Nvidia Driver Quadro P2000 on Redhat 8
We are trying to install the driver for Nvidia Quadro P2000 on Redhat 8.2
After several unsuccessful attempts following some instructions like that link : https://linuxconfig.org/redhat-8-nvidia-driver-install-guide
We followed this link sent from Redhat support : How to install Nvidia CUDA on RHEL 8 - Red Hat Customer Portal
Now we can get a GUI by running startx command but when restart the server it stops at boot as you can see :
There is this error in Xorg.0.conf :
[ 331.307] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; t he daemon
[ 331.307] (II) NVIDIA(0): may not be running or the “AcpidSocketPath” X
[ 331.307] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 331.307] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X dr iver will
[ 331.307] (II) NVIDIA(0): try to use it to receive ACPI event notificatio ns. For
[ 331.307] (II) NVIDIA(0): details, please see the “ConnectToAcpid” and
[ 331.307] (II) NVIDIA(0): “AcpidSocketPath” X configuration options in Ap pendix B: X
[ 331.307] (II) NVIDIA(0): Config Options in the README.
[ 331.323] (EE)
[ 331.323] (EE) Backtrace:
[ 331.323] (EE) 0: /usr/libexec/Xorg (xorg_backtrace+0x7d) [0x55ca9b9ed3ad]
[ 331.323] (EE) 1: /usr/libexec/Xorg (0x55ca9b835000+0x1bc15d) [0x55ca9b9f115d ]
[ 331.323] (EE) 2: /lib64/libpthread.so.0 (0x7f9f56da9000+0x12dd0) [0x7f9f56db bdd0]
[ 331.323] (EE) 3: /usr/lib64/xorg/modules/drivers/nvidia_drv.so (0x7f9f5293c0 00+0xbd0d2) [0x7f9f529f90d2]
[ 331.323] (EE) 4: /usr/lib64/xorg/modules/drivers/nvidia_drv.so (0x7f9f5293c0 00+0xabf78) [0x7f9f529e7f78]
[ 331.323] (EE) 5: /usr/lib64/xorg/modules/drivers/nvidia_drv.so (0x7f9f5293c0 00+0x75373) [0x7f9f529b1373]
[ 331.323] (EE) 6: /usr/lib64/xorg/modules/drivers/nvidia_drv.so (0x7f9f5293c0 00+0x4db7de) [0x7f9f52e177de]
[ 331.323] (EE)
[ 331.323] (EE) Segmentation fault at address 0x55ca9dc26000
[ 331.323] (EE)
Fatal server error:
[ 331.323] (EE) Caught signal 11 (Segmentation fault). Server aborting
[ 331.323] (EE)
[ 331.323] (EE)
Please consult the The X.Org Foundation support
for help.
[ 331.323] (EE) Please also check the log file at “/var/log/Xorg.0.log” for ad ditional information.
[ 331.323] (EE)
[ 331.350] (EE) Server terminated with error (1). Closing log file.
The symptom is like you don’t have a valid xorg.conf file…
But please run nvidia-bug-report.sh as root and attach the resulting nvidia-bug-report.log.gz file.
We need to read the whole error log to figure out the main problems.
Thanks for your answer.
You can check the file below
nvidia-bug-report.log.gz (1.2 MB)
test this xorg.conf file @copwell
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0"
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
    Inactive       "InactiveDevice1"
EndSection
Section "Files"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/input/mice"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Unknown"
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
    BusID          "PCI:59@0:0:0"
EndSection
Section "Device"
    Identifier     "InactiveDevice1"
    Driver         "matrox"
    VendorName     "Matrox Electronics"
    BusID          "PCI:3@0:0:0"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
Thank you very much it works !
glad to heard that @copwell
