When I run nvidia-smi I receive the following error:
NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
When I run nvidia-settings I receive the following error:
ERROR: NVIDIA driver is not loaded
ERROR: Unable to load info from any available system
(nvidia-settings:11905): GLib-GObject-CRITICAL **: 16:50:01.416: g_object_unref: assertion (184.2 KB) ‘G_IS_OBJECT (object)’ failed
** Message: 16:50:01.418: PRIME: No offloading required. Abort
** Message: 16:50:01.418: PRIME: is it supported? no
Output of dkms status is:
nvidia, 465.19.01: added
I do not have a file under the name /etc/modprobe.d/blacklist-nvidia.conf
The output of lspci -v | grep VGA is:
00:02.0 VGA compatible controller: Intel Corporation Device 9bc4 (rev 05) (prog-if 00 [VGA controller])
01:00.0 VGA compatible controller: NVIDIA Corporation Device 1e91 (rev a1) (prog-if 00 [VGA controller])
The output of prime-select query is nvidia
There is no output to lspci -v | grep 3D
On a Ubuntu only MSI GS66 Stealth
Running Ubuntu 18.04.5 LTS
Kernel: 5.4.0
CPU: Intel® Core™ i7-10750H CPU @ 2.60GHz × 12
Intel Graphics: Intel® UHD Graphics (CML GT2)
Nvidia GPU: NVIDIA® GeForce® RTX 2070 SUPER™ Max-Q
GNOME: 3.28.2
I have attached the bug report nvidia-bug-report.log.gz (184.2 KB)
