Has anybody successfully resolved the issue:
Run cuda code and find following error: “NVIDIA: could not open the device file /dev/nvidiactl (No such file or directory).”
Tried to run the script provided by the previous note below and got the error “fix: line 9: /etc/init.d/functions: No such file or directory”.
=> “http://forums.nvidia.com/lofiversion/index.php?t52629.html ”
The environment is S870 with SUSE 10.
Thanks in advance!
A quick and dirty solution would be to give the program the permissions to use that device
sudo chmod a+rwx /dev/nvidiactl
=> “The Official NVIDIA Forums | NVIDIA ”
Thanks in advance!
Looks like your display driver has not been properly installed.
Thank you nasacort and jjtapiav!
I just checked the directory and found out that “/dev/nvidiactl” does not even exist anymore. This happened after relocating the server.
Do I have to reinstall the cuda toolkit and driver?
edit: move over to the other thread of the same name.
Thanks in advance!
I got the same problem…
Cuda works fine for about a week, until I run a very long program (or maybe a infinate loop)
It seems that cuda will lock and remove the /dev/nvidiactl while running. Now, as the /dev/nvidiactl has vanished, what should I do? reinstall the cuda driver?
hi…i have a similar issue whenever i reboot my linux box. i do a chmod +777 /dev/nv* which fixes it.
I am naive in linux… Does not MAKEDEV script help?
