Lab (visible in RViz):
And here is the tsdf_layer_marker working correctly:
When I subscribe to the mesh or occupancy grid topics in RViz, the RViz process immediately dies with the following Ogre geometry error:
[rviz2-4] [ERROR] [1776881895.064336313] [rviz2]: ItemIdentityException: Unable to locate geometry program called rviz/glsl150/box.geom. in GpuProgramUsage::_getProgramByName at ./.obj-x86_64-linux-gnu/ogre-v1.12.1-prefix/src/ogre-v1.12.1/OgreMain/src/OgreGpuProgramUsage.cpp (line 92)
[rviz2-4] terminate called after throwing an instance of ‘Ogre::ItemIdentityException’
[rviz2-4] what(): ItemIdentityException: Unable to locate geometry program called rviz/glsl150/box.geom. in GpuProgramUsage::_getProgramByName at ./.obj-x86_64-linux-gnu/ogre-v1.12.1-prefix/src/ogre-v1.12.1/OgreMain/src/OgreGpuProgramUsage.cpp (line 92)
[ERROR] [rviz2-4]: process has died [pid 2384310, exit code -6, cmd ‘/opt/ros/humble/lib/rviz2/rviz2 -d /workspaces/isaac_ros-dev/src/nbv_ros2_bridge/rviz/nbv_config.rviz --ros-args -r __node:=rviz2’].c
Despite the crash, I can still use the save_ply service to export the mesh. However, the resulting reconstruction looks incorrect:
Finally, here is the output log from my nvblox node:
admin@quillay:/workspaces/isaac_ros-dev$ ros2 launch nbv_ros2_bridge nbv_full_stack.launch.py
[INFO] [launch]: All log files can be found below /home/admin/.ros/log/2026-04-22-14-16-12-166053-quillay-2384303
[INFO] [launch]: Default logging verbosity is set to INFO
[INFO] [static_transform_publisher-1]: process started with pid [2384304]
[INFO] [robot_state_publisher-2]: process started with pid [2384306]
[INFO] [nvblox_node-3]: process started with pid [2384308]
[INFO] [rviz2-4]: process started with pid [2384310]
[static_transform_publisher-1] [INFO] [1776881772.234909235] [world_to_base]: Spinning until stopped - publishing transform
[static_transform_publisher-1] translation: (‘0.000000’, ‘0.000000’, ‘0.000000’)
[static_transform_publisher-1] rotation: (‘0.000000’, ‘0.000000’, ‘0.000000’, ‘1.000000’)
[static_transform_publisher-1] from ‘world’ to ‘base_link’
[robot_state_publisher-2] [WARN] [1776881772.239576759] [kdl_parser]: The root link base_link has an inertia specified in the URDF, but KDL does not support a root link with an inertia. As a workaround, you can add an extra dummy link to your URDF.
[robot_state_publisher-2] [INFO] [1776881772.239648866] [robot_state_publisher]: got segment base_link
[robot_state_publisher-2] [INFO] [1776881772.239683490] [robot_state_publisher]: got segment gripper_frame_link
[robot_state_publisher-2] [INFO] [1776881772.239688062] [robot_state_publisher]: got segment gripper_link
[robot_state_publisher-2] [INFO] [1776881772.239691789] [robot_state_publisher]: got segment lower_arm_link
[robot_state_publisher-2] [INFO] [1776881772.239695420] [robot_state_publisher]: got segment moving_jaw_so101_v1_link
[robot_state_publisher-2] [INFO] [1776881772.239699066] [robot_state_publisher]: got segment shoulder_link
[robot_state_publisher-2] [INFO] [1776881772.239702461] [robot_state_publisher]: got segment upper_arm_link
[robot_state_publisher-2] [INFO] [1776881772.239705818] [robot_state_publisher]: got segment wrist_link
[rviz2-4] QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to ‘/tmp/runtime-admin’
[rviz2-4] [INFO] [1776881772.729127074] [rviz2]: Stereo is NOT SUPPORTED
[rviz2-4] [INFO] [1776881772.729245002] [rviz2]: OpenGl version: 4.6 (GLSL 4.6)
[rviz2-4] [INFO] [1776881772.765175403] [rviz2]: Stereo is NOT SUPPORTED
[nvblox_node-3] [INFO] [1776881772.989681948] [nvblox_node]: Create nvblox cuda stream with type: kBlocking
[nvblox_node-3] I0422 14:16:13.003080 2384308 block_memory_pool_impl.h:65] Expanding the memory pool with 2048 blocks. Number of allocated blocks: 2048
[nvblox_node-3] I0422 14:16:13.010110 2384308 gpu_hash_interface_impl.cuh:83] Creating a GPUHashImpl with requested capacity of 4096 blocks. Real capacity: 4096
[nvblox_node-3] I0422 14:16:13.010160 2384308 layer_cake_impl.h:32] Adding Layer with type: N6nvblox15VoxelBlockLayerINS_9TsdfVoxelEEE, voxel_size: 0.05, and memory_type: kDevice to LayerCake.
[nvblox_node-3] I0422 14:16:13.013967 2384308 block_memory_pool_impl.h:65] Expanding the memory pool with 2048 blocks. Number of allocated blocks: 2048
[nvblox_node-3] I0422 14:16:13.016039 2384308 gpu_hash_interface_impl.cuh:83] Creating a GPUHashImpl with requested capacity of 4096 blocks. Real capacity: 4096
[nvblox_node-3] I0422 14:16:13.017624 2384308 layer_cake_impl.h:32] Adding Layer with type: N6nvblox15VoxelBlockLayerINS_10ColorVoxelEEE, voxel_size: 0.05, and memory_type: kDevice to LayerCake.
[nvblox_node-3] I0422 14:16:13.021297 2384308 block_memory_pool_impl.h:65] Expanding the memory pool with 2048 blocks. Number of allocated blocks: 2048
[nvblox_node-3] I0422 14:16:13.021667 2384308 gpu_hash_interface_impl.cuh:83] Creating a GPUHashImpl with requested capacity of 4096 blocks. Real capacity: 4096
[nvblox_node-3] I0422 14:16:13.023257 2384308 layer_cake_impl.h:32] Adding Layer with type: N6nvblox15VoxelBlockLayerINS_14FreespaceVoxelEEE, voxel_size: 0.05, and memory_type: kDevice to LayerCake.
[nvblox_node-3] I0422 14:16:13.025911 2384308 block_memory_pool_impl.h:65] Expanding the memory pool with 2048 blocks. Number of allocated blocks: 2048
[nvblox_node-3] I0422 14:16:13.026716 2384308 gpu_hash_interface_impl.cuh:83] Creating a GPUHashImpl with requested capacity of 4096 blocks. Real capacity: 4096
[nvblox_node-3] I0422 14:16:13.028412 2384308 layer_cake_impl.h:32] Adding Layer with type: N6nvblox15VoxelBlockLayerINS_14OccupancyVoxelEEE, voxel_size: 0.05, and memory_type: kDevice to LayerCake.
[nvblox_node-3] I0422 14:16:13.032121 2384308 block_memory_pool_impl.h:65] Expanding the memory pool with 2048 blocks. Number of allocated blocks: 2048
[nvblox_node-3] I0422 14:16:13.033180 2384308 gpu_hash_interface_impl.cuh:83] Creating a GPUHashImpl with requested capacity of 4096 blocks. Real capacity: 4096
[nvblox_node-3] I0422 14:16:13.033229 2384308 layer_cake_impl.h:32] Adding Layer with type: N6nvblox15VoxelBlockLayerINS_9EsdfVoxelEEE, voxel_size: 0.05, and memory_type: kDevice to LayerCake.
[nvblox_node-3] I0422 14:16:13.033443 2384308 block_memory_pool_impl.h:65] Expanding the memory pool with 2048 blocks. Number of allocated blocks: 2048
[nvblox_node-3] I0422 14:16:13.033597 2384308 gpu_hash_interface_impl.cuh:83] Creating a GPUHashImpl with requested capacity of 4096 blocks. Real capacity: 4096
[nvblox_node-3] I0422 14:16:13.033643 2384308 layer_cake_impl.h:32] Adding Layer with type: N6nvblox10BlockLayerINS_9MeshBlockEEE, voxel_size: 0.05, and memory_type: kDevice to LayerCake.
[nvblox_node-3] I0422 14:16:13.033651 2384308 layer_cake_streamer_impl.h:79] Adding Streamer with type: N6nvblox25LayerStreamerOldestBlocksINS_15VoxelBlockLayerINS_9TsdfVoxelEEEEE to LayerCake.
[nvblox_node-3] I0422 14:16:13.033655 2384308 layer_cake_streamer_impl.h:79] Adding Streamer with type: N6nvblox25LayerStreamerOldestBlocksINS_15VoxelBlockLayerINS_10ColorVoxelEEEEE to LayerCake.
[nvblox_node-3] I0422 14:16:13.033658 2384308 layer_cake_streamer_impl.h:79] Adding Streamer with type: N6nvblox25LayerStreamerOldestBlocksINS_15VoxelBlockLayerINS_14FreespaceVoxelEEEEE to LayerCake.
[nvblox_node-3] I0422 14:16:13.033661 2384308 layer_cake_streamer_impl.h:79] Adding Streamer with type: N6nvblox25LayerStreamerOldestBlocksINS_15VoxelBlockLayerINS_14OccupancyVoxelEEEEE to LayerCake.
[nvblox_node-3] I0422 14:16:13.033663 2384308 layer_cake_streamer_impl.h:79] Adding Streamer with type: N6nvblox25LayerStreamerOldestBlocksINS_15VoxelBlockLayerINS_9EsdfVoxelEEEEE to LayerCake.
[nvblox_node-3] I0422 14:16:13.033667 2384308 layer_cake_streamer_impl.h:79] Adding Streamer with type: N6nvblox25LayerStreamerOldestBlocksINS_10BlockLayerINS_9MeshBlockEEEEE to LayerCake.
[nvblox_node-3] I0422 14:16:13.037806 2384308 block_memory_pool_impl.h:65] Expanding the memory pool with 2048 blocks. Number of allocated blocks: 2048
[nvblox_node-3] I0422 14:16:13.038376 2384308 gpu_hash_interface_impl.cuh:83] Creating a GPUHashImpl with requested capacity of 4096 blocks. Real capacity: 4096
[nvblox_node-3] I0422 14:16:13.038414 2384308 layer_cake_impl.h:32] Adding Layer with type: N6nvblox15VoxelBlockLayerINS_9TsdfVoxelEEE, voxel_size: 0.05, and memory_type: kDevice to LayerCake.
[nvblox_node-3] I0422 14:16:13.042232 2384308 block_memory_pool_impl.h:65] Expanding the memory pool with 2048 blocks. Number of allocated blocks: 2048
[nvblox_node-3] I0422 14:16:13.043033 2384308 gpu_hash_interface_impl.cuh:83] Creating a GPUHashImpl with requested capacity of 4096 blocks. Real capacity: 4096
[nvblox_node-3] I0422 14:16:13.043066 2384308 layer_cake_impl.h:32] Adding Layer with type: N6nvblox15VoxelBlockLayerINS_10ColorVoxelEEE, voxel_size: 0.05, and memory_type: kDevice to LayerCake.
[nvblox_node-3] I0422 14:16:13.046828 2384308 block_memory_pool_impl.h:65] Expanding the memory pool with 2048 blocks. Number of allocated blocks: 2048
[nvblox_node-3] I0422 14:16:13.049669 2384308 gpu_hash_interface_impl.cuh:83] Creating a GPUHashImpl with requested capacity of 4096 blocks. Real capacity: 4096
[nvblox_node-3] I0422 14:16:13.049700 2384308 layer_cake_impl.h:32] Adding Layer with type: N6nvblox15VoxelBlockLayerINS_14FreespaceVoxelEEE, voxel_size: 0.05, and memory_type: kDevice to LayerCake.
[nvblox_node-3] I0422 14:16:13.052577 2384308 block_memory_pool_impl.h:65] Expanding the memory pool with 2048 blocks. Number of allocated blocks: 2048
[nvblox_node-3] I0422 14:16:13.052703 2384308 gpu_hash_interface_impl.cuh:83] Creating a GPUHashImpl with requested capacity of 4096 blocks. Real capacity: 4096
[nvblox_node-3] I0422 14:16:13.052729 2384308 layer_cake_impl.h:32] Adding Layer with type: N6nvblox15VoxelBlockLayerINS_14OccupancyVoxelEEE, voxel_size: 0.05, and memory_type: kDevice to LayerCake.
[nvblox_node-3] I0422 14:16:13.056617 2384308 block_memory_pool_impl.h:65] Expanding the memory pool with 2048 blocks. Number of allocated blocks: 2048
[nvblox_node-3] I0422 14:16:13.057292 2384308 gpu_hash_interface_impl.cuh:83] Creating a GPUHashImpl with requested capacity of 4096 blocks. Real capacity: 4096
[nvblox_node-3] I0422 14:16:13.057319 2384308 layer_cake_impl.h:32] Adding Layer with type: N6nvblox15VoxelBlockLayerINS_9EsdfVoxelEEE, voxel_size: 0.05, and memory_type: kDevice to LayerCake.
[nvblox_node-3] I0422 14:16:13.057463 2384308 block_memory_pool_impl.h:65] Expanding the memory pool with 2048 blocks. Number of allocated blocks: 2048
[nvblox_node-3] I0422 14:16:13.057547 2384308 gpu_hash_interface_impl.cuh:83] Creating a GPUHashImpl with requested capacity of 4096 blocks. Real capacity: 4096
[nvblox_node-3] I0422 14:16:13.057569 2384308 layer_cake_impl.h:32] Adding Layer with type: N6nvblox10BlockLayerINS_9MeshBlockEEE, voxel_size: 0.05, and memory_type: kDevice to LayerCake.
[nvblox_node-3] I0422 14:16:13.057572 2384308 layer_cake_streamer_impl.h:79] Adding Streamer with type: N6nvblox25LayerStreamerOldestBlocksINS_15VoxelBlockLayerINS_9TsdfVoxelEEEEE to LayerCake.
[nvblox_node-3] I0422 14:16:13.057574 2384308 layer_cake_streamer_impl.h:79] Adding Streamer with type: N6nvblox25LayerStreamerOldestBlocksINS_15VoxelBlockLayerINS_10ColorVoxelEEEEE to LayerCake.
[nvblox_node-3] I0422 14:16:13.057574 2384308 layer_cake_streamer_impl.h:79] Adding Streamer with type: N6nvblox25LayerStreamerOldestBlocksINS_15VoxelBlockLayerINS_14FreespaceVoxelEEEEE to LayerCake.
[nvblox_node-3] I0422 14:16:13.057577 2384308 layer_cake_streamer_impl.h:79] Adding Streamer with type: N6nvblox25LayerStreamerOldestBlocksINS_15VoxelBlockLayerINS_14OccupancyVoxelEEEEE to LayerCake.
[nvblox_node-3] I0422 14:16:13.057579 2384308 layer_cake_streamer_impl.h:79] Adding Streamer with type: N6nvblox25LayerStreamerOldestBlocksINS_15VoxelBlockLayerINS_9EsdfVoxelEEEEE to LayerCake.
[nvblox_node-3] I0422 14:16:13.057580 2384308 layer_cake_streamer_impl.h:79] Adding Streamer with type: N6nvblox25LayerStreamerOldestBlocksINS_10BlockLayerINS_9MeshBlockEEEEE to LayerCake.
[nvblox_node-3] [INFO] [1776881773.059478600] [nvblox_node]: Initialize Mapper:
[nvblox_node-3] [INFO] [1776881773.059511507] [nvblox_node]: static_mapper.do_depth_preprocessing: 0
[nvblox_node-3] [INFO] [1776881773.059518958] [nvblox_node]: static_mapper.depth_preprocessing_num_dilations: 4
[nvblox_node-3] [INFO] [1776881773.059526998] [nvblox_node]: static_mapper.esdf_slice_min_height: 0
[nvblox_node-3] [INFO] [1776881773.059530252] [nvblox_node]: static_mapper.esdf_slice_max_height: 1
[nvblox_node-3] [INFO] [1776881773.059533369] [nvblox_node]: static_mapper.esdf_slice_height: 1
[nvblox_node-3] [INFO] [1776881773.059536183] [nvblox_node]: static_mapper.exclude_last_view_from_decay: 0
[nvblox_node-3] [INFO] [1776881773.059539148] [nvblox_node]: static_mapper.projective_integrator_max_integration_distance_m: 7
[nvblox_node-3] [INFO] [1776881773.059543071] [nvblox_node]: static_mapper.lidar_projective_integrator_max_integration_distance_m: 10
[nvblox_node-3] [INFO] [1776881773.059546097] [nvblox_node]: static_mapper.projective_integrator_truncation_distance_vox: 4
[nvblox_node-3] [INFO] [1776881773.059551181] [nvblox_node]: static_mapper.projective_integrator_weighting_mode: kInverseSquareWeight
[nvblox_node-3] [WARN] [1776881773.059554993] [nvblox_node]: Requested weighting function: “kInverseSquareWeight” not recognized. Defaulting to: kInverseSquareWeight
[nvblox_node-3] [INFO] [1776881773.059558448] [nvblox_node]: static_mapper.projective_integrator_max_weight: 5
[nvblox_node-3] [INFO] [1776881773.059561578] [nvblox_node]: static_mapper.projective_tsdf_integrator_invalid_depth_decay_factor: -1
[nvblox_node-3] [INFO] [1776881773.059565117] [nvblox_node]: static_mapper.free_region_occupancy_probability: 0.3
[nvblox_node-3] [INFO] [1776881773.059568027] [nvblox_node]: static_mapper.occupied_region_occupancy_probability: 0.7
[nvblox_node-3] [INFO] [1776881773.059570955] [nvblox_node]: static_mapper.unobserved_region_occupancy_probability: 0.5
[nvblox_node-3] [INFO] [1776881773.059574008] [nvblox_node]: static_mapper.occupied_region_half_width_m: 0.1
[nvblox_node-3] [INFO] [1776881773.059576776] [nvblox_node]: static_mapper.raycast_subsampling_factor: 4
[nvblox_node-3] [INFO] [1776881773.059579637] [nvblox_node]: static_mapper.workspace_bounds_type: kUnbounded
[nvblox_node-3] [WARN] [1776881773.059583658] [nvblox_node]: Requested workspace bounds type: “kUnbounded” not recognized. Defaulting to: kUnbounded
[nvblox_node-3] [INFO] [1776881773.059587008] [nvblox_node]: static_mapper.workspace_bounds_min_height_m: 0
[nvblox_node-3] [INFO] [1776881773.059589854] [nvblox_node]: static_mapper.workspace_bounds_max_height_m: 1
[nvblox_node-3] [INFO] [1776881773.059592524] [nvblox_node]: static_mapper.workspace_bounds_min_corner_x_m: 0
[nvblox_node-3] [INFO] [1776881773.059595262] [nvblox_node]: static_mapper.workspace_bounds_max_corner_x_m: 0
[nvblox_node-3] [INFO] [1776881773.059597961] [nvblox_node]: static_mapper.workspace_bounds_min_corner_y_m: 2
[nvblox_node-3] [INFO] [1776881773.059600577] [nvblox_node]: static_mapper.workspace_bounds_max_corner_y_m: 2
[nvblox_node-3] [INFO] [1776881773.059603647] [nvblox_node]: static_mapper.esdf_integrator_min_weight: 0.0001
[nvblox_node-3] [INFO] [1776881773.059606359] [nvblox_node]: static_mapper.esdf_integrator_max_site_distance_vox: 1
[nvblox_node-3] [INFO] [1776881773.059609027] [nvblox_node]: static_mapper.esdf_integrator_max_distance_m: 2
[nvblox_node-3] [INFO] [1776881773.059611965] [nvblox_node]: static_mapper.mesh_integrator_min_weight: 0.0001
[nvblox_node-3] [INFO] [1776881773.059614547] [nvblox_node]: static_mapper.mesh_integrator_weld_vertices: 1
[nvblox_node-3] [INFO] [1776881773.059617089] [nvblox_node]: static_mapper.decay_integrator_deallocate_decayed_blocks: 1
[nvblox_node-3] [INFO] [1776881773.059620083] [nvblox_node]: static_mapper.tsdf_decay_factor: 0.95
[nvblox_node-3] [INFO] [1776881773.059623081] [nvblox_node]: static_mapper.tsdf_decayed_weight_threshold: 0.001
[nvblox_node-3] [INFO] [1776881773.059625741] [nvblox_node]: static_mapper.tsdf_set_free_distance_on_decayed: 0
[nvblox_node-3] [INFO] [1776881773.059628424] [nvblox_node]: static_mapper.tsdf_decayed_free_distance_vox: 4
[nvblox_node-3] [INFO] [1776881773.059631216] [nvblox_node]: static_mapper.free_region_decay_probability: 0.55
[nvblox_node-3] [INFO] [1776881773.059633948] [nvblox_node]: static_mapper.occupied_region_decay_probability: 0.4
[nvblox_node-3] [INFO] [1776881773.059636457] [nvblox_node]: static_mapper.occupancy_decay_to_free: 0
[nvblox_node-3] [INFO] [1776881773.059639180] [nvblox_node]: static_mapper.max_tsdf_distance_for_occupancy_m: 0.15
[nvblox_node-3] [INFO] [1776881773.059645138] [nvblox_node]: static_mapper.max_unobserved_to_keep_consecutive_occupancy_ms: 200
[nvblox_node-3] [INFO] [1776881773.059671330] [nvblox_node]: static_mapper.min_duration_since_occupied_for_freespace_ms: 1000
[nvblox_node-3] [INFO] [1776881773.059674250] [nvblox_node]: static_mapper.min_consecutive_occupancy_duration_for_reset_ms: 2000
[nvblox_node-3] [INFO] [1776881773.059676807] [nvblox_node]: static_mapper.check_neighborhood: 1
[nvblox_node-3] [INFO] [1776881773.059679375] [nvblox_node]: Initialize Mapper:
[nvblox_node-3] [INFO] [1776881773.059682284] [nvblox_node]: dynamic_mapper.do_depth_preprocessing: 0
[nvblox_node-3] [INFO] [1776881773.059684992] [nvblox_node]: dynamic_mapper.depth_preprocessing_num_dilations: 4
[nvblox_node-3] [INFO] [1776881773.059687762] [nvblox_node]: dynamic_mapper.esdf_slice_min_height: 0
[nvblox_node-3] [INFO] [1776881773.059690355] [nvblox_node]: dynamic_mapper.esdf_slice_max_height: 1
[nvblox_node-3] [INFO] [1776881773.059693055] [nvblox_node]: dynamic_mapper.esdf_slice_height: 1
[nvblox_node-3] [INFO] [1776881773.059695564] [nvblox_node]: dynamic_mapper.exclude_last_view_from_decay: 0
[nvblox_node-3] [INFO] [1776881773.059698169] [nvblox_node]: dynamic_mapper.projective_integrator_max_integration_distance_m: 7
[nvblox_node-3] [INFO] [1776881773.059701069] [nvblox_node]: dynamic_mapper.lidar_projective_integrator_max_integration_distance_m: 10
[nvblox_node-3] [INFO] [1776881773.059703926] [nvblox_node]: dynamic_mapper.projective_integrator_truncation_distance_vox: 4
[nvblox_node-3] [INFO] [1776881773.059706525] [nvblox_node]: dynamic_mapper.projective_integrator_weighting_mode: kInverseSquareWeight
[nvblox_node-3] [WARN] [1776881773.059710030] [nvblox_node]: Requested weighting function: “kInverseSquareWeight” not recognized. Defaulting to: kInverseSquareWeight
[nvblox_node-3] [INFO] [1776881773.059713005] [nvblox_node]: dynamic_mapper.projective_integrator_max_weight: 5
[nvblox_node-3] [INFO] [1776881773.059721384] [nvblox_node]: dynamic_mapper.projective_tsdf_integrator_invalid_depth_decay_factor: -1
[nvblox_node-3] [INFO] [1776881773.059724878] [nvblox_node]: dynamic_mapper.free_region_occupancy_probability: 0.3
[nvblox_node-3] [INFO] [1776881773.059727510] [nvblox_node]: dynamic_mapper.occupied_region_occupancy_probability: 0.7
[nvblox_node-3] [INFO] [1776881773.059730182] [nvblox_node]: dynamic_mapper.unobserved_region_occupancy_probability: 0.5
[nvblox_node-3] [INFO] [1776881773.059732932] [nvblox_node]: dynamic_mapper.occupied_region_half_width_m: 0.1
[nvblox_node-3] [INFO] [1776881773.059735474] [nvblox_node]: dynamic_mapper.raycast_subsampling_factor: 4
[nvblox_node-3] [INFO] [1776881773.059738148] [nvblox_node]: dynamic_mapper.workspace_bounds_type: kUnbounded
[nvblox_node-3] [WARN] [1776881773.059740692] [nvblox_node]: Requested workspace bounds type: “kUnbounded” not recognized. Defaulting to: kUnbounded
[nvblox_node-3] [INFO] [1776881773.059743601] [nvblox_node]: dynamic_mapper.workspace_bounds_min_height_m: 0
[nvblox_node-3] [INFO] [1776881773.059746288] [nvblox_node]: dynamic_mapper.workspace_bounds_max_height_m: 1
[nvblox_node-3] [INFO] [1776881773.059748973] [nvblox_node]: dynamic_mapper.workspace_bounds_min_corner_x_m: 0
[nvblox_node-3] [INFO] [1776881773.059751580] [nvblox_node]: dynamic_mapper.workspace_bounds_max_corner_x_m: 0
[nvblox_node-3] [INFO] [1776881773.059754211] [nvblox_node]: dynamic_mapper.workspace_bounds_min_corner_y_m: 2
[nvblox_node-3] [INFO] [1776881773.059756793] [nvblox_node]: dynamic_mapper.workspace_bounds_max_corner_y_m: 2
[nvblox_node-3] [INFO] [1776881773.059759685] [nvblox_node]: dynamic_mapper.esdf_integrator_min_weight: 0.0001
[nvblox_node-3] [INFO] [1776881773.059762419] [nvblox_node]: dynamic_mapper.esdf_integrator_max_site_distance_vox: 1
[nvblox_node-3] [INFO] [1776881773.059765034] [nvblox_node]: dynamic_mapper.esdf_integrator_max_distance_m: 2
[nvblox_node-3] [INFO] [1776881773.059768436] [nvblox_node]: dynamic_mapper.mesh_integrator_min_weight: 0.0001
[nvblox_node-3] [INFO] [1776881773.059770979] [nvblox_node]: dynamic_mapper.mesh_integrator_weld_vertices: 1
[nvblox_node-3] [INFO] [1776881773.059773767] [nvblox_node]: dynamic_mapper.decay_integrator_deallocate_decayed_blocks: 1
[nvblox_node-3] [INFO] [1776881773.059776518] [nvblox_node]: dynamic_mapper.tsdf_decay_factor: 0.95
[nvblox_node-3] [INFO] [1776881773.059779288] [nvblox_node]: dynamic_mapper.tsdf_decayed_weight_threshold: 0.001
[nvblox_node-3] [INFO] [1776881773.059781825] [nvblox_node]: dynamic_mapper.tsdf_set_free_distance_on_decayed: 0
[nvblox_node-3] [INFO] [1776881773.059784407] [nvblox_node]: dynamic_mapper.tsdf_decayed_free_distance_vox: 4
[nvblox_node-3] [INFO] [1776881773.059787064] [nvblox_node]: dynamic_mapper.free_region_decay_probability: 0.55
[nvblox_node-3] [INFO] [1776881773.059794366] [nvblox_node]: dynamic_mapper.occupied_region_decay_probability: 0.4
[nvblox_node-3] [INFO] [1776881773.059796953] [nvblox_node]: dynamic_mapper.occupancy_decay_to_free: 0
[nvblox_node-3] [INFO] [1776881773.059799752] [nvblox_node]: dynamic_mapper.max_tsdf_distance_for_occupancy_m: 0.15
[nvblox_node-3] [INFO] [1776881773.059802300] [nvblox_node]: dynamic_mapper.max_unobserved_to_keep_consecutive_occupancy_ms: 200
[nvblox_node-3] [INFO] [1776881773.059804912] [nvblox_node]: dynamic_mapper.min_duration_since_occupied_for_freespace_ms: 1000
[nvblox_node-3] [INFO] [1776881773.059807429] [nvblox_node]: dynamic_mapper.min_consecutive_occupancy_duration_for_reset_ms: 2000
[nvblox_node-3] [INFO] [1776881773.059810113] [nvblox_node]: dynamic_mapper.check_neighborhood: 1
[nvblox_node-3] [INFO] [1776881773.059813314] [nvblox_node]: Initialize MultiMapper:
[nvblox_node-3] [INFO] [1776881773.059816325] [nvblox_node]: multi_mapper.connected_mask_component_size_threshold: 2000
[nvblox_node-3] [INFO] [1776881773.059819165] [nvblox_node]: multi_mapper.remove_small_connected_components: 1
[nvblox_node-3] [INFO] [1776881773.059866319] [nvblox_node]: NvbloxNode::subscribeToTopics()
[nvblox_node-3] [INFO] [1776881773.059949578] [nvblox_node]: Subscribing input topics with QoS: SYSTEM_DEFAULT
[nvblox_node-3] [INFO] [1776881773.061206263] [nvblox_node]: NvbloxNode::setupTimers()
[nvblox_node-3] [INFO] [1776881773.061244145] [nvblox_node]: NvbloxNode::advertiseTopics()
[nvblox_node-3] [INFO] [1776881773.064040455] [nvblox_node]: NvbloxNode::advertiseServices()
[nvblox_node-3] [INFO] [1776881773.067005865] [nvblox_node]: Started up nvblox node in frame world and voxel size 0.05
[nvblox_node-3] [INFO] [1776881773.067034539] [nvblox_node]: Mapping type: kStaticTsdf
[nvblox_node-3] [INFO] [1776881773.067678478] [nvblox_node]: nvblox parameters:
[nvblox_node-3] nvblox_node
[nvblox_node-3] cuda_stream_type: kBlocking
[nvblox_node-3] global_frame: world
[nvblox_node-3] voxel_size: 0.050000
[nvblox_node-3] max_back_projection_distance: 10.000000
[nvblox_node-3] layer_visualization_min_tsdf_weight: 0.100000
[nvblox_node-3] layer_visualization_exclusion_height_m: 2.000000
[nvblox_node-3] layer_visualization_exclusion_radius_m: 5.000000
[nvblox_node-3] layer_streamer_bandwidth_limit_mbps: 30.000000
[nvblox_node-3] distance_map_unknown_value_optimistic: 1000.000000
[nvblox_node-3] distance_map_unknown_value_pessimistic: -1000.000000
[nvblox_node-3] esdf_mode: 3d
[nvblox_node-3] mapping_type: static_tsdf
[nvblox_node-3] pose_frame: base_link
[nvblox_node-3] map_clearing_frame_id: base_link
[nvblox_node-3] after_shutdown_map_save_path:
[nvblox_node-3] esdf_slice_bounds_visualization_attachment_frame_id: base_link
[nvblox_node-3] workspace_height_bounds_visualization_attachment_frame_id: base_link
[nvblox_node-3] publish_esdf_distance_slice: 1
[nvblox_node-3] use_color: 0
[nvblox_node-3] use_depth: 0
[nvblox_node-3] use_segmentation: 0
[nvblox_node-3] use_lidar: 1
[nvblox_node-3] use_non_equal_vertical_fov_lidar_params: 0
[nvblox_node-3] print_timings_to_console: 0
[nvblox_node-3] print_rates_to_console: 0
[nvblox_node-3] print_queue_drops_to_console: 0
[nvblox_node-3] print_delays_to_console: 0
[nvblox_node-3] layer_visualization_undo_gamma_correction: 0
[nvblox_node-3] output_pessimistic_distance_map: 1
[nvblox_node-3] num_cameras: 1
[nvblox_node-3] lidar_width: 192
[nvblox_node-3] lidar_height: 70
[nvblox_node-3] tick_period_ms: 10
[nvblox_node-3] print_statistics_on_console_period_ms: 10000
[nvblox_node-3] maximum_input_queue_length: 10
[nvblox_node-3] back_projection_subsampling: 1
[nvblox_node-3] lidar_vertical_fov_rad: 1.570800
[nvblox_node-3] lidar_min_valid_range_m: 0.050000
[nvblox_node-3] lidar_max_valid_range_m: 10.000000
[nvblox_node-3] min_angle_below_zero_elevation_rad: 0.349066
[nvblox_node-3] max_angle_above_zero_elevation_rad: 0.261799
[nvblox_node-3] esdf_slice_bounds_visualization_side_length: 10.000000
[nvblox_node-3] workspace_height_bounds_visualization_side_length: 10.000000
[nvblox_node-3] integrate_depth_rate_hz: 40.000000
[nvblox_node-3] integrate_color_rate_hz: 5.000000
[nvblox_node-3] integrate_lidar_rate_hz: 20.000000
[nvblox_node-3] update_mesh_rate_hz: 2.000000
[nvblox_node-3] update_esdf_rate_hz: 5.000000
[nvblox_node-3] publish_layer_rate_hz: 10.000000
[nvblox_node-3] publish_debug_vis_rate_hz: 2.000000
[nvblox_node-3] decay_tsdf_rate_hz: 0.000000
[nvblox_node-3] decay_dynamic_occupancy_rate_hz: 10.000000
[nvblox_node-3] clear_map_outside_radius_rate_hz: 1.000000
[nvblox_node-3] map_clearing_radius_m: -1.000000
[nvblox_node-3] esdf_and_gradients_unobserved_value: -1000.000000
[nvblox_node-3] multi_mapper
[nvblox_node-3] connected_mask_component_size_threshold: 2000
[nvblox_node-3] background_mapper
[nvblox_node-3] voxel_size_m: 0.050000
[nvblox_node-3] memory_type: kDevice
[nvblox_node-3] projective_layer_type: kTsdf
[nvblox_node-3] esdf_mode: kUnset
[nvblox_node-3] do_depth_preprocessing: 0
[nvblox_node-3] depth_preprocessing_num_dilations: 4
[nvblox_node-3] exclude_last_view_from_decay: 0
[nvblox_node-3] camera_tsdf_integrator
[nvblox_node-3] max_weight:: 5.000000
[nvblox_node-3] marked_unobserved_voxels_distance_m:: -1.000000
[nvblox_node-3] marked_unobserved_voxels_weight:: 0.100000
[nvblox_node-3] weighting_function_type:: kInverseSquareWeight
[nvblox_node-3] invalid_depth_decay_factor:: -1.000000
[nvblox_node-3] projective_integrator
[nvblox_node-3] lidar_linear_interpolation_max_allowable_difference_vox:: 2.000000
[nvblox_node-3] lidar_nearest_interpolation_max_allowable_dist_to_ray_vox:: 0.500000
[nvblox_node-3] truncation_distance_vox:: 4.000000
[nvblox_node-3] max_integration_distance_m:: 7.000000
[nvblox_node-3] view_calculator
[nvblox_node-3] raycast_subsampling_factor: 4
[nvblox_node-3] workspace_bounds_type: kUnbounded
[nvblox_node-3] workspace_bounds_min_height_m: 0.000000
[nvblox_node-3] workspace_bounds_max_height_m: 1.000000
[nvblox_node-3] workspace_bounds_min_corner_x_m: 0.000000
[nvblox_node-3] workspace_bounds_max_corner_x_m: 0.000000
[nvblox_node-3] workspace_bounds_min_corner_y_m: 2.000000
[nvblox_node-3] workspace_bounds_max_corner_y_m: 2.000000
[nvblox_node-3] lidar_tsdf_integrator
[nvblox_node-3] max_integration_distance_m:: 10.000000
[nvblox_node-3] projective_color_integrator
[nvblox_node-3] sphere_tracing_ray_subsampling_factor:: 4
[nvblox_node-3] camera_occupancy_integrator
[nvblox_node-3] free_region_log_odds:: -0.847298
[nvblox_node-3] occupied_region_log_odds:: 0.847298
[nvblox_node-3] unobserved_region_log_odds:: 0.000000
[nvblox_node-3] occupied_region_half_width_m:: 0.100000
[nvblox_node-3] lidar_occupancy_integrator
[nvblox_node-3] esdf_integrator
[nvblox_node-3] max_esdf_distance_m:: 2.000000
[nvblox_node-3] max_tsdf_site_distance_vox:: 1.000000
[nvblox_node-3] tsdf_min_weight:: 0.000100
[nvblox_node-3] occupied_threshold_log_odds:: 0.000000
[nvblox_node-3] esdf_slice_min_height:: 0.000000
[nvblox_node-3] esdf_slice_max_height:: 1.000000
[nvblox_node-3] esdf_slice_height:: 1.000000
[nvblox_node-3] slice_height_above_plane_m:: 0.000000
[nvblox_node-3] slice_height_thickness_m:: 0.100000
[nvblox_node-3] mesh_integrator
[nvblox_node-3] min_weight:: 0.000100
[nvblox_node-3] cutoff_distance_vox:: 5.000000
[nvblox_node-3] weld_vertices:: 1
[nvblox_node-3] occupancy_decay_integrator
[nvblox_node-3] free_space_decay_log_odds:: 0.200671
[nvblox_node-3] occupied_space_decay_log_odds:: -0.405465
[nvblox_node-3] decay_to_log_odds_:: 0.000000
[nvblox_node-3] decay_integrator
[nvblox_node-3] deallocate_decayed_blocks:: 1
[nvblox_node-3] tsdf_decay_integrator
[nvblox_node-3] decay_factor:: 0.950000
[nvblox_node-3] decayed_weight_theshold:: 0.001000
[nvblox_node-3] set_free_distance_on_decayed:: 0
[nvblox_node-3] free_distance_vox:: 4.000000
[nvblox_node-3] freespace_integrator
[nvblox_node-3] max_tsdf_distance_for_occupancy_m:: 0.150000
[nvblox_node-3] max_unobserved_to_keep_consecutive_occupancy_ms:: 200
[nvblox_node-3] min_duration_since_occupied_for_freespace_ms:: 1000
[nvblox_node-3] min_consecutive_occupancy_duration_for_reset_ms:: 2000
[nvblox_node-3] check_neighborhood:: 1
[nvblox_node-3] foreground_mapper
[nvblox_node-3] projective_layer_type: kNone
[nvblox_node-3] image_masker
[nvblox_node-3] occlusion_threshold_m:: 0.250000
[nvblox_node-3] ground_plane_estimator
[nvblox_node-3] ground_points_candidates_min_z_m:: -0.100000
[nvblox_node-3] ground_points_candidates_max_z_m:: 0.150000
[nvblox_node-3] ransac_plane_fitter
[nvblox_node-3] num_ransac_iterations:: 1000
[nvblox_node-3] ransac_distance_threshold_m:: 0.200000
[nvblox_node-3] tsdf_zero_crossings_extractor
[nvblox_node-3] min_tsdf_weight:: 0.100000
[nvblox_node-3] max_crossings:: 360000
[nvblox_node-3]
[nvblox_node-3] [INFO] [1776881895.043378349] [nvblox_node]: Got a new subscriber, sending entire map.
^C[WARNING] [launch]: user interrupted with ctrl-c (SIGINT)
[robot_state_publisher-2] [INFO] [1776882886.450617953] [rclcpp]: signal_handler(SIGINT/SIGTERM)
[nvblox_node-3] [INFO] [1776882886.450617822] [rclcpp]: signal_handler(SIGINT/SIGTERM)
[static_transform_publisher-1] [INFO] [1776882886.450644583] [rclcpp]: signal_handler(SIGINT/SIGTERM)
[nvblox_node-3] [INFO] [1776882886.452012452] [nvblox_node]: Timing statistics:
[nvblox_node-3]
[nvblox_node-3] NVBlox Timings (in seconds)
[nvblox_node-3] namespace/tag - NumSamples - TotalTime - (Mean ± StdDev) - [Min,Max]
[nvblox_node-3] -----------
[nvblox_node-3] esdf/integrate 5339 08.584118 (00.001608 ± 00.000000) [00.000000,00.022860]
[nvblox_node-3] esdf/integrate/allocate 1548 00.003088 (00.000002 ± 00.000000) [00.000001,00.000013]
[nvblox_node-3] esdf/integrate/clear 1548 02.464191 (00.001592 ± 00.001834) [00.000030,00.007416]
[nvblox_node-3] esdf/integrate/clear/get_blocks 1548 00.009845 (00.000006 ± 00.000005) [00.000003,00.000036]
[nvblox_node-3] esdf/integrate/compute 1548 03.981972 (00.002572 ± 00.003193) [00.000047,00.015792]
[nvblox_node-3] esdf/integrate/compute/neighbor_bands 1821 02.646035 (00.001453 ± 00.002121) [00.000029,00.006167]
[nvblox_node-3] esdf/integrate/compute/neighbor_bands/gpu_view 1821 01.356458 (00.000745 ± 00.001103) [00.000007,00.003669]
[nvblox_node-3] esdf/integrate/compute/swap 1821 00.000480 (00.000000 ± 00.000000) [00.000000,00.000002]
[nvblox_node-3] esdf/integrate/compute/sweep 1821 01.323866 (00.000727 ± 00.001089) [00.000001,00.003256]
[nvblox_node-3] esdf/integrate/mark_sites 1548 02.129004 (00.001375 ± 00.001389) [00.000033,00.009462]
[nvblox_node-3] esdf/integrate/mark_sites/pack_out 1548 01.193341 (00.000771 ± 00.000846) [00.000010,00.004459]
[nvblox_node-3] gpu_hash/flush_insertion_cache 2 00.003007 (00.001504 ± 00.001424) [00.000079,00.002928]
[nvblox_node-3] gpu_hash/transfer/reset 12 00.017509 (00.001459 ± 00.001750) [00.000099,00.006519]
[nvblox_node-3] mesh/gpu/get_meshable 150 00.059528 (00.000397 ± 00.000638) [00.000014,00.004303]
[nvblox_node-3] mesh/gpu/integrate 154 00.303217 (00.001969 ± 00.003074) [00.000001,00.011588]
[nvblox_node-3] mesh/gpu/mesh_blocks 150 00.243250 (00.001622 ± 00.002935) [00.000077,00.009522]
[nvblox_node-3] mesh/gpu/mesh_blocks/block_allocation 150 00.000482 (00.000003 ± 00.000002) [00.000002,00.000016]
[nvblox_node-3] mesh/gpu/mesh_blocks/copy_out 150 00.000820 (00.000005 ± 00.000002) [00.000004,00.000017]
[nvblox_node-3] mesh/gpu/mesh_blocks/kernel_table 150 00.106946 (00.000713 ± 00.001481) [00.000007,00.005354]
[nvblox_node-3] mesh/gpu/mesh_blocks/kernel_vertices 150 00.063941 (00.000426 ± 00.000740) [00.000009,00.002451]
[nvblox_node-3] mesh/gpu/mesh_blocks/prep 150 00.002235 (00.000015 ± 00.000002) [00.000011,00.000050]
[nvblox_node-3] mesh/gpu/mesh_blocks/welding 150 00.068401 (00.000456 ± 00.000805) [00.000039,00.003579]
[nvblox_node-3] ros/esdf 5339 09.141987 (00.001712 ± 00.000036) [00.000020,00.022921]
[nvblox_node-3] ros/esdf/integrate 5339 09.128788 (00.001710 ± 00.000035) [00.000019,00.022921]
[nvblox_node-3] ros/idle 95854 877.051305 (00.009150 ± 00.000122) [00.000031,00.012179]
[nvblox_node-3] ros/lidar 4800 218.962184 (00.045617 ± 00.003174) [00.031650,00.071097]
[nvblox_node-3] ros/lidar/conversion 4800 211.230742 (00.044006 ± 00.002559) [00.031540,00.065529]
[nvblox_node-3] ros/lidar/integration 4800 07.672175 (00.001598 ± 00.001909) [00.000090,00.009952]
[nvblox_node-3] ros/lidar/transform 4800 00.019757 (00.000004 ± 00.000002) [00.000002,00.000035]
[nvblox_node-3] ros/pointcloud_callback 4801 00.052147 (00.000011 ± 00.000007) [00.000004,00.000094]
[nvblox_node-3] ros/process_queue 287565 223.508415 (00.000777 ± 00.000027) [00.000000,00.071123]
[nvblox_node-3] ros/publish_layer 9998 01.737506 (00.000174 ± 00.000046) [00.000016,00.019363]
[nvblox_node-3] ros/publish_layer/serialize 9998 01.199174 (00.000120 ± 00.000043) [00.000010,00.007231]
[nvblox_node-3] ros/publish_layers 9998 01.987831 (00.000199 ± 00.000050) [00.000023,00.019388]
[nvblox_node-3] ros/publish_mesh_layer 154 00.033832 (00.000220 ± 00.000198) [00.000003,00.001988]
[nvblox_node-3] ros/publish_tsdf_layer 276 00.024769 (00.000090 ± 00.000018) [00.000052,00.001362]
[nvblox_node-3] ros/push_onto_queue 4801 00.006478 (00.000001 ± 00.000000) [00.000000,00.000043]
[nvblox_node-3] ros/tick 95855 235.920945 (00.002461 ± 00.000076) [00.000001,00.080075]
[nvblox_node-3] tsdf/integrate 4800 07.177914 (00.001495 ± 00.001869) [00.000030,00.009858]
[nvblox_node-3] tsdf/integrate/allocate_blocks 4800 02.957968 (00.000616 ± 00.000829) [00.000002,00.005430]
[nvblox_node-3] tsdf/integrate/get_blocks_in_view 4800 00.016392 (00.000003 ± 00.000002) [00.000002,00.000658]
[nvblox_node-3] tsdf/integrate/transfer_blocks 4800 02.263479 (00.000472 ± 00.000710) [00.000012,00.004871]
[nvblox_node-3] tsdf/integrate/update_blocks 4800 01.925599 (00.000401 ± 00.000790) [00.000010,00.005147]
[nvblox_node-3] view_calculator/raycast 4800 00.008692 (00.000002 ± 00.000000) [00.000001,00.000656]
[nvblox_node-3] view_calculator/raycast/output 1 00.000343 (00.000343 ± 00.000000) [00.000343,00.000343]
[nvblox_node-3] view_calculator/raycast/raycast_pixels_kernel 1 00.000283 (00.000283 ± 00.000000) [00.000283,00.000283]
[nvblox_node-3] view_calculator/raycast/setup 1 00.000027 (00.000027 ± 00.000000) [00.000027,00.000027]
[nvblox_node-3]
[nvblox_node-3] [INFO] [1776882886.452035749] [nvblox_node]: Rates statistics:
[nvblox_node-3]
[nvblox_node-3] NVBlox Rates (in Hz)
[nvblox_node-3] namespace/tag - NumSamples (Window Length) - Mean
[nvblox_node-3] layer_streamer/mesh 100 7.7
[nvblox_node-3] layer_streamer/tsdf 100 7.8
[nvblox_node-3] ros/lidar 100 14.2
[nvblox_node-3] ros/pointcloud_callback 100 14.2
[nvblox_node-3] ros/update_esdf 100 4.9
[nvblox_node-3] ros/tick 100 101.0
[nvblox_node-3]
[nvblox_node-3] [INFO] [1776882886.452046522] [nvblox_node]: Delay statistics:
[nvblox_node-3]
[nvblox_node-3] NVBlox Delays
[nvblox_node-3] namespace/tag - NumSamples (Window Length) - Mean Delay (seconds)
[nvblox_node-3] ros/esdf_integration 100 743.239
[nvblox_node-3] ros/pointcloud_integration 100 0.114
[nvblox_node-3] ros/pointcloud_callback 100 0.023
[nvblox_node-3]
[INFO] [static_transform_publisher-1]: process has finished cleanly [pid 2384304]
[INFO] [robot_state_publisher-2]: process has finished cleanly [pid 2384306]
[INFO] [nvblox_node-3]: process has finished cleanly [pid 2384308]
Regarding these issues, I would appreciate any advice on how to properly reconstruct the object and resolve the RViz crash I am experiencing. I suspect my parameters or system setup might need adjustments. Since I am a student and still new to the field of robotics, any guidance, tips, or suggestions would be greatly appreciated. Thanks!
Hello @fayalasarria,
Welcome to the Isaac ROS forum and thanks for the post!
The RViz crash you encountered is a known issue. Recent ROS 2 RViz updates removed the GLSL 1.5 shader files (including rviz/glsl150/box.geom) that the Isaac ROS nvblox RViz plugin expects. When RViz tries to render nvblox’s cube-based visualization (mesh / occupancy), it looks for that shader, fails, and aborts.
The workaround is export ISAAC_ROS_NVBLOX_PLUGIN_FORCE_FALLBACK_MATERIAL=1 before you launch the nvblox. This forces the nvblox RViz plugin to use a fallback material that renders points instead of cubes, which does not require the removed GLSL 1.5 shaders, avoiding the crash.
The permanent fix is only included in NVBlox release 4.1.
Thank you very much for the response and for the detailed explanation regarding the shader issue in RViz.
The workaround you provided worked perfectly and resolved the crash. However, I have also updated to version 4.2 to ensure I have the permanent fix and the latest improvements.
I appreciate the help in identifying the root cause. Best regards!
Thanks for following up and sharing your test results!
Glad to hear it’s working now. We’ll close this topic for now.
If you have any further questions or run into new issues, feel free to open a new thread.
