Nvblox_examples_bringup isnt working
Im using on a Jetson Orin Nx and a Zed2i camera
I used
git clone -b release-3.1 https://github.com/NVIDIA-ISAAC-ROS/isaac_ros_common.git isaac_ros_common
When i run the NVBlox Zed example from Nvidia Github Wiki nothing works in rviz.
Launch command
ros2 launch nvblox_examples_bringup zed_example.launch.py camera:=zed2
The rviz can see the topics and i can select them but nothing shows. It wont even show a camera. when i list the topics in a terminal, I see the zed and nvblox topics are there.
is my problem that i have Zed2i?
To test things out i also ran the Visual Slam
When i run isaac_ros_visual_slam things work mostly fine.
I do get these messages. but not important
[visual_slam_node]: Delta between current and previous frame [399.927000 ms] is above threshold [34.000000 ms]
[rviz]: Message Filter dropping message: frame ‘odom’ at time 1729037777.728 for reason ‘discarding message because the queue is full’
Hi @smokemonkey101
Thanks for your post.
From the attached log, it seems that rebuilt zed library is not loaded. Could you source the setup.bash and try the demo again?
cd ${ISAAC_ROS_WS}/ && source install/setup.bash
Let me know.
Best,
Ahung
The believe workspace was sourced.
To make sure the zed was running,
i first opened another terminal and entered the docker then listed the topics. Zed and nvblox where listed.
Second i ran the Visual slam right after. And it was working. Mostly
Thank you for the reply
I decided to rebuild the workspace, but now im unable to rebuild the zed-ros2-wrapper.
cmake would result in
Failed <<< zed_components [51.7s, exited with code 2]
i found this thread
ros2-wrapper with branch foxy-humble-4.0.5 requires a cmake_minimum_version of 3.5 and policy is not set. On the other hand, Isaac ROS Visual SLAM requires a minimum version of 3.22.1
Im still trying to fix
Hi @smokemonkey101
I sync’d zed-ros2-wrapper to top of tree and observed cmake build failed below.
It’s caused by recent merged commits. Please checkout to earlier tag like humble-v4.1.4 to avoid the issue.
Starting >>> zed_components
--- stderr: zed_components
/workspaces/isaac_ros-dev/src/zed-ros2-wrapper/zed_components/src/zed_camera/src/zed_camera_component.cpp: In member function ‘void stereolabs::ZedCamera::getOdParams()’:
/workspaces/isaac_ros-dev/src/zed-ros2-wrapper/zed_components/src/zed_camera/src/zed_camera_component.cpp:1656:51: error: ‘CUSTOM_YOLOLIKE_BOX_OBJECTS’ is not a member of ‘sl::OBJECT_DETECTION_MODE
L’; did you mean ‘CUSTOM_BOX_OBJECTS’?
 1656 |   if (mObjDetModel == sl::OBJECT_DETECTION_MODEL::CUSTOM_YOLOLIKE_BOX_OBJECTS) {
      |                                                   CUSTOM_BOX_OBJECTS
/workspaces/isaac_ros-dev/src/zed-ros2-wrapper/zed_components/src/zed_camera/src/zed_camera_component.cpp:1698:51: error: ‘CUSTOM_YOLOLIKE_BOX_OBJECTS’ is not a member of ‘sl::OBJECT_DETECTION_MODE
 1698 |   if (mObjDetModel != sl::OBJECT_DETECTION_MODEL::CUSTOM_YOLOLIKE_BOX_OBJECTS) {
      |                                                   CUSTOM_BOX_OBJECTS
Ok it took me a little while but i rebuild everything from the source and still experience the same problem.
i built from source
release-3.1 isaac_ros_common, isaac_ros_visual_slam, and isaac_ros_nvblox
zed-ros2-wrapper tag humble-v4.1.4
I start the nvblox example with the Zed and i get the same 3 lines repeating.
On the left of the screenshot you can see i ran a topic list. The zed and nvblox nodes are present.
Here is the launch command. same as the example.
camera:=zed2
[component_container_mt-1] [INFO] [1729886419.483382711] [nvblox_node]: Lookup transform failed for frame zed_camera_link. Layer pointclouds not published
[component_container_mt-1] [INFO] [1729886420.003754171] [nvblox_node]: Tried to clear map outside of radius but couldn't look up frame: zed_camera_link
[component_container_mt-1] [INFO] [1729886420.353818695] [nvblox_node]: Lookup transform failed for frame zed_camera_link. Mesh not published
i then change nothing and run the isaac_ros_visual_slam example and it works. Here is the launch command.
ros2 launch isaac_ros_examples isaac_ros_examples.launch.py
launch_fragments:=zed_stereo_rect,visual_slam
base_frame:=zed2_camera_center camera_optical_frames:=“[‘zed2_left_camera_optical_frame’, ‘zed2_right_camera_optical_frame’]”
interface_specs_file:=${ISAAC_ROS_WS}/isaac_ros_assets/isaac_ros_visual_slam/zed2_quickstart_interface_specs.json
to be honest im trying to do something like the Isaac Perceptor Technical Details — isaac_ros_docs documentation
but i only have the 1 zed camera - Zed2i
im trying to get localization and navigation.
So I need to combine Nvblox and isaac_ros_visual_slam but i cant seem to get Nvblox to run.
I tried both the build from source and the Binary package.
I even deleted the the dockers and rebuilt them.
Hi @smokemonkey101
I don’t have zed2i but zed. I observe the same logs of lookup trasform failed & clear map. It somehow takes over10mins for zed to start streaming in nvblox demo. Please help confirm if you observe the same.
Yes. After proximity 12 mins it started working.
Also after about 9 mins of it working the tf axes started to fly away. Lol
Ok so i got my hands on an jetson AGX and repeated the setup.
I can use the isaac_ros_visual_slam no problem. Then tried to use Nvblox, It take a while before it starts working.
i tried the zed-ros2-wrapper master first but had to move to
isaac_ros_nvblox
sorry i accidentally change users
Hi @smokemonkey101
Thank you for update. I forward this issue to engineers.
is there any progress on updating the isaac_ros-dev docker container to work with the main branch of the zed_ros-wrapper?
I have discovered some new interesting behavior.
1st - launch the Nvblox and wait the 10 odd minutes
2nd - stop the process while keeping the docker active
3rd - launch the Nvblox again.
With the second launch, I no longer had to wait the 10 min. It started immediately.
My new major problem is that my Tf info will not update .
When i move the device, it doesn’t see its own movement
[component_container_mt-1] [INFO] [1730849769.994574827] [nvblox_node]: Rates statistics:
[component_container_mt-1] NVBlox Rates (in Hz)
[component_container_mt-1] namespace/tag - NumSamples (Window Length) - Mean
[component_container_mt-1] -----------
[component_container_mt-1] ros/mesh                	100    	2.4
[component_container_mt-1] ros/color               	100    	3.3
[component_container_mt-1] ros/depth               	100    	4.8
[component_container_mt-1] ros/depth_image_callback	100    	4.8
[component_container_mt-1] ros/color_image_callback	100    	4.8
[component_container_mt-1] ros/update_esdf         	100    	2.4
[component_container_mt-1] mapper/stream_mesh      	100    	2.4
[component_container_mt-1] ros/tick                	100    	2.4
[component_container_mt-1] [INFO] [1730849769.994636557] [nvblox_node]: Delay statistics:
[component_container_mt-1] NVBlox Delays
[component_container_mt-1] namespace/tag - NumSamples (Window Length) - Mean Delay (seconds)
[component_container_mt-1] ros/esdf_integration       	100    	0.546
[component_container_mt-1] ros/color_image_integration	100    	0.546
[component_container_mt-1] ros/depth_image_integration	100    	0.458
[component_container_mt-1] ros/depth_image_callback   	100    	0.243
[component_container_mt-1] ros/color_image_callback   	100    	0.240
[component_container_mt-1] [INFO] [1730849775.284931032] [nvblox_node]: Depth Statistics:
[component_container_mt-1] avg=212.191419, min=1.304427, max=519.248602, std_dev=30.598434, count=10612
^C[WARNING] [launch]: user interrupted with ctrl-c (SIGINT)
[component_container_mt-1] [INFO] [1730849778.355400712] [rclcpp]: signal_handler(signum=2)
[INFO] [robot_state_publisher-2]: process has finished cleanly [pid 88810]
[INFO] [rviz2-3]: process has finished cleanly [pid 88812]
[rviz2-3] [INFO] [1730849778.355405960] [rclcpp]: signal_handler(signum=2)
[robot_state_publisher-2] [INFO] [1730849778.355408008] [rclcpp]: signal_handler(signum=2)
[component_container_mt-1] [INFO] [1730849778.481249866] [nvblox_node]: Timing statistics:
[component_container_mt-1] NVBlox Timings (in seconds)
[component_container_mt-1] namespace/tag - NumSamples - TotalTime - (Mean +- StdDev) - [Min,Max]
[component_container_mt-1] /esdf_slicer/get_aabb                         	   5520	00.165005	(00.000030 +- 00.000010)	[00.000001,00.000650]
[component_container_mt-1] /esdf_slicer/slice_layer                      	   5479	12.704775	(00.002319 +- 00.001199)	[00.000111,00.139642]
[component_container_mt-1] color/integrate                               	   8283	553.145147	(00.066781 +- 00.070205)	[00.001668,00.247916]
[component_container_mt-1] color/integrate/allocate_blocks               	   8283	58.551820	(00.007069 +- 00.039055)	[00.000067,00.194391]
[component_container_mt-1] color/integrate/get_blocks_in_view            	   8283	03.071003	(00.000371 +- 00.000168)	[00.000189,00.005468]
[component_container_mt-1] color/integrate/reduce_to_blocks_in_band      	   8283	65.846667	(00.007950 +- 00.009993)	[00.000328,00.186947]
[component_container_mt-1] color/integrate/sphere_trace                  	   8283	377.486956	(00.045574 +- 00.063874)	[00.000360,00.220408]
[component_container_mt-1] color/integrate/sphere_trace/hash_transfer    	   8283	358.592062	(00.043293 +- 00.063944)	[00.000001,00.219088]
[component_container_mt-1] color/integrate/transfer_blocks               	   8283	36.069596	(00.004355 +- 00.020668)	[00.000122,00.181925]
[component_container_mt-1] color/integrate/update_blocks                 	   8283	11.575567	(00.001398 +- 00.001097)	[00.000319,00.167490]
[component_container_mt-1] esdf/integrate/clear                          	   5393	08.193795	(00.001519 +- 00.001054)	[00.000227,00.151343]
[component_container_mt-1] esdf/integrate/clear/get_blocks               	   5393	01.064018	(00.000197 +- 00.000225)	[00.000030,00.108795]
[component_container_mt-1] esdf/integrate/compute/neighbor_bands         	  26603	39.893708	(00.001500 +- 00.001675)	[00.000105,00.167104]
[component_container_mt-1] esdf/integrate/compute/neighbor_bands/gpu_view	  26603	00.022708	(00.000001 +- 00.000000)	[00.000000,00.003035]
[component_container_mt-1] esdf/integrate/compute/swap                   	  26603	00.029332	(00.000001 +- 00.000000)	[00.000000,00.000239]
[component_container_mt-1] esdf/integrate/compute/sweep                  	  26603	02.460562	(00.000092 +- 00.000048)	[00.000007,00.146435]
[component_container_mt-1] esdf/integrate/mark_sites/pack_out            	   5393	02.883380	(00.000535 +- 00.000896)	[00.000064,00.009172]
[component_container_mt-1] esdf/integrate_slice                          	   5527	337.990212	(00.061153 +- 00.067269)	[00.000001,00.355386]
[component_container_mt-1] esdf/integrate_slice/compute                  	   5393	44.763791	(00.008300 +- 00.006675)	[00.000219,00.207068]
[component_container_mt-1] esdf/integrate_slice/mark_sites               	   5393	284.964804	(00.052840 +- 00.066950)	[00.000302,00.242384]
[component_container_mt-1] gpu_hash/transfer                             	  11118	616.771218	(00.055475 +- 00.059300)	[00.000430,00.226511]
[component_container_mt-1] gpu_hash/transfer/reallocation                	      2	00.199550	(00.099775 +- 00.062662)	[00.037113,00.162437]
[component_container_mt-1] mesh/gpu/get_meshable                         	   5297	12.928927	(00.002441 +- 00.001128)	[00.000256,00.167581]
[component_container_mt-1] mesh/gpu/integrate                            	   5298	640.622824	(00.120918 +- 00.068733)	[00.000002,00.292942]
[component_container_mt-1] mesh/gpu/mesh_blocks                          	   5297	625.154492	(00.118020 +- 00.069092)	[00.011248,00.275519]
[component_container_mt-1] mesh/gpu/mesh_blocks/block_allocation         	   5297	08.265672	(00.001560 +- 00.001094)	[00.000153,00.165054]
[component_container_mt-1] mesh/gpu/mesh_blocks/copy_out                 	   5297	379.479101	(00.071640 +- 00.069273)	[00.000042,00.193503]
[component_container_mt-1] mesh/gpu/mesh_blocks/kernel_table             	   5297	113.282751	(00.021386 +- 00.004727)	[00.003031,00.092951]
[component_container_mt-1] mesh/gpu/mesh_blocks/kernel_vertices          	   5297	16.704542	(00.003154 +- 00.001690)	[00.000774,00.164233]
[component_container_mt-1] mesh/gpu/mesh_blocks/prep                     	   5297	45.114894	(00.008517 +- 00.026195)	[00.000284,00.191598]
[component_container_mt-1] mesh/gpu/mesh_blocks/welding                  	   5297	62.046829	(00.011714 +- 00.002598)	[00.002826,00.189585]
[component_container_mt-1] ros/clear_outside_radius                      	   1845	00.004140	(00.000002 +- 00.000001)	[00.000000,00.000110]
[component_container_mt-1] ros/color                                     	  10628	563.265509	(00.052998 +- 00.063378)	[00.000006,00.252039]
[component_container_mt-1] ros/color/conversion                          	   8283	09.498460	(00.001147 +- 00.001304)	[00.000113,00.151776]
[component_container_mt-1] ros/color/integrate                           	   8283	553.425124	(00.066815 +- 00.070202)	[00.001684,00.247949]
[component_container_mt-1] ros/color/transform                           	  10628	00.226206	(00.000021 +- 00.000007)	[00.000005,00.001317]
[component_container_mt-1] ros/color_image_callback                      	  10628	116.187459	(00.010932 +- 00.022303)	[00.000033,00.405586]
[component_container_mt-1] ros/decay_tsdf                                	   5300	21.147383	(00.003990 +- 00.003046)	[00.000179,00.164207]
[component_container_mt-1] ros/depth                                     	  10628	266.604657	(00.025085 +- 00.042156)	[00.000781,00.207339]
[component_container_mt-1] ros/depth/conversions                         	  10628	117.125571	(00.011020 +- 00.018293)	[00.000026,00.192800]
[component_container_mt-1] ros/depth/integrate                           	  10628	148.983163	(00.014018 +- 00.038599)	[00.000715,00.195382]
[component_container_mt-1] ros/depth/output/back_projected_depth         	  10628	00.074657	(00.000007 +- 00.000002)	[00.000002,00.000614]
[component_container_mt-1] ros/depth/transform                           	  10628	00.258749	(00.000024 +- 00.000006)	[00.000013,00.001974]
[component_container_mt-1] ros/depth_image_callback                      	  10628	06.736762	(00.000634 +- 00.001263)	[00.000030,00.097637]
[component_container_mt-1] ros/esdf                                      	   5527	441.126865	(00.079813 +- 00.067656)	[00.000095,00.379073]
[component_container_mt-1] ros/esdf/integrate                            	   5527	339.897198	(00.061498 +- 00.067247)	[00.000081,00.361500]
[component_container_mt-1] ros/esdf/output                               	   5527	101.183028	(00.018307 +- 00.021801)	[00.000009,00.182255]
[component_container_mt-1] ros/idle                                      	   7520	21.244951	(00.002825 +- 00.003158)	[00.000156,00.014708]
[component_container_mt-1] ros/mesh                                      	   5322	732.461973	(00.137629 +- 00.068774)	[00.000032,00.549782]
[component_container_mt-1] ros/mesh/output                               	   5298	25.294886	(00.004774 +- 00.001343)	[00.000001,00.033632]
[component_container_mt-1] ros/mesh/update                               	   5322	705.944582	(00.132646 +- 00.068914)	[00.000031,00.535609]
[component_container_mt-1] ros/process_message_queue                     	  15042	1042.378904	(00.069298 +- 00.061101)	[00.000032,00.407627]
[component_container_mt-1] ros/publish_layer                             	   5536	00.432812	(00.000078 +- 00.000014)	[00.000007,00.005662]
[component_container_mt-1] ros/static/esdf/output/compute                	   5520	12.930773	(00.002343 +- 00.001199)	[00.000004,00.139703]
[component_container_mt-1] ros/static/esdf/output/pointcloud             	   5520	87.915693	(00.015927 +- 00.021500)	[00.000093,00.181572]
[component_container_mt-1] ros/tick                                      	   7521	2238.514339	(00.297635 +- 00.201227)	[00.000117,01.022147]
[component_container_mt-1] tsdf/integrate                                	  10628	117.445840	(00.011051 +- 00.035479)	[00.000535,00.195132]
[component_container_mt-1] tsdf/integrate/allocate_blocks                	  10628	17.877340	(00.001682 +- 00.020643)	[00.000040,00.179810]
[component_container_mt-1] tsdf/integrate/get_blocks_in_view             	  10628	72.598013	(00.006831 +- 00.028559)	[00.000180,00.184035]
[component_container_mt-1] tsdf/integrate/transfer_blocks                	  10628	14.521142	(00.001366 +- 00.000732)	[00.000062,00.171682]
[component_container_mt-1] tsdf/integrate/update_blocks                  	  10628	12.216338	(00.001149 +- 00.001158)	[00.000061,00.156685]
[component_container_mt-1] view_calculator/get_blocks_in_view_planes     	   8283	00.006006	(00.000001 +- 00.000000)	[00.000000,00.000322]
[component_container_mt-1] view_calculator/raycast                       	  10628	72.557093	(00.006827 +- 00.028559)	[00.000177,00.184030]
[component_container_mt-1] view_calculator/raycast/output                	  10628	50.605285	(00.004762 +- 00.028137)	[00.000042,00.178946]
[component_container_mt-1] view_calculator/raycast/raycast_pixels_kernel 	  10628	20.609830	(00.001939 +- 00.001627)	[00.000102,00.171418]
[component_container_mt-1] view_calculator/raycast/setup                 	  10628	01.206494	(00.000114 +- 00.000018)	[00.000012,00.159047]
