I’m using Nvidia Grid vGPU in vSphere 6.5 and Horizon Instant Clones 7.12.
In the Windows 10 v1809 LTSC virtual machine with 2 or monitors, the Nvidia Control Panel > Display > “Change Resolution” or “Set up multiple displays” … the primary monitor has the label NVIDIA VGX under it while all other monitors have the label Dell VMware VD.
Running DxDiag shows all monitors running under NVIDIA GRID T4-1B. In the VMware Blast log, it shows each display using a different driver …
2021-02-26 08:26:48.479+0800 [INFO ] 0x11c0 bora::Log: VNCSERVER-WIN32: Screen ID 0. Display name: “\.\DISPLAY2”, Device String: “NVIDIA GRID T4-1B”, Device Id: “PCI\VEN_10DE&DEV_1EB8&SUBSYS_130910DE&REV_A1”
2021-02-26 08:26:48.480+0800 [INFO ] 0x11c0 bora::Log: VNCSERVER-WIN32: Screen ID 1. Display name: “\.\DISPLAY1”, Device String: “Microsoft Basic Display Adapter”, Device Id: “PCI\VEN_15AD&DEV_0405&SUBSYS_040515AD&REV_00”
… but 2 seconds later, it show both displays using the Nvidia driver:
2021-02-26 08:26:50.987+0800 [INFO ] 0x11c0 bora::Log: VNCSERVER-WIN32: Screen ID 0. Display name: “\.\DISPLAY2”, Device String: “NVIDIA GRID T4-1B”, Device Id: “PCI\VEN_10DE&DEV_1EB8&SUBSYS_130910DE&REV_A1”
2021-02-26 08:26:50.988+0800 [INFO ] 0x11c0 bora::Log: VNCSERVER-WIN32: Screen ID 1. Display name: “\.\DISPLAY3”, Device String: “NVIDIA GRID T4-1B”, Device Id: “PCI\VEN_10DE&DEV_1EB8&SUBSYS_130910DE&REV_A1”
Just wondering if the Nvidia Control Panel labels for each monitor is mis-represented and both monitors are actually running with the Nvidia driver.
Is there a way to verify this within the Nvidia Control Panel or Nvidia logs?
