Nvidia-docker installation example getting unable to find image error
hello everyone,
I’m trying to setup Nvidia-Docker to my Jetson Nano.
On the last step of documentation Installation Guide — NVIDIA Cloud Native Technologies documentation there is a command given to test the nvidia-docker
This is the command;
sudo docker run --rm --gpus all nvidia/cuda:11.0-base nvidia-smi
Since Nano doesn’t have nvidia-smi or nvcc, I downloaded tegrastats jtop to my system instead.
Oh and I also changed the docker tag to ;
`sudo docker run --rm --gpus all nvidia/cuda:10.2-base jtop since my system informations are as given below:
NVIDIA Jetson Nano (Developer Kit Version)
L4T 32.6.1 [ JetPack 4.6 ]
Ubuntu 18.04.6 LTS
Kernel Version: 4.9.253-tegra
CUDA 10.2.300
CUDA Architecture: 5.3
OpenCV version: 4.1.1
OpenCV Cuda: NO
CUDNN: 8.2.1.32
TensorRT: 8.0.1.6
Vision Works: 1.6.0.501
VPI: ii libnvvpi1 1.1.15 arm64 NVIDIA Vision Programming Interface library
The error could be found in the file below, I guess It’s not a big problem that I’m getting this error but I still would like to be able to run the test case too
message.txt (19.7 KB)
thanks and regards
hi! I know it is one year later but probably it would help
sudo docker run --runtime=nvidia --rm nvidia/cuda:11.0-base nvidia-smi
That’s really kind of you, thank you so much.
Unfortunately I no longer have access to Nano but back then I solved it the same way you’re suggesting.
Thank you!
