I’ve been trying to integrate a camera with NVblox for a while now. However, the camera’s localization estimation goes through PX4 EKF2 to fuse localization with other sensors, so there is a bit of a sensor delay between the depth image from the camera and the transform from localization. This sensor delay is turning the camera into an eraser when I try to integrate the depth image into NVblox. Whenever the camera looks away, it deletes many of the voxels on the edge of the view. I can do some work to tighten the sensor delay, but I’d prefer if the mapping solution were much more robust to this issue. What steps can I take to fix this?
Here are my current parameters for NVblox. I’ve tried to tune the parameters as much as possible to keep voxels in place, but there seems to be a fundamental limitation.
multi_mapper:
connected_mask_component_size_threshold: 2000
remove_small_connected_components: true
static_mapper:
do_depth_preprocessing: false
depth_preprocessing_num_dilations: 3
projective_integrator:
projective_integrator_max_integration_distance_m: 20.0
projective_integrator_truncation_distance_vox: 10.0
projective_integrator_weighting_mode: “constant”
projective_integrator_max_weight: 100.0
projective_tsdf_integrator_invalid_depth_decay_factor: -1.0
occupancy_integrator:
free_region_occupancy_probability: 0.3
occupied_region_occupancy_probability: 0.7
unobserved_region_occupancy_probability: 0.5
occupied_region_half_width_m: 1.5
occupancy_decay_integrator:
occupied_region_decay_probability: 0.45
free_region_decay_probability: 0.55
occupancy_decay_to_free: false
freespace_integrator:
max_tsdf_distance_for_occupancy_m: 1.0
max_unobserved_to_keep_consecutive_occupancy_ms: 10000
min_duration_since_occupied_for_freespace_ms: 2000
min_consecutive_occupancy_duration_for_reset_ms: 10
check_neighborhood: true
view_calculator:
raycast_subsampling_factor: 4
workspace_bounds_type: “unbounded”
workspace_bounds_min_corner_x_m: 0.0
workspace_bounds_max_corner_x_m: 0.0
workspace_bounds_min_corner_y_m: 0.0
workspace_bounds_max_corner_y_m: 0.0
workspace_bounds_min_height_m: -100.0
workspace_bounds_max_height_m: 100.0
esdf_integrator:
esdf_integrator_min_weight: 0.1
esdf_integrator_max_site_distance_vox: 2.0
esdf_integrator_max_distance_m: 2.0
esdf_slice_min_height: -0.1
esdf_slice_max_height: 0.3
esdf_slice_height: 0.0
mesh_integrator:
mesh_integrator_min_weight: 0.1
mesh_integrator_weld_vertices: true
tsdf_decay_integrator:
tsdf_decay_factor: 0.95
tsdf_decayed_weight_threshold: 0.0001
tsdf_set_free_distance_on_decayed: false
tsdf_decayed_free_distance_vox: 4.0
decay_integrator_base:
decay_integrator_deallocate_decayed_blocks: true
dynamic_mapper:
esdf_integrator:
