Has anybody successfully resolved the issue:
Run cuda code and find following error: “NVIDIA: could not open the device file /dev/nvidiactl (No such file or directory).”
Tried to run the script provided by the previous note below and got the error “fix: line 9: /etc/init.d/functions: No such file or directory”.
=> “http://forums.nvidia.com/lofiversion/index.php?t52629.html”
The environment is S870 with SUSE 10.
Thanks in advance!
Have you tried starting X with the nvidia driver?
Thx netllama!
Tried “startx” and got following message. It seems to be running already. ??
[codebox]
xauth: creating new authority file /home/xxxx/.serverauth.8608
Fatal server error:
Server is already active for display 0
If this server is no longer running, remove /tmp/.X0-lock
and start again.
Please consult the The X.Org Foundation support
at <a target='_blank' rel='noopener noreferrer' href='"http://wiki.X.Org"'>http://wiki.X.Org</a>
for help.
Xlib: connection to “:0.0” refused by server
Xlib: Invalid MIT-MAGIC-COOKIE-1 key
giving up.
/usr/X11R6/bin/xinit: unable to connect to X server
/usr/X11R6/bin/xinit: No such process (errno 3): Server error.
Fatal server error:
and start again.
for help.
giving up.
[/codebox]
Please generate and attach an nvidia-bug-report.log
