I have Kubuntu 20.04 and graphics card Nvidia 750Ti and two displays connected to it (HDMI and DVI).
In case I do NOT set
nvidia-drm.modeset=1(default), only one of my displays is detected and its resolution is incorrect (only minimal, like 1024*764) without a way to change. -
If I SET
nvidia-drm.modeset=1in Grub options, I get everything fine on the start, but simetimes (i. e. when I load WebStorm - 100% reproducibility here, don’t know why) the second (DVI) monitor turning off, then after a sec turning on, but KDE UI restarts there (all my windows were moved to the first display and I need to return them back manually).
This bug appears only once after restart, then all works fine. -
More strange is I already had another Kubuntu installation (100% equal to current, I just reinstalled it due to my SDD failed), and everything worked fine WITHOUT
nvidia-drm.modeset=1, but once if I go out of memory, after restart, I fell into the bug (1) described above. And the solution for fixing this was settingnvidia-drm.modeset=1ONCE - after next restarts it was not needed and all worked fine again.
I already googled a log of articles, checked all permissions for configs and dev files as it recommended, but did not understand what’s wrong here.
Do you have any idea what do I need to change to fix such strange behaviour?
