NvDCF error on 4.1 version, It is working with KLT tracker
can you verify
(gst-plugin-scanner:7734): GLib-GObject-WARNING **: 10:05:46.513: cannot register existing type 'GstInterpolationMethod'
(gst-plugin-scanner:7734): GLib-GObject-CRITICAL **: 10:05:46.513: g_param_spec_enum: assertion 'G_TYPE_IS_ENUM (enum_type)' failed
(gst-plugin-scanner:7734): GLib-GObject-CRITICAL **: 10:05:46.513: validate_pspec_to_install: assertion 'G_IS_PARAM_SPEC (pspec)' failed
Using winsys: x11
Creating LL OSD context new
0:00:01.737432736 7733 0x5584db7270 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 5]:log(): Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
0:00:03.741077760 7733 0x5584db7270 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 4]:log(): Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_nvdcf.so
gstnvtracker: Failed to open low-level lib at /opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_nvdcf.so
dlopen error: /opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_nvdcf.so : cannot open shared object file: No such file or directory
gstnvtracker: Failed to initilaize low level lib.
** ERROR: <main:651>: Failed to set pipeline to PAUSED
Quitting
